lists(at)stevet.net Guest
Posted: Sat Jan 16, 2010 10:04 am Post subject: Encoder Certification |
A message to Stan Sutterfield:
You wrote last June:
| Quote: | | This may not be the ideal forum for asking this question, but I'll try it anyway. I want to certify my RV-8 for IFR flight. I know the FARs - I've looked at them. I have the Blue Mountain EFIS One as primary instrumentation. I have the Blue Mountain EFIS Lite as a backup. Both EFISs are on different electrical busses - the main and the standby. - which can be tied together, if needed. I asked a local avionics guy about doing a pitot-static and transponder check for IFR. He said I would have to install a separate altimeter and encoder in order to get IFR certification. The EFIS has a built-in encod er. Has anyone else encountered this obstacle? Stan Sutterfield |
There were several replies that mostly focused on finding the right avionics guy. I have the exact same setup in my panel as do you and am ready for certification. Can you share your experience? Are you certified and flying? Who did you use for your certification and how did you go about getting it?
I am in Southern California, and anyone else who can offer any advice on this topic will be welcome. My local shop mostly deals with biz jets and large non-jets. I don't think they will be very helpful with an experimental. Also, exorbitantly expensive. Do I need a transponder cert for my DAR inspection? Can I fly somewhere else to get it done once I have flown off my hours?
Steve Thomas
________________________________________________________________________
flyboybob1(at)gmail.com Guest
Posted: Sat Jan 16, 2010 11:14 am Post subject: Encoder Certification |
Steve,
You wrote: << My local shop ... I don't think they will be very helpful with an experimental. Also, exorbitantly expensive. >>
Never let what you think prevent you from asking. If you don't ask your local shop it's a 0% chance they will calibrate your system at a reasonable price. If you do ask them all they can say is yes or no so you've got a 50% chance they will help you at a reasonable price. Your odds of success are 50 times better if you ask!
Bob Lee
N52BL KR2
Suwanee, GA USA
92% done only 67% to go!
bgray(at)glasair.org Guest
Posted: Sat Jan 16, 2010 12:27 pm Post subject: Encoder Certification |
I would advise you to check with the EAA. This subject has been aired before. I essence, by passing the certification criteria (ramp test), it meets the FAA’s standards. No TSO or separate encoder/altimeter is required. The EAA has chapter and verse. I would also suggest you find another shop who work on experimentals. Those heavy iron types are rather inflexible to new ideas.
Bruce
www.Glasair.org
bakerocb
Posted: Sun Jan 17, 2010 6:12 am Post subject: Encoder Certification |
1/17/2009
Hello Steve Thomas, You wrote:
1) "Can I fly somewhere else to get it done once I have flown off my hours?"
Here is what 14 CFR says:
"91.215 ATC transponder and altitude reporting equipment and use.
(d) ATC authorized deviations. Requests for ATC authorized deviations must
be made to the ATC facility having jurisdiction over the concerned airspace
within the time periods specified as follows:
(2) For operation of an aircraft with an inoperative transponder to the
airport of ultimate destination, including any intermediate stops, or to
proceed to a place where suitable repairs can be made or both, the request
may be made at any time."
So you see that it is possible to fly your airplane without an operating
transponder where one is required if you obtain ATC permission to do so. Why
not do some research to:
A) Determine how amenable your local ATC coverage people are to letting you
make a one time flight without a transponder IAW 91.215 (d) (2) above.
B) Find a facility that will do your transponder cert and design your flight
test area to include that facility. Then make your request to ATC and on a
flight subsequent to your first flight fly to that location to have the
certification done. (I recommend that the first test flight be just a 20-30
minute orbit over the originating field.)
It would not be reasonable to expect permission to perform the entire Phase
one testing without a transponder unless you were able to do the testing in
airspace that did not require a transponder.
2) "Do I need a transponder cert for my DAR inspection?"
The regulations do not require this -- see 91.215 (d) (2). But a DAR, or FAA
inspector, has wide discretion and the power of the FAA Administrator in
that original airworthiness inspection and he may choose to require one.
