JHearnsberger
Joined: 22 Dec 2009 Posts: 31 Location: Springhill, LA
Posted: Wed Jan 13, 2010 6:20 am Post subject: rear spar caps |
I clamped, marked, and cut the rear spar caps outside of my line using a band saw.
My cuts had a couple of gradual waves in them. I worked them out with an air belt sander and file by clamping the two pieces back to back to try to get them even.
It is not that big of a deal other than I would like to get as much insight as possible while starting out. The cut is not perfect, but will it be ok? Please see attached images.
Also, my air belt sander uses 60 to 120 grit belts. Is this fine enough for deburring aluminum?
574.36 KB |
17446 Time(s) |
708.09 KB |
17446 Time(s) |
597.26 KB |
17446 Time(s) |
Tim Olson
Posted: Wed Jan 13, 2010 6:34 am Post subject: rear spar caps |
The cuts are probably straight enough, but 60 and 120 grit is not
fine enough to do good deburring. Run those pieces over a
scotchbrite wheel until you see no nicks at all. They will
look mirror smooth.
Tim Olson - RV-10 N104CD
JHearnsberger wrote:
Kelly McMullen
Posted: Wed Jan 13, 2010 6:35 am Post subject: rear spar caps |
Follow up your sanding with a pass of the Scotchbrite wheel. It will get you a nice smooth finish. I wouldn't worry too much about your cut.
Kelly
40866, QB Wings/Fuse
On Wed, Jan 13, 2010 at 7:20 AM, JHearnsberger <jakehearnsberger(at)gmail.com (jakehearnsberger(at)gmail.com)> wrote:
[quote]--> RV10-List message posted by: "JHearnsberger" <jakehearnsberger(at)gmail.com (jakehearnsberger(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=281268#281268
http://forums.matronics.com//files/img_0107_114.jpg
http://forums.matronics.com//files/img_0108_237.jpg
http://forums.matronics.com//files/img_0109_150.jpg
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
Phil.Perry(at)netapp.com Guest
Posted: Wed Jan 13, 2010 6:45 am Post subject: rear spar caps |
Looks good. Just finish them off with a scotchbrite wheel.
I use a 1" wheel on a die grinder. Works great on those edges.
Phil
jcumins(at)jcis.net Guest
Posted: Wed Jan 13, 2010 9:51 am Post subject: rear spar caps |
Jake those look just fine. You will find you will get the cut and finish
next to the fine line skills will come back fast. Kind of like coloring
book skills as a kid. What helps me get a nice straight edge is I use a 12
in disk sander that is mounted on my shop smith. With the table 90 degrees
to the sanding disk I get a nice clean straight and square edge on material
I am trying to make.
Check Harbor Freight for a cheap table top 8-10 in disc sander there worth
every penny.
John G. Cumins
40864 Emp in primer mode
JHearnsberger
Posted: Wed Jan 13, 2010 1:06 pm Post subject: Re: rear spar caps |
Thank you.
Albert Gardner
Posted: Wed Jan 13, 2010 1:32 pm Post subject: rear spar caps |
Early on in building I was advised to get a roll of the 3" wide adhesive
backed sand paper usually sold in auto supply houses. You can stick it to
most anything, a socket for small radis, a section of PVC pipe for larger, a
form you cut from wood for the windshield lower fairing, or a short section
of 2x4. Most useful to me was 80 and 220. A long roll was about $33 as I
recall and I used about half a roll in building. Also you might look at a
vixen file.
Albert Gardner
N991RV
Yuma, AZ
_________________ RV-9A N872RV
RV-10 N991RV |
JHearnsberger
Posted: Wed Jan 13, 2010 3:07 pm Post subject: Re: rear spar caps |
What type of scotchbrite wheel? Is it the rolec pad? I am looking for something to attach to my die grinder. Also, what grit?
Sent from my iPhone.
jeff(at)westcottpress.com Guest
Posted: Wed Jan 13, 2010 3:30 pm Post subject: rear spar caps |
3M SCOTCH-BRITE DEBURRING WHEEL from Aircraft Spruce
[/url]
[url=http://forums.matronics.com/viewtopic.php?p=281348#281348]http://forums.matronics.com/viewtopic.php?p=281348#281348
- The RV10-List --> &n========================
JHearnsberger
Posted: Wed Jan 13, 2010 4:35 pm Post subject: Re: rear spar caps |
I think I would prefer to use it in a bench grinder. Does anyone have any recommendations for a good bench grinder to use with the scotchbrite wheel?
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=39797
Jake
Kelly McMullen
Posted: Wed Jan 13, 2010 7:13 pm Post subject: rear spar caps |
One of the easier ways to use a large Scotchbrite wheel is to mount it in a drill press, and just run the pieces over it. Leaves both hands free to manipulate/control the piece being deburred. Easier to install and remove than in a bench grinder. For large/ long pieces, like skins, a small scotchbrite wheel in a die grinder or hand drill works fine.
On Wed, Jan 13, 2010 at 5:35 PM, JHearnsberger <jakehearnsberger(at)gmail.com (jakehearnsberger(at)gmail.com)> wrote:
[quote] --> RV10-List message posted by: "JHearnsberger" <jakehearnsberger(at)gmail.com (jakehearnsberger(at)gmail.com)>
Jake
http://forums.matronics.com/viewtopic.php?p=281359#281359
le, List Admin.
