Posted: Wed Jan 06, 2010 2:06 pm Post subject: List decorum |
At 12:55 PM 1/6/2010, you wrote:
P.S. You probably didn’t read the part of my last comment (the only in which I didn’t panic) when I said I built and fly one airplane with fuses, one airplane with circuit breakers, and the one I’m currently finishing building have both. Don’t loose your time, just hit the delete button
| Quote: | May I suggest
that you finish building your aircraft, using resettable circuit
breakers, since this gives you a greater comfort
level.[/b] [/b]
Roger[/b]
Gentlemen, this isn't about "superiority" of anything over
anything else. It's about meeting design goals for what
we hope will be a failure tolerant system understood by
the pilot and sufficiently fitted to meet the missions
for which the airplane is built.
The pantry of electro-goodies that can be stirred into
a host of recipes for success is huge. Just because any
one of us has a preference over one ingredient vs. another
should not be taken as an invitation to cast disparaging
remarks.
The mission for each of us on the List is to offer/acquire
understanding of how each ingredient functions in
particular situations . . . and not to suggest that anyone
has made a poor choice EXCEPT where we perceive a risk
for not achieving failure tolerance . . . even if the
"preferred" system is heavier, costlier, perhaps more
complex, or uses breakers.
We have a number of folks putting Z-14 into two-place
airplanes with missions that will never tax the system's
ability to mitigate risk. At the same time, for
each individual on the List who has expressed an interest
in exploring the possibilities, there are many, Many,
MANY more who are wiring their airplanes like a 1969
C-172. Are those folks at extra-ordinary risk for a bad
day in the cockpit? No, a modern alternator, active notification
of LV, modern RG battery and a purpose-driven battery
maintenance program makes them 10x better off than we
were in 1950 with generators and lead-acid slop-pots.
The OBAM aviation community, indeed all of light aircraft GA
is under incremental, relentless attack to simply go away.
Our collective future is best served by helping every
OBAM aircraft builder generate and meet design goals consistent
with the best we know how to do . . . while accommodating their
preferences.
Bob . . . [quote][b]
Posted: Thu Jan 07, 2010 4:26 am Post subject: List decorum |
Ditto!
Carlos
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Sent: quarta-feira, 6 de Janeiro de 2010 22:04
Subject: List decorum
P.S. You probably didnt read the part of my last comment (the only in which I didnt panic) when I said I built and fly one airplane with fuses, one airplane with circuit breakers, and the one Im currently finishing building have both. Dont loose your time, just hit the delete button
| Quote: | | May I suggestthat you finish building your aircraft, using resettable circuitbreakers, since this gives you a greater comfortlevel. |
remarks.
preferences.
Bob . . . | Quote: | | that you finish building your aircraft, using resettable circuit | 0 | Quote: | | that you finish building your aircraft, using resettable circuit | 1 | Quote: | | that you finish building your aircraft, using resettable circuit | 2 | Quote: | | that you finish building your aircraft, using resettable circuit | 3 | Quote: | | that you finish building your aircraft, using resettable circuit | 4 | Quote: | | that you finish building your aircraft, using resettable circuit | 5 | Quote: | | that you finish building your aircraft, using resettable circuit | 6 | Quote: | | that you finish building your aircraft, using resettable circuit | 7 | Quote: | | that you finish building your aircraft, using resettable circuit | 8 | Quote: | | that you finish building your aircraft, using resettable circuit | 9 | Quote: | | breakers, since this gives you a greater comfort | 0 | Quote: | | breakers, since this gives you a greater comfort | 1 | Quote: | | breakers, since this gives you a greater comfort | 2 | Quote: | | breakers, since this gives you a greater comfort | 3 | Quote: | | breakers, since this gives you a greater comfort | 4 | Quote: | | breakers, since this gives you a greater comfort | 5
mrspudandcompany(at)veriz Guest
Posted: Thu Jan 07, 2010 5:24 am Post subject: List decorum |
| Quote: | | May I suggestthat you finish building your aircraft, using resettable circuitbreakers, since this gives you a greater comfortlevel. Roger |
remarks.
Bob . . . | Quote: | | The above statement was NEVER said to “cast disparaging remarks”. It was only to encourage that we stop the back and forth of the same statements, “beating the dead horse”, and move on with our learning/teaching process. I honestly believe that if he feels more comfortable with circuit breakers, then he should install them! Roger |
Posted: Thu Jan 07, 2010 6:03 am Post subject: List decorum |
| Quote: | The above statement was NEVER said to
install them!
[/b] |
Which is exactly what he will do with or
without anyone's encouragement. The
"disparaging remark" reference went to
someone's suggestions that perhaps he
"shouldn't be a pilot".
As for beating a dead horse . . . this is
a classroom of 1800+ students and teachers
at last count. We need to keep in mind that
while conversations between individuals may
have been discussed many times in the past,
folks who read them today may have been on
the List a short time.
If we can't make the newbies feel welcome
and well informed then we degrade into
a club of elites that discusses only "new"
topics. The delete button works the same
way on everybody's computer and nobody is
being forced to participate in any conversation.
If anyone is weary of a review of old topics,
they can certainly start a thread on any new
topic of their choice.
dan(at)familybrown.org Guest
Posted: Thu Jan 07, 2010 6:37 am Post subject: List decorum |
Quoting "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>:
| Quote: | "disparaging remark" reference went to
That would be me, and I'm sorry they were taken as disparaging.
Having never met Mr. Trigo, I certainly have no grounds to question
his abilities as a pilot. The questions he was posing, though, (which
I took as hypothetical) sounded very panicky, and such a panicked
reaction to losing only one radio doesn't seem consistent with good
ADM. I was intending to address the hypothetical response he posed; I
didn't (and don't) assume that he would actually respond that way.
Dan Brown, KE6MKS, dan(at)familybrown.org
"Since all the world is but a story, it were well for thee to buy the
more enduring story rather than the story that is less enduring."
-- The Judgment of St. Colum Cille
Posted: Thu Jan 07, 2010 6:53 am Post subject: List decorum |
No hard feelings, Don
Let’s proceed with our eternal learning process, listening to Bob and other good teachers on this List
Carlos
[quote] --
From: Carlos Trigo [mailto:trigo(at)mail.telepac.pt]
Sent: quinta-feira, 7 de Janeiro de 2010 14:52
To: 'aeroelectric-list(at)matronics.com'
Subject: RE: AeroElectric-List: List decorum
No hard feelings, Dan
Carlos
[quote] --
mmayfield
Joined: 09 Oct 2009 Posts: 40 Location: NSW Central Coast, Australia
Posted: Thu Jan 07, 2010 1:23 pm Post subject: Re: List decorum |
There are many ways to skin a cat, I think, and going one way or the other doesn't make anyone smarter than anyone else.
The chances are that, if the system is designed well and installed well, anyone using either breakers or fuses will get a relatively long and hassle-free life out of it. Some want breakers, some want fuses. Tom-ay-to, tom-ah-to.......
Just do it properly and don't keep resetting/replacing them when they pop or blow without figuring out why they did!
Mike