If you have not already established some contact and level of rapport with
your prospective inspector you should start now -- and ask him that
question. An FAA inspector would be my first choice. How are you doing with
the program letter and all of the other paperwork required?
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Time: 10:04:13 AM PST US
Subject: AeroElectric-List: Encoder Certification
| Quote: | This may not be the ideal forum for asking this question, but I'll try
it
| Quote: | anyway.
looked at
| Quote: | them.
standby.
| Quote: | -
transponder
and
encod
| Quote: | er.
Stan Sutterfield
Steve Thomas
bobsv35b(at)aol.com Guest
Posted: Sun Jan 17, 2010 6:50 am Post subject: Encoder Certification |
Good Morning O.C. and Steve Thomas,
You (O.C.) have given your usual very accurate listing of current rules and you did use language saying that there is airspace where the transponder is not required. However, I get the feeling that Steve may not realize that the use of a transponder is NOT required in the vast majority of airspace within the United States of America. I want to emphasize that point
I also recognize that he does wish to fly IFR and doing so does increase the likelihood of his wanting to have a certified operational transponder.
As long as he is operating in a space where no transponder is required, there should be no rush to get it checked.
The DAR has no need to evaluate the suitability of the aircraft for IFR flight. He should just use the canned language that the aircraft is to be flown day VFR only unless it is equipped -- etc. It is up to the operator to make the IFR and night suitability determination.
Please DO NOT ask the DAR to list it any way other than as recommended. It will just muddy up the water.
Have I once again placed my foot in my mouth?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Downers Grove, IL
Stearman N3977A
In a message dated 1/17/2010 8:14:44 A.M. Central Standard Time, bakerocb(at)cox.net writes:
| Quote: | --> AeroElectric-List message posted by: <bakerocb(at)cox.net>
1/17/2009
Sam
Posted: Sun Jan 17, 2010 7:15 am Post subject: Encoder Certification |
Without looking at the regs, I seem to recall that if the aircraft is equipped with an operating transponder, it must be turned on. My simple minded solution would to pull the transponder and stuff it into a flight bag. You could even apply a sticker that says "INOP".
Fly to the shop, then install it for the test.
Sam
On Sun, Jan 17, 2010 at 8:49 AM, <bobsv35b(at)aol.com (bobsv35b(at)aol.com)> wrote:
[quote] Good Morning O.C. and Steve Thomas,
Happy Skies,
Old Bob
AKA
Bob Siegfried
Downers Grove, IL
Stearman N3977A
In a message dated 1/17/2010 8:14:44 A.M. Central Standard Time, bakerocb(at)cox.net (bakerocb(at)cox.net) writes:
| Quote: | --> AeroElectric-List message posted by: <bakerocb(at)cox.net (bakerocb(at)cox.net)>
1/17/2009
tp://forums.matronics.com
_________________ Sam Hoskins
www.samhoskins.blogspot.com |
speedy11(at)aol.com Guest
Posted: Sun Jan 17, 2010 8:42 am Post subject: Encoder Certification |
All of this is correct, but why does ATC need to be involved? Unless you will be flying under airspace that requires a transponder, then there is no need to contact ATC unless you want them to check your transponder code and mode C. If you are transiting under class B, then coordinate with approach control by phone for instructions.
My DAR did not ask for proof of pitot-static or transponder certification - although I had them available.
Stan Sutterfield
| Quote: | 1/17/2009
it
| Quote: | anyway.
looked at
| Quote: | them.
standby.
| Quote: | -
transponder
and
encod
| Quote: | er.
Stan Sutterfield
Steve Thomas |
Posted: Sun Jan 17, 2010 8:54 am Post subject: Encoder Certification |
Steve,
I believe that your assessment of your local avionics shops is correct - that is, they service jets and large piston aircraft - and thus, they are unlikely to be interested in doing a low dollar certification for you.
