RV4WGH(at)aol.com Guest
Posted: Wed Apr 12, 2006 7:59 am Post subject: CIRCUIT BREAKERS |
I have a 55 Amp alternator and have been looking for a 60 or 70 Amp -
push-pull (on-off) circuit breaker. I assume one of those would be the appropriate
rating.
Anyone know of a source?
Wally Hunt
Rockford, IL
RV-4 Finishing Kit
Bruce(at)glasair.org Guest
Posted: Wed Apr 12, 2006 8:53 am Post subject: CIRCUIT BREAKERS |
Use a fuse link instead. If you pop a breaker that size do you really want
to reset it in flight?
Bruce
www.glasair.org
nuckollsr(at)cox.net Guest
Posted: Wed Apr 12, 2006 10:00 am Post subject: CIRCUIT BREAKERS |
the appropriate
rating.
I'd recommend you go to an ANL current limiter mounted
on the firewall and wired as described in the Z-figures.
If you absolutely must have a breaker, the right sized
(75 amp) is going to be a fat rascal.
Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Wed Apr 12, 2006 10:38 am Post subject: CIRCUIT BREAKERS |
Bruce,
I'm just trying to find a suitable B lead protection with the following
questions ... no foul intended, Bruce. Have you used a fuselink for the
purpose expressed below? What gage wire are you advocating to use with say,
a 10 AWG B lead from the alternator? The standards point to using four
gages smaller, or, 14 AWG. Is this what you are advocating to substitute
for say a 70A CB or 80A current limiter?
Thanks ...
Jerry Grimmonpre'
Bruce
www.glasair.org
appropriate
rating.
Wally Hunt
Rockford, IL
RV-4 Finishing Kit
Posted: Thu Apr 13, 2006 5:29 am Post subject: CIRCUIT BREAKERS |
At 01:36 PM 4/12/2006 -0500, you wrote:
Quote: |
Bruce,
When you say 10AWG b-lead feeder, I presume you're talking
about a SMALL alternator, like the SD20. Here you're talking
about fusible links on the same order as those used in automobiles
(14AWG). Yeah, that size b-lead/alternator combination is probably
a good candidate for fusible link . . . but under the cowl.
Quote: | The standards . . .
Let's be careful about what we label as "standards" . . . the fusible
links in automotive applications are common practice supported
by good science and practical experience. If we elevate the practice
to a "standard" then the next creep in concept will elevate it to a
regulation. There are roaming hoards of individuals constantly on the
lookout for things to elevate to regulatory status all in the name
of safety . . . and nobody is against being safer, right?
Quote: | . . . point to using four gages smaller, or, 14 AWG. Is this what you
are advocating to substitute for say a 70A CB or 80A current limiter?
Here's where we get a disconnect. A 10AWG/14AWG feeder-link combo
is in the 20-30A alternator class. If you're looking to replace
a 70A breaker, then we're talking 6AWG or 4AWG feeders and fusible
links are indeed impractical. Then the CB or current limiter becomes
hardware of choice. Since the b-lead protection does not benefit
from pilot access, a limiter is attractive. Know that limiters
have a VERY long and conservative operating time constant compared
with fuses. See:
http://aeroelectric.com/articles/anl/anlvsjjs.html
Note that a 100A limiter will carry 170A indefinitely
and that it's blowing time constant is much longer
than fuses. Breakers fall between fuses and limiters
with respect to sensitivity and speed.
Which b-lead are you wrestling with? An SD-20 or something
larger?
Jerry Grimmonpre'
Posted: Thu Apr 13, 2006 10:08 am Post subject: CIRCUIT BREAKERS |
Quote: |
<nuckollsr(at)cox.net>
My bad Bob ...
I erroneously labeled a 60A alt B lead with a 10 AWG and stared at for so
many days ... began to believe it as well. It deserves a 6 AWG ... correct
me if wrong. In this installation, would a 60A current limiter be OK since
the CL have an 80% over load rating?
Thanks for the link and your leadership, Bob ... that clears up alot.
Jerry Grimmonpre'
Posted: Thu Apr 13, 2006 4:33 pm Post subject: CIRCUIT BREAKERS |
My bad Bob ...
You're correct. An ANL 60 will be just fine on the b-lead
of a 60A alternator.
