Posted: Mon Jan 11, 2010 7:25 pm Post subject: Electronic Dead Reckoning Distance Calculator |
At 09:47 AM 1/11/2010, you wrote:
Bob,
Thanks for your comments. I am really proud of this project, but did
not expect many replies because GPS has made dead reckoning
obsolete. You and another friend suggested using a PIC
micro-controller. Unfortunately I know very little about them. I
understand that a programmer is required. It was fun learning how to
program the CD74HC4059 counter-divider. Learning how to program a
PIC micro-controller should be fun too.
There's a ton of pic development systems out there
for under $100, dozens for under $50. You might
think about subscribing to Nuts and Volts magazine
http://www.nutsvolts.com/
Their advertisers include a number of hobbyist PIC
systems to get started with. The one we use here is
only $29 and comes with an exceedingly capable editor,
assembler package. I think it's the PicKit II. You can
go the assembler route (I think there's only 35 instructions
to learn how to use) or the Tiny Basic round offered in
the Basic Stamp series systems . . . and others.
http://www.parallax.com/
http://www.parallax.com/Resources/GettingStarted/tabid/270/Default.aspx
There are programmers listed on eBay from $15 to over $200. Does
anyone have a suggestion on which one to buy?
This one is $100 but probably your best bet to get
up and running quickly in Tiny Basic or Assembler
http://tinyurl.com/yfxgka4
See also:
http://www.mstracey.btinternet.co.uk/pictutorial/picmain.htm
http://tutor.al-williams.com/pic-intro.html
http://www.hobbyprojects.com/microcontroller_tutorials.html
I want to build a capacitance to voltage converter for a fuel
gauge like this:http://www.rstengineering.com/kitplanes/KP0007/KPsch.jpg
Can a PIC micro-controller replace much of that circuit?
Oh my, yes. I've been halted on a program to do just that.
The program manager ran out of money. It might come back
in the spring . . .
The philosophy I'm using alternately charges the
tank capacitance through a large value resistor
and discharges it with a transistor. The time it takes
to charge the capacitor from zero to some reference
value is measured by the uP. Every other charge/discharge
cycle, a 100 pf reference capacitor is switched across the
tank line and the time to charge total capacitances is
measured.
By having a reference capacitor, calculation of tank
+ wiring capacitance is a simple ratio that wipes out
errors in charging current or comparator trip voltages.
System accuracy is dependent only on stability of
the reference capacitor and timing accuracy of the uP
(crystal controlled).
I can't offer you anything more than that right
now but I can assure you it's well within the capability of
the PICs to do the timing, operating the capacitor
switch and calculating a PWM output value that
represents % of tank contents. What's more, the
total parts count is VERY low.
pmather
Posted: Tue Jan 12, 2010 1:04 am Post subject: Electronic Dead Reckoning Distance Calculator |
Unless you need very fast program response look at www.picaxe.co.uk. The
chips are available worldwide.
These are pic chips pre-programmed with a basic interpreter and need nothing
more than two resistors and a serial cable to connect to a PC and program.
The software for the PC is completely free.
The support on the forum www.picaxeforum.co.uk is fantastic and the chips
have i2c, pwm, etc. capability all available in the interpreter
I can and do use PICs directly programmed in C /assembler using various
programmers but for quick prototyping and many applications the picaxe can
not be bettered
best regards
Peter
From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
To: <aeroelectric-list(at)matronics.com>
Sent: Tuesday, January 12, 2010 3:22 AM
Subject: Re: Re: Electronic Dead Reckoning Distance
Calculator
<fran4sew(at)banyanol.com>
Bob,
Thanks for your comments. I am really proud of this project, but did not
expect many replies because GPS has made dead reckoning obsolete. You and
another friend suggested using a PIC micro-controller. Unfortunately I
know very little about them. I understand that a programmer is required.
It was fun learning how to program the CD74HC4059 counter-divider.
Learning how to program a PIC micro-controller should be fun too.
There are programmers listed on eBay from $15 to over $200. Does anyone
See also:
I want to build a capacitance to voltage converter for a fuel gauge like
in the spring . . .
measured.
Posted: Tue Jan 12, 2010 12:14 pm Post subject: Electronic Dead Reckoning Distance Calculator |
At 08:38 AM 1/12/2010, you wrote:
To Peter, Bob, Ken, Ed,
I know that I can build that capacitance-to-voltage-converter
fuel-gauge circuit designed by Jim Weir using discreet parts that
do not cost very much. Using a PIC microcontroller will cost more
in both time and money to purchase the programmer and to learn how
to use it. On the other hand, new technology is exciting and it
will be fun to learn a new skill that can be used for future
projects. Thanks for your suggestions and advice.
Certainly going the discrete component route has some
educational value . . . as I mentioned, I have plans
for my grandsons to sling a little solder over some
vacuum tubes. I've looked at the schematic in Jim's
article. It's not clear to me that it even works.
There are two oscillators . . . U101A and U101C
who's frequency is set by hysteresis (resistor network
on the minus terminal) and the RC time constant of
network on the plus terminal.
The frequency of the lower oscillator is fixed.
The frequency of the upper oscillator is affected
by the 360 pF variable which I presume is tank
+ wiring capacitance. The output of both oscillators
is fed to positive peak following integrators and
then applied to a differential amplifier and finally
to a gain stage U102B. Offset and gain potentiometers
are provided in the DC gain stages.
It appears that the circuit depends on a DIFFERENCE
in relative duty cycle of the two oscillators. While
they differ from each other in frequency, their duty
cycles will be close to 50% irrespective of frequency.
The stages at U101B and U101D are not frequency
discriminators. I'd like to enlist the assistance
of other electron-herders on the list to confirm
or correct my dissection of this circuit's functionality.
If you're up to the task for conducting the experiment,
you might consider this schematic:
http://aeroelectric.com/Pictures/Schematics/Fuel_Capacitance_Meter.pdf
This circuit was crafted to generate a variable
DUTY CYCLE as tank sensor capacitance changes.
Like any analog circuit, calibration stability
is subject to the sum total of effect contributed
by every nearly every component in the system.
This circuit was never built but it was analyzed
for component effects on the system error budget.
It's possible to build a practical fuel gage but
falls short of the best we know how to do. This
is why I move off to the processor-based design
I described earlier . . . parts count and effects
of those parts on calibration and drift are a
TINY fraction of the analog.
Let's see if anyone else on the List can confirm
that the Kitplanes article fuel gage can be expected
to meet design goals.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