However, I have to agree with Bob and recommend that you at least ask them. I've talked to the shop floor guys in large aviation businesses and found that often they are very interested in doing an experimental cert - if for no other reason than to say they've done it.
Ask them - you have nothing to lose.
Stan Sutterfield
| Quote: | You wrote: << My local shop ... I don't think they will be very helpful
Posted: Sun Jan 17, 2010 9:36 am Post subject: Encoder Certification |
A discussion is already underway. What is most important to me is to know the facts. You cannot argue with "experts" if you don't know the facts. Being able to do my own pitot-static check will also get me a long way to being able to discuss with some authority. Being able to calibrate my BMA EFIS ahead of time will be a giant step in the right direction.
Thanks to all of you for this invaluable help! I will report back and detail my experience.
Steve Thomas
On Jan 17, 2010, at 8:52 AM, Speedy11(at)aol.com (Speedy11(at)aol.com) wrote:
[quote]Steve,
Stan Sutterfield
dalamphere(at)comcast.net Guest
Posted: Sun Jan 17, 2010 10:01 am Post subject: Encoder Certification |
When I requested my airworthiness inspection from the FAA inspector on my Wittman Tailwind , he insisted that I get my pitot/static/transponder/encoder system checked by a certified shop to FAR 91.413, FAR43 App F - IFR standards - FIRST before he would come out - even tho the plane was not going to be used in IFR conditions. I found a guy that was setup to do this at my hangar (Don Hendrix) and did a fine job. We found some leaks in the static system partway through the tests that I corrected before the test could be completed. He made some adjustments in the process of the tests also.
The FAA inspector felt that it was the safe thing to do on a newly built plane and would eliminate one cause for first flight problems later.
I agree, - - - now..
Dave
ianxbrown
Posted: Sun Jan 17, 2010 10:43 am Post subject: Encoder Certification |
I'd also agree. Having both the pitot and the static system tested by a mechanic with the right equipment is very important. After my own experience, I'd say VITAL to safe first flight testing. Having done what I thought was a very good job of building my aircraft we discovered five separate tiny leaks in the system. Finding them would have been a lot more complicated without the expert help. Ian Brown, RV-9A
clip When I requested my airworthiness inspection from the FAA inspector on my Wittman Tailwind , he insisted that I get my pitot/static/transponder/encoder system checked by a certified shop to FAR 91.413, FAR43 App F - IFR standards - FIRST before he would come out - even tho the plane was not going to be used in IFR conditions. I found a guy that was setup to do this at my hangar (Don Hendrix) and did a fine job. We found some leaks in the static system partway through the tests that I corrected before the test could be completed. He made some adjustments in the process of the tests also.
bakerocb
Posted: Sun Jan 17, 2010 1:02 pm Post subject: Encoder Certification |
1/17/2010
Hello Stan Sutterfield, You wrote:
1) "All of this is correct, but why does ATC need to be involved?"
Valid question. ATC does not need to be involved in approving non
transponder flight operations if one is not flying in airspace where the
aircraft must be transponder equipped.
Note my wording copied from below "......where one is required....".
See 14 CFR 91.215 (b) (1) through (5) for a description of the airspace
where the aircraft must be transponder equipped. We are assuming an aircraft
that has been originally certificated with an engine-driven electrical
system.
2) "Unless you will be flying under airspace that requires a transponder,
then there is no
need to contact ATC ..........skip....."
I agree, providing the word "under" is changed to the word "in" as "in" is a
more inclusive word and also the wording used in 14 CFR 91.215.
3) "........... coordinate with approach control by phone for
instructions."
Approach Control is part of the ATC (Air Traffic Control) system. When you
talk to approach control you are talking to ATC.
4) "My DAR did not ask for proof of pitot-static or transponder
certification ..........."
Good, I think that is the way that it should be done. However, as I
mentioned earlier the inspector during the initial airworthiness inspection
is endowed with the power of the Administrator and some inspectors swing a
too heavy hammer. If one disagrees with the inspector one is left with
either swallowing that disagreement or going over the inspector's head
within the FAA.
