sapril001(at)hotmail.com Guest
Posted: Wed Jan 13, 2010 2:39 am Post subject: MurphyMoose-List Digest: 3 Msgs - 01/12/10 |
Hi C
I ram my moose radial without the wings C you must make sure your fuselage it is well attached because this engine is pulling really hard.
Sylvain April
[quote] Date: Tue C 12 Jan 2010 23:56:51 -0800
To: murphymoose-list-digest(at)matronics.com
Subject: MurphyMoose-List Digest: 3 Msgs - 01/12/10
Today's complete MurphyMoose-List Digest can also be found in either of the
of the MurphyMoose-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter=2010-01-12&Archive=MurphyMoose
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter=2010-01-12&Archive=MurphyMoose
MurphyMoose-List Digest Archive
Total Messages Posted Tue 01/12/10: 3
Today's Message Index:
1. 02:45 PM - Re: Murphy Moose (HBaker)
2. 04:09 PM - Re: Re: Murphy Moose (Greg Young)
3. 04:51 PM - Re: Re: Murphy Moose (Jeff Micheal)
Time: 02:45:44 PM PST US
Subject: Re: Murphy Moose
Hi Jeff
Getting ready to start the engine C can this be done with out the wings attached
to the A/C.
Henry
Moose 294
Currently building a Murphy Moose - any help would be appreciated.
http://forums.matronics.com/viewtopic.php?p=281207#281207
Time: 04:09:31 PM PST US
Subject: RE: Re: Murphy Moose
I'm not sure how stabile the Moose is but there's a video floating around
the web of a Lancair IV that started his engine sans wings. He wrapped it in
a ball. Why risk it?
Regards C
Greg Young
| - The Matronics MurphyMoose-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?MurphyMoose-List |
dstroud(at)xplornet.com Guest
Posted: Wed Jan 13, 2010 3:43 am Post subject: MurphyMoose-List Digest: 3 Msgs - 01/12/10 |
Hello, Sylvain. Any chance you may have a fuel system diagram you could let me have
a copy of, please ? I need to understand everything forward of the gascolator including
any fuel returns to main tank(s) and electric boost pump. Thank you.
David Stroud Ottawa, Canada
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
jwill3638(at)aol.com Guest
Posted: Wed Jan 13, 2010 4:02 am Post subject: MurphyMoose-List Digest: 3 Msgs - 01/12/10 |
Murphy started their M14P Moose behind the factory tied to a fork lift. They had a video on the web site for a while.I ran mine for a couple hours tied to a John Deer. No wings. Jim Williams.
george(at)gesoco.com Guest
Posted: Wed Jan 13, 2010 11:57 am Post subject: MurphyMoose-List Digest: 3 Msgs - 01/12/10 |
I have to comment on the fuel system design for the Moose.There has been at least one accident that can be traced to a poor fuel system design. When designing the fuel system please bear in mind that the pressure carburetor is like a throttle body injection system. there is no float bowl or and storage of fuel in the carburetor. One drop of air and it is like turning the magnetos to the OFF position until the air is worked through the engine. Worse yet if there is a slug of air it can cause the mechanical fuel pump to cavitate and the fuel pressure to drop. It is called a pressure carb because it requires fuel pressure to work. No pressure and no fuel. It is rather instantaneous. We highly recommend a vapor return system as part of your fuel system. It allows fuel to be returned to the header or main tank. Another gotcha is a partial loop with a horizontal section of the fuel line between the pump and the carburetor. This is often done to accommodate a fuel flow sensor. It can trap a bubble of air that will move along to the carb when the aircraft changes pitch and or at high power settings. (Like take Off). The Yaks use a system with a return line with a restrictor in it . This allows the pump to maintain fuel pressure while allowing for a fuel return path for any vapors or air.
George Coy
Motorstar NA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com (george.coy(at)gmail.com)
SKYPE george.coy
motorstarna.com
From: owner-murphymoose-list-server(at)matronics.com [mailto:owner-murphymoose-list-server(at)matronics.com] On Behalf Of DAVID STROUD
Sent: Wednesday, January 13, 2010 6:43 AM
To: murphymoose-list(at)matronics.com
Subject: Re: RE: MurphyMoose-List Digest: 3 Msgs - 01/12/10
Christavia C-FDWS
