JHearnsberger
Joined: 22 Dec 2009 Posts: 31 Location: Springhill, LA
Posted: Thu Jan 07, 2010 11:57 am Post subject: Can I use this? |
Can I use rust-oleum automotive primer? I understand that everyone has opinions and primer preferences. I just want to know if this will do the job and hold up.
7.81 KB |
17158 Time(s) |
deej(at)deej.net Guest
Posted: Thu Jan 07, 2010 12:27 pm Post subject: Can I use this? |
On 01/07/2010 02:57 PM, JHearnsberger wrote:
I'm using an automotive primer, which might be similar to what you are
asking about. So far, so good. I have 4+ year old parts with it on it
and it seems to be holding up okay. Still building, though. I've found
that you need to let it sit at least a couple of days to let it harden
enough to work with the pieces after priming, otherwise it can scratch
easily. Of course, it is just as easy to put a squirt over it once
you've done to cover up any marks you might have made on it while
riveting, etc.
You can get it from two sources (same product, branded two ways):
<http://www.sherwin-automotive.com/products/show_product.cfm?product=988>
<http://www.napaonline.com/Search/Detail.aspx?R=MSR7220_0006419503>
fyi
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Grumman Yankee Driver N9870L - http://deej.net/yankee/
Phil.Perry(at)netapp.com Guest
Posted: Thu Jan 07, 2010 12:36 pm Post subject: Can I use this? |
I'm using it only with Alodine underneath. The product doesn't have any
chromates to prevent corrosion, so it basically serves as an barrier
between metal surfaces and moisture/air. I'd like to treat the aluminum
with a preventative chemical, so that's the reason I alodine underneath.
Generally speaking though, I'm using a higher-end primer (Dupont
Variprime). I only use the Alodine/Rust-oleum combo on pieces that are
too small to justify a batch of Variprime and the effort to clean
everything up.
Phil
Posted: Thu Jan 07, 2010 12:54 pm Post subject: Can I use this? |
Hey DJ..
Try sitting the pieces in front of a space heater. No need to get them
hot, just warm for a while.
It'll setup quickly and be hard as nails. Then you can build on.
Posted: Thu Jan 07, 2010 1:01 pm Post subject: Can I use this? |
Any primer is better than no primer, but I think you will be disappointed
with a non-sealing primer like the one you suggest.
Considering the prep is the same, and is the majority of the work, why not
use something worthwhile? A quality epoxy primer like PPG DP40LF is
exceptionally durable and easy for the amateur painter. It is widely
available at automotive paint suppliers.
Carl Froehlich
RV-8A (525 hrs)
RV-10 (systems)
Posted: Thu Jan 07, 2010 1:15 pm Post subject: Can I use this? |
On 01/07/2010 03:47 PM, Perry, Phil wrote:
| Quote: | Try sitting the pieces in front of a space heater. No need to get them
Thanks! Nice tip.
I don't yet have heat in my shop, but I'm almost finished with
installing a propane heating system. It is mounted, vented, and wired,
and now I just need to get the propane company out to install the
propane lines and tank, and then check everything. Hopefully soon! It
gets slightly chilly here in Maine this time of year...
-Dj
Dj Merrill - N1JOV
jcumins(at)jcis.net Guest
You want to use a acid etching primer unless you want to acid etch first
them alodine then prime. Napa has a Acid Etching primer that is in rattle
can and works well. There are numerous ones on the market I went with the
Napa one and it works just fine.
John G. Cumins
40864
Emp in priming mode and yes I won the primer war
partner14
Posted: Thu Jan 07, 2010 1:40 pm Post subject: Can I use this? |
Bottom line: Don't sweat it, almost anything is better than nothing... and if you keep the plane inside the vast majority of the time,,,, nothing is just fine. Unless, of course, you want your son to be able to give the plane to his son.
Don McDonald
--- On Thu, 1/7/10, Perry, Phil <Phil.Perry(at)netapp.com> wrote:
Subject: RE: Can I use this?
Date: Thursday, January 7, 2010, 12:47 PM
--> RV10-List message posted by: "Perry, Phil" <Phil.Perry(at)netapp.com (Phil.Perry(at)netapp.com)>
Hey DJ..