One should proceed with caution in going over the inspector's head on a
specific item because the inspector may find other areas to show that he is
really the boss. I recall a particularly stubborn DAR that required
direction from FAA Headquarters, at my request, through the supervising FSDO
before he would yield on an inspection issue. He got so mad when he was over
ruled that he refused to acknowledge to me that he had been wrong.
Posted: Mon Jan 18, 2010 10:08 am Post subject: Encoder Certification |
Steve,
You may already know about this, but EAA Chapter 1000 has a lot of test pilot guys (Edwards AFB) and their web site has instructions on doing your own pitot-static calibration. You can see it at http://www.eaa1000.av.org/technicl/techidx.htm.
Stan Sutterfield
| Quote: | A discussion is already underway. What is most important to me is to
direction.
detail my experience. |
bakerocb
Posted: Mon Jan 18, 2010 10:24 am Post subject: Encoder Certification |
1/18/2010
Hello Sam Hoskins, You wrote:
1) "Without looking at the regs, I seem to recall that if the aircraft is
equipped with an operating transponder, it must be turned on."
That is correct. Here is what 14 CFR 91.215 (c) says:
"(c) Transponder-on operation. While in the airspace as specified in
paragraph (b) of this section or in all controlled airspace, each person
operating an aircraft equipped with an operable ATC transponder maintained
in accordance with §91.413 of this part shall operate the transponder,
including Mode C equipment if installed, and shall reply on the appropriate
code or as assigned by ATC."
2) "My simple minded solution would to pull the transponder and stuff it
into a flight
bag. You could even apply a sticker that says "INOP". Fly to the shop, then
install it for the test."
That would be a violation of 14 CFR 91.215 which says, in part:
"(b) All airspace. Unless otherwise authorized or directed by ATC, no person
may operate an aircraft in the airspace described in paragraphs (b)(1)
through (b)(5) of this section, unless that aircraft is equipped with an
operable coded radar beacon transponder having either Mode 3/A 4096 code
capability,.............."
91.215 goes on to provide some exceptions to the above requirement such as
aircraft originally certified with no electrical system and getting
permission from ATC to operate with no transponder. What you describe is not
one of the exceptions.
Time: 07:16:01 AM PST US
Subject: Re: AeroElectric-List: Encoder Certification
Sam
jon(at)finleyweb.net Guest
Posted: Mon Jan 18, 2010 7:10 pm Post subject: Encoder Certification |
Bakerocb,
Everything noted so far in this thread assumes controlled airspace. If I missed where that was stated in this thread then ignore my comments. No doubt that what has been said is applicable given the right environment (controlled airspace).
If you read the full text of 14 CFR 91.215 (b), you will find that folks living in a place like me (middle of nowhere in New Mexico) can fly for hours and hours in most any direction and NOT come upon ANY of the airspace listed in (b)(1) through (b)(5). Additionally, 91.215 (c), does not apply as almost all of our airspace is uncontrolled.
So, given MY environment, I can fly without a transponder and/or without it turned on. There are huge expanses of this country where this is true.
If someone can prove the above wrong, I would be interested in hearing.
Jon
[quote] --
Posted: Mon Jan 18, 2010 7:51 pm Post subject: Encoder Certification |
Good Evening Jon,
I tried to make the same point a couple of days ago and my comment seems to have been totally ignored by all. Maybe you will have better luck!
Happy Skies,
Old Bob
In a message dated 1/18/2010 9:12:51 P.M. Central Standard Time, jon(at)finleyweb.net writes:
Bakerocb,
Jon
[quote] --
bakerocb
Posted: Mon Jan 18, 2010 9:15 pm Post subject: Encoder Certification |
1/18/2010
1) "Being able to do my own pitot-static check will also get me a long way
to being able to discuss with some authority."
A) There is no regulatory requirement for a pitot system check, but you may
gain some confidence in the accuracy of your airspeed indicator by
performing one.
