mrspudandcompany(at)veriz Guest
Posted: Wed Jan 06, 2010 10:57 am Post subject: [AeroElectric-List] Questions about circuit protection |
Dear Dan
I shouldn’t be a pilot (which I am for over 32 years now), I didn’t design or labelled very well my electrical system (which I’ve done many times), then, with all the respect, you shouldn’t be commenting… sir!
Best regards
Carlos
P.S. You probably didn’t read the part of my last comment (the only in which I didn’t panic) when I said I built and fly one airplane with fuses, one airplane with circuit breakers, and the one I’m currently finishing building have both. Don’t loose your time, just hit the delete button
[quote] Carlos, my friend, You have apparently made up your mind that circuit breakers are superior to fuses, even though several people on the forum have tried to show you the logic and advantages of fuses. May I suggest that you finish building your aircraft, using resettable circuit breakers, since this gives you a greater comfort level. Roger[b]
