nuckollsr(at)cox.net Guest
Posted: Thu Apr 13, 2006 4:35 am Post subject: Current Limiter On The Aft Side of Firewall |
At 02:31 PM 4/12/2006 -0500, you wrote:
<snip>
Quote: | >
> What system needs a higher fuse value than 15A?
The endurance bus feed is planned to be tapped off the hot battery bus
through a fuse similar to Z12. The endurance bus will be running about
22A. It seems this feed wire needs to be moved to the hot battery bus lug.
Should this be done and what method of wire protection should be used with
this source of power for the endurance bus?
Understand on locations. How does the e-bus load get so high?