B) The static pressure system check performed in order to meet the
requirements of 14 CFR 91.411 quoted here:
"Altimeter system and altitude reporting equipment tests and inspections.
(a) No person may operate an airplane, or helicopter, in controlled airspace
under IFR unless-
(1) Within the preceding 24 calendar months, each static pressure system,
each altimeter instrument, and each automatic pressure altitude reporting
system has been tested and inspected and found to comply with appendices E
and F of part 43 of this chapter;"
Must be performed in accordance with the portion of 14 CFR 91.411 quoted
here:
"(b) The tests required by paragraph (a) of this section must be conducted
by-
(1) The manufacturer of the airplane, or helicopter, on which the tests and
inspections are to be performed;
(2) A certificated repair station properly equipped to perform those
functions and holding-
(i) An instrument rating, Class I;
(ii) A limited instrument rating appropriate to the make and model of
appliance to be tested;
(iii) A limited rating appropriate to the test to be performed;
(iv) An airframe rating appropriate to the airplane, or helicopter, to be
tested; or
(3) A certificated mechanic with an airframe rating (static pressure system
tests and inspections only)."
So only if you hold one of the qualifications listed above, would you be
able to perform the regulatory requirement of the static pressure system
tests. But otherwise, as you point out, performing the test yourself could
help you in your discussions. The equipment and parameters to perform the
test are described in 14 CFR Appendix E to Part 43 (a).
2) "Being able to calibrate my BMA EFIS ahead of time will be a giant step
in the right
direction."
Good idea.
3) "I will report back and detail my experience."
I would appreciate that -- thank you.
Time: 09:36:20 AM PST US
Subject: Re: AeroElectric-List: Re: Encoder Certification
direction.
Steve Thomas
bakerocb
Posted: Tue Jan 19, 2010 6:19 am Post subject: Encoder Certification |
1/19/2010
Hello Jon Finley, Many thanks for your input and raising this point again.
You wrote:
1) "Everything noted so far in this thread assumes controlled airspace."
I did not make this assumption.
2) "If I missed where that was stated in this thread then ignore my
comments."
Here is my wording: "It would not be reasonable to expect permission to
airspace that did not require a transponder."
This specifically raises the point that there is indeed airspace that does
not require a transponder. I also point out that 14 CFR 91.215 (b) (1)
through (b) (5) and 91.215 (c) identifies the airspace where you must have a
transponder. If one is not flying in the airspace identified then there is
no requirement for a transponder.
3) "If you read the full text of 14 CFR 91.215 (b),........"
Absolutely on point.
Up on my soap box now: I have been working on people sized airplanes (as
opposed to models) since 1950 and flying since 1958 -- all that time I was
planning and gathering information with the intent of building my own
airplane some day. When that day came and I started to build and the
internet allowed me to see what other builders were thinking and writing I
was appalled at the ignorance and assumptions regarding applicable
regulations displayed by my fellow builders.
Here we had the greatest opportunity on our planet to do this wonderful
homebuilding and flying thing and there were many builders so willing to
operate on hearsay, gossip, and rumor and possibly violate regulations
rather than educate themselves. Each notorious violation bringing us closer
to the day when we could lose the opportunity to homebuild and fly.
So my mission in life became to educate my fellow homebuilders and pilots
regarding what the regulations actually say with the hope and belief that
education would encourage compliance. That is why many of my postings read
the way they do.
4) "Additionally, 91.215 (c), does not apply as almost all of our airspace
is uncontrolled."
Let's see what 14 CFR definitions says:
"Controlled airspace means an airspace of defined dimensions within which
air traffic control service is provided to IFR flights and to VFR flights in
accordance with the airspace classification.
Note: Controlled airspace is a generic term that covers Class A, Class B,
Class C, Class D, and Class E airspace."
So as long as one is flying outside of the airspace identified in 91.215 (b)
(1) through (5) and outside the definition of controlled airspace then one
indeed does not need to have or operate a transponder.