40636 |
Posted: Thu Jan 07, 2010 8:03 pm Post subject: Can I use this? |
Cold in Maine??
Check out tomorrow’s Houston forecast compared to Base Orcadas, Antarctica. J
-Dj
15.96 KB |
17098 Time(s) |
17.7 KB |
17098 Time(s) |
Bob Turner
Posted: Thu Jan 07, 2010 9:52 pm Post subject: Re: Can I use this? |
Of course, it's mid-summer in Antarctica. What was Houston like on July 7th?
_________________ Bob Turner
RV-10 QB |
JHearnsberger
Posted: Fri Jan 08, 2010 6:23 am Post subject: Re: Can I use this? |
| Quote: | You want to use a acid etching primer unless you want to acid etch first
John G. Cumins |
Do you not have to use alodine if you go the acid etching primer route?
tsts4
Posted: Fri Jan 08, 2010 6:33 am Post subject: Re: Can I use this? |
No, but understand what each chemical does. Acid etching's purpose is to roughen (and to lessor degree clean) the surface to provide better mechanical adhesion of the primer. Alodine is a conversion coating that provides corrosion protection by replacing the oxide layer (ie the ALCLAD layer) that typically gets removed either by scratches and/or dings or through the prepping process for priming.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
JHearnsberger
Posted: Fri Jan 08, 2010 6:54 am Post subject: Re: Can I use this? |
What does Alumiprep do? Is this necessary?
pietflyr(at)bellsouth.net Guest
Posted: Fri Jan 08, 2010 7:31 am Post subject: Can I use this? |
Alumiprep is a phosphoric acid etch. It works best if the parts are cleaned
with a good dishwashing soap and water first, rinsed, then dipped in
Alumiprep for about 3 minutes, then rinsed with cold water. The etched
surface should be primed or alodined within 8 hours.
Jack Phillips
#40610 - Wings
Raleigh, NC
johngoodman
Posted: Fri Jan 08, 2010 7:34 am Post subject: Re: Can I use this? |
If it contains chromates or MEK, you don't want it anywhere near your skin, eyes, or nose.
JHearnsberger
Posted: Fri Jan 08, 2010 7:48 am Post subject: Re: Can I use this? |
Ok, I give up. I will do it right. I was looking for the easy way out.
Tell me what all to order. Alumiprep, Alodine, paint sprayer, etc....
Just not the most expensive products. I don't want to break the bank.
Posted: Fri Jan 08, 2010 7:52 am Post subject: Can I use this? |
I use a Alumiprep (PPG product) to clean aluminum parts prior to priming.
This is about as easy as it gets. Mix the Alumiprep about 4 to 1 with
water, use a red Scotch Brite pad with the Alumiprep on the parts to clean
them, rinse with water, let dry then prime with a good sealing epoxy primer
like PPG DP40LF. The first parts I primed on my 8A are now 11 years old and
still look the same as the day I primed them.
Carl Froehlich
RV-8A (525 hrs)
RV-10 (systems install)
johngoodman
Posted: Fri Jan 08, 2010 7:57 am Post subject: Re: Can I use this? |
I'm leaving most of the aluminum in shiny Alclad, because I plan on using Corrosion-X once it's painted & flying. However, there are always worked over pieces that need some primer. I use a rattle can of Napa 7220, which is one of many brands of self-etching primer out there. It contains MEK, so I wear long sleeve shirts, nitrile gloves, and a real respirator with ventless goggles.
Posted: Fri Jan 08, 2010 8:10 am Post subject: Can I use this? |
On 01/08/2010 10:48 AM, JHearnsberger wrote:
There really isn't one "right" answer. All I do is clean the part with
Denatured Alcohol using an old toothbrush, wipe it down with a rag and
let it dry, and then spray it from the can of Sherwin Williams 988 (also
Napa 7220) self etching primer. This works well for me, and the primer
is still adhering well to parts that I applied it to over 4 years ago.
This was the "easiest" method of priming for me, but the other methods
work well too, and you might find one of them even easier.
Short answer, it doesn't matter what you put on, just put something on
and you'll be fine.
-Dj
Dj Merrill - N1JOV