KCHD |
Kelly McMullen
Posted: Wed Jan 13, 2010 7:38 pm Post subject: rear spar caps |
I forgot to mention, generally you will get smoother results if the piece is parallel to the rotating wheel, not the axis it is rotating about. That is why the wheel on horizontal axis with shaft vertical works well with long pieces held horizontal.
On Wed, Jan 13, 2010 at 8:11 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote] One of the easier ways to use a large Scotchbrite wheel is to mount it in a drill press, and just run the pieces over it. Leaves both hands free to manipulate/control the piece being deburred. Easier to install and remove than in a bench grinder. For large/ long pieces, like skins, a small scotchbrite wheel in a die grinder or hand drill works fine.
| Quote: | --> RV10-List message posted by: "JHearnsberger" <jakehearnsberger(at)gmail.com (jakehearnsberger(at)gmail.com)>
Jake
le, List Admin.
KCHD |
JHearnsberger
Kelly McMullen
Posted: Wed Jan 13, 2010 8:49 pm Post subject: rear spar caps |
Most of the tool kit suppliers include a large wheel as part of their
kits and sell separately. They aren't cheap, but one should do you for
the entire build process.
On Wed, Jan 13, 2010 at 9:14 PM, JHearnsberger
<jakehearnsberger(at)gmail.com> wrote:
What a great tip! Thank you.
I found the 7a wheels here http://solutions.3m.com/wps/portal/3M/en_US/Manufacturing/Industry/Product-Catalog/Online-Catalog/?PC_7_RJH9U5230GE3E02LECFTDQGLE0_nid=8ZFZHRFX71beH55CPWS904gl
I am hoping I can find it locally somewhere.
http://forums.matronics.com/viewtopic.php?p 81387#281387
KCHD |
Strasnuts
Joined: 10 Feb 2009 Posts: 502 Location: Salt Lake City, UT
Posted: Wed Jan 13, 2010 9:24 pm Post subject: rear spar caps |
They are around 50$ I am 99 percent done with the aluminum parts and
I'm on number three??? I know other builders that just used one or two
On Jan 13, 2010, at 21:46, Kelly McMullen <apilot2(at)gmail.com> wrote:
_________________ 40936
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours |
Posted: Wed Jan 13, 2010 11:11 pm Post subject: rear spar caps |
Though the scotch-brite wheel is very useful, I ultimately found that skins and long parts that were difficult to get to the wheel were easily deburred with a large vixen file run a few times along an edge at different angles. It's also pretty easy to overwork a part with the scotch-brite wheel
Jeff Carpenter
40304
Yearning for the good old days of metal work... when fiberglass was far off in the future
On Jan 13, 2010, at 3:29 PM, Jeff Carpenter wrote:
[quote]3M SCOTCH-BRITE DEBURRING WHEEL from Aircraft Spruce
[/url]
deej(at)deej.net Guest
Posted: Thu Jan 14, 2010 6:45 am Post subject: rear spar caps |
On 01/13/2010 07:35 PM, JHearnsberger wrote:
I'm using one of these el cheapo $40 ones - works fine, price is right,
and it comes with a polishing wheel.
<http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=43533>
Replacement wheel kits are cheap $6:
<http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=43758>
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Grumman Yankee Driver N9870L - http://deej.net/yankee/
MauleDriver(at)nc.rr.com Guest
Posted: Thu Jan 14, 2010 7:14 am Post subject: rear spar caps |
| Quote: | Though the scotch-brite wheel is very useful, I ultimately found that
The vixen file seems to be the ideal tool for dressing the edges of
tail/wing skins. I had no idea what it was or how to use it but I
described what I found out in a post - search the archives for 'Vixen'
and look for my post (I can't find the supporting pics). A very useful
tool and very basic technique for skin deburring. Very productive.
I found that the scotchbrite wheel in a floor mounted bench grinder to
be by far the tool I use the most. Still do. I'm on my second wheel at
3+ years of a 4 year QB. The drill press thing sounds good - never
thought about the axis thing but I wouldn't want to have to mount and
de-mount it all the time. On the bench grinder, I first had a coarse
and fine wheel - found just the coarse is fine. Mounted a regular
grinding wheel in the other for the little bits of steel work we do.
The little SB wheel in the die grinder is very handy when needed too.
Have worn one out, on number 2. I used Avery's 3700 but I think I got
it from Cleaveland:
http://www.averytools.com/pc-351-43-scotch-brite-cutting---polishing--wheel--kit.aspx
Tim Olson
Posted: Thu Jan 14, 2010 7:51 am Post subject: rear spar caps |
You can't beat the die grinder wheels for doing the inside of those
lightening holes. I went through about 5 or 6 of them over the
whole build, but used them a lot. I bought 2 large wheels for
my grinder, and one is pretty worn, the other is worn some. So
1.5 or so did my whole project. If I start another kit, I'll
buy one more big wheel, maybe put one of my grinder ones onto
a drill press, and buy a few more die grinder wheels. That's
some of the nicest deburring you can get.
Bill Mauledriver Watson wrote:
<MauleDriver(at)nc.rr.com>
it from Cleaveland:
Dick Sipp
Posted: Thu Jan 14, 2010 11:25 am Post subject: rear spar caps |
Another good technique for edge dressing is called "draw filling" wherein a
standard fine file is turned 90 degrees or perpendicular to the work and
dragged lightly alone the work edge. Like others have said the edge still
needs to be "polished" with a de-burring wheel of some kind.
Dick Sipp
N110DV 210 hours