Time: 07:10:22 PM PST US
Subject: RE: AeroElectric-List: Encoder Certification
Bakerocb,
not
Jon
Posted: Tue Jan 19, 2010 6:49 am Post subject: Encoder Certification |
OC,
As I read the regs. you quote below, it sounds like I am qualified to perform the tests.
| Quote: | "(b) The tests required by paragraph (a) of this section must be conducted by-
(1) The manufacturer of the airplane, or helicopter, on which the tests and inspections are to be performed;
I am the manufacturer of the airplane.
Steve Thomas
On Jan 18, 2010, at 9:11 PM, <bakerocb(at)cox.net> <bakerocb(at)cox.net> wrote:
1/18/2010
1) "Being able to do my own pitot-static check will also get me a long way to being able to discuss with some authority."
A) There is no regulatory requirement for a pitot system check, but you may gain some confidence in the accuracy of your airspeed indicator by performing one.
B) The static pressure system check performed in order to meet the requirements of 14 CFR 91.411 quoted here:
(a) No person may operate an airplane, or helicopter, in controlled airspace under IFR unless-
(1) Within the preceding 24 calendar months, each static pressure system, each altimeter instrument, and each automatic pressure altitude reporting system has been tested and inspected and found to comply with appendices E and F of part 43 of this chapter;"
Must be performed in accordance with the portion of 14 CFR 91.411 quoted here:
(2) A certificated repair station properly equipped to perform those functions and holding-
(ii) A limited instrument rating appropriate to the make and model of appliance to be tested;
(iv) An airframe rating appropriate to the airplane, or helicopter, to be tested; or
(3) A certificated mechanic with an airframe rating (static pressure system tests and inspections only)."
So only if you hold one of the qualifications listed above, would you be able to perform the regulatory requirement of the static pressure system tests. But otherwise, as you point out, performing the test yourself could help you in your discussions. The equipment and parameters to perform the test are described in 14 CFR Appendix E to Part 43 (a).
2) "Being able to calibrate my BMA EFIS ahead of time will be a giant step in the right
direction."
Good idea.
'OC' Says: "The best investment we can make is the effort to gather and understand knowledge."
Subject: Re: Re: Encoder Certification
direction.
Steve Thomas
Posted: Tue Jan 19, 2010 7:45 am Post subject: Encoder Certification |
At 08:47 AM 1/19/2010, you wrote:
OC,
conducted by-
Only one small caveat . . . manufacturers of
type certificated airplanes are expected/commanded
to jump lots of hoops not the least of which is
calibration traceability, proper equipment,
and training of persons tasked with operating
the equipment.
If one understands the physics, spirit and intent
of a pitot-static system check, it can be accomplished
with the most rudimentary of pressure measuring devices
(including a water manometer you might build up from
hardware store materials), a pump (can and often is
hand operated) and a calculator or set of charts that
converts observed pressures to observed panel readings.
Of course, the FIRST (and most common) dragon to
slay is leaks. This requires no calibration, only
the ability to apply a pressure, stop it off,
watch for changes, and then soap the joints looking
for bubbles . . . and finally, to see that panel
indications do not drift with time faster than
what's allowed. In other words, SOME degree of
leaking is permitted in some venues.
After the system is tight, then you need to
worry with the numbers. Not at all difficult
if you're interested in educating and equipping
yourself to the task . . . but convincing the
odd institutionally educated bureaucrat that
you KNOW what your doing is . . . well . . .
problematic.
It would be interesting to hear of your experience
in this endeavor. One thing that WOULD help is
to document the test procedure you use. If
pressures are read with a device subject
to calibration, then having a quality assurance
or cert document (not more than a year old) for that
device would be helpful. Or calibrate it yourself
using a water manometer. Fortunately, its
EASY to get a measuring tape with some assurance
of accuracy.
While we may all rightfully claim to be "the
manufacturer" of our projects, there may be a
price of membership for taking on that title.
