rvdave
Posted: Thu Jan 07, 2010 8:30 pm Post subject: headliner finishing |
I'm actually in the planning stages of headliner material/finishing and wondering how to finish the edges around windows and edges of doors, etc. What are some of the methods/materials used instead of just a cut edge?
_________________ Dave Ford
Cadillac, MI |
MauleDriver(at)nc.rr.com Guest
Posted: Thu Jan 07, 2010 8:41 pm Post subject: headliner finishing |
Flightline apparently has an edging material for their headliner
material. Just talked to them today.
rvdave wrote:
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p 80620#280620
tsts4
Posted: Fri Jan 08, 2010 5:02 am Post subject: Re: headliner finishing |
I was over at Carl Froehlich's house just last week and he showed me some nifty window closeout rings he made himself out of fiberglass. They seem simple enough to make so that's the route I'm going to take, at least for the windows.
_________________ Todd Stovall
aka "Auburntsts" on EAA and VAF
RV-10 N728TT -- Flying |
aerosport1
Posted: Fri Jan 08, 2010 6:42 am Post subject: headliner finishing |
Dave I made my own headliner out of 2 layers of 6oz fiberglass cloth. I
finished the cabin top in the area I wanted the headliner to go to a
Semi smooth finish. I waxed up the cabin top and PVA released it. 2 layers
of 6oz cloth that I trimmed exactly to my window cutouts which were cut and
trimmed to size. Trimmed head liner to size and fit and covered with auto
headliner material. I then put rubber edge trim on window opening. These
Velcro in and work great. I had about 6hrs total in the headliner pieces
from start to finish. They trim out the window really nice. It took longer
to finish the cabin top out then the headliner parts. You still need to do
some finish on the cabin top no matter which way you go.
FWIW Geoff
Geoff Combs
President
Aerosport Modeling & Design
8090 Howe Industrial Parkway
Canal Winchester, Ohio 43110
614-834-5227p
614-834-5230f
www.aerosportmodeling.com
50.29 KB |
5503 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033 |
johngoodman
Posted: Fri Jan 08, 2010 7:40 am Post subject: Re: headliner finishing |
I bought the complete RV-10 package from Flightline Interiors. It comes with a cord-like closeout that you attach with Gel rubber cement.
coop85(at)verizon.net Guest
Posted: Fri Jan 08, 2010 8:45 am Post subject: headliner finishing |
I used the flightline interiors and really like it overall. The edging
looks great, however make sure you use the gel cement (I couldn't find any
and suspect that contributed to my problems). Also the material seems to
shrink a little over time so mine pulled away from the window and I get to
redo it when I get the time. I think really pushing it in all the way
around the window making sure there is excellent contact all the way around,
along with the right glue, will help prevent the issues I and apparently
others have had.
Marcus
40286
rvdave
Posted: Fri Jan 08, 2010 7:27 pm Post subject: Re: headliner finishing |
| aerosport1 wrote: | Dave I made my own headliner out of 2 layers of 6oz fiberglass cloth. I
FWIW Geoff
Geoff, I don't quite understand about the fiberglass cloth but what kind of rubber edge trim did you use? It looks great and seems to match the Mcmaster Carr window seal. Also does your cloth fit under the door seals?
Dave
Cadillac, MI |
