emaproducts(at)aol.com Guest
Posted: Sat Jan 16, 2010 9:42 pm Post subject: Static Ports |
Static ports
I have a KitFox drawing showing correct location for the Static port on the KitFox, don't remember just what version it is, but if person wanting info will write, I will dig it out!
If you don't have the static correct your airspeed can be up to 10 mph off, had one customer whose airspeed wouldn't get below 80 mph, finally found just a slight oil can in front of the static port causing a low pressure area over the area of the static port. This was on a Zenith 601 about 10 years ago. plane has over 600 hours on it now, still flying great.
Elbie Mendenhall EM Aviation,LLC
www.riteangle.com
| Quote: | Time: 09:23:50 AM PST US
Subject: Re: Airspeed Indicator reading low,
WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Pat Reilly
Posted: Sun Jan 17, 2010 1:03 pm Post subject: Static Ports |
What about just venting directly out of instrument to cabin pressure. I can't believe the pressure inside a KF is much different than outside. I know you would get different readings with doors open vs closed, but how much.
Pat Reilly
Mod 3 582 Rebuild
Rockford, OL
On Sat, Jan 16, 2010 at 11:38 PM, <emaproducts(at)aol.com (emaproducts(at)aol.com)> wrote:
Static ports
www.riteangle.com
Subject: Kitfox-List: Re: Airspeed Indicator reading low,
From: "dave" <dave(at)cfisher.com (dave(at)cfisher.com)>
arget="_blank">http://www.matronics.com/Navigator?Kitfox-List
ttp://forums.matronics.com
| [b]
dave
Posted: Sun Jan 17, 2010 4:22 pm Post subject: Re: Static Ports |
Pat -- this i why they read wrong................
you need a static port where the pressure really is static.
Read my post on how to check
[quote="Pat Reilly"]What about just venting directly out of instrument to cabin pressure. I can't believe the pressure inside a KF is much different than outside. I know you would get different readings with doors open vs closed, but how much.
Pat Reilly
Mod 3 582 Rebuild
Rockford, OL
On Sat, Jan 16, 2010 at 11:38 PM, <emaproducts> wrote:
| Quote: | �
Static ports
I have a KitFox drawing showing correct location for the Static port on the KitFox, don't remember just what version it is, but if person wanting info will write, I�will dig it out!
If you don't have the static correct your airspeed can be up to 10 mph off, had one customer whose airspeed wouldn't get below 80 mph, finally found just a slight oil can in front of the static port causing a low pressure area over the area of the static port.� This was on a Zenith 601 about 10 years ago.��plane has over 600 hours on it now, still flying great.
Elbie Mendenhall���� EM Aviation,LLC
www.riteangle.com
| [b] |
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
WurlyBird
Posted: Mon Jan 18, 2010 9:36 am Post subject: Re: Static Ports |
I fly primarily with my doors in the garage. I have tested with doors on and off and I can adjust airspeed by throwing the plane out of trim. It is more pronounced with the doors open but even with doors I can fluctuate speed about 10 mph. This is vented to the inside.
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Pat Reilly
Posted: Mon Jan 18, 2010 10:13 am Post subject: Static Ports |
James, Thanks for the info. One of the KF guru's says he vents with filters, directly to inside of cabin.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Mon, Jan 18, 2010 at 11:36 AM, WurlyBird <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)> wrote:
[quote]--> Kitfox-List message posted by: "WurlyBird" <james.t.trizzino(at)us.army.mil (james.t.trizzino(at)us.army.mil)>
James
Kitfox 3 / 582 / GSC prop
The ink is still drying on my new certificate
http://forums.matronics.com/viewtopic.php?p=282096#282096
ist Un/Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
