winter.geoff(at)gmail.com Guest
Posted: Tue Jan 05, 2010 4:47 pm Post subject: Tachometer problems |
Hi All
I fly a Corby Starlet using an 1835 VW with a Bendix D4 RN-2021 dual magneto.
Both magnetos are grounded through separate magneto switches on my panel. I use
one of these leads to also run my tachometer. This has all been working just fine, but I've
now replaced the original Westach tacho with a new VDO tachourmeter, item # 333-035-11.
I have the VDO tacho set for 4 stroke, 4 cylinder, single coil operation.
The rpm reading appears accurate, but it is continually fluctuating. Every second or so the
rpm drops anything from 200 to 1000 rpm momentarily, then returns to normal.
Could anyone advise what I need to do to smooth out the reading. I've tried putting a diode inline with no joy.
Could anyone suggest some specific combination of capacitor/resistor/diode inline or parallel to the tacho I could try to smooth things out? Failed to get any help from VDO so any advice would be very much appreciated.
Cheers
Geoff
Posted: Wed Jan 06, 2010 9:35 am Post subject: Tachometer problems |
| Quote: | Could anyone suggest some specific combination of
It's a WAG. Without knowing how the input circuits
of the tachometer are crafted, then it's VERY difficult
to figure out what it doesn't like about the signal
provided by your magneto p-leads. The fact that
the reading "drops" suggests a low signal level
. . . hard to imagine on a p-lead!
However, the VDO input signal conditioning may have
over-attenuated the incoming signal as a by-product
of their own design goals for signal conditioning.
In this case, there's not much you can do outside
the tach short of building some sort of signal-
conditioning device to satisfy the tachometer's
demands.
Posted: Thu Jan 07, 2010 9:24 pm Post subject: Tachometer problems |
Bob
Thanks very much for that, I appreciate your time. I feared I wasn't looking at an easy fix. I think I'll revert to the old instrument and have a ponder.
Best regards
Geoff
On Thu, Jan 7, 2010 at 4:33 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
| Quote: | Could anyone suggest some specific combination of capacitor/resistor/diode inline or parallel to the tacho I could try to smooth things out? Failed to get any help from VDO so any advice would be very much appreciated.
demands.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
