Van's oil cooler shutter
recapen(at)earthlink.net
PostPosted: Mon Jan 04, 2010 2:55 pm    Post subject: Van's oil cooler shutter Reply with quote
Anyone have one of these on their baffle behind the #4 cylinder?
Would like to see pictures - hear your story.
My Vernatherm and oil temp sender are both good - my oil temp runs too cold in the winter.
My IO360B1F6 with SW 8406R cooler gives me a straight-line 185F degree oil temp in the summer (OAT over 65F) - but won't make 150F in the lower OAT ranges.
We get some weird temperature ranges here on the DelMarVa peninsula so a fixed block-off plate inside my plenum doesn't make sense - like this cockpit controllable unit.
Thanks in advance!
Ralph Capen
N822AR (Patience) (at) N06 47hrs - almost done with the first annual.
Terry Watson
PostPosted: Mon Jan 04, 2010 3:54 pm    Post subject: Van's oil cooler shutter Reply with quote
Ralph,
I mounted the oil cooler shutter on the baffle-mounted oil cooler, and another as an alternate air bypass on the bottom of the air cleaner. I have photos of the air filter one but not the oil cooler. I could get photos without too much trouble if you need them.
Here is a link to the photos of the air filter shutter installation: http://tcwatson.zenfolio.com/p288537335/e31f70275
It hasn't flown yet but I think the shutters will work well in both locations.
Terry
RV-8A #80729 stalled in the shop
Seattle
PostPosted: Mon Jan 04, 2010 5:37 pm    Post subject: Van's oil cooler shutter Reply with quote
Thanks in advance!
Ralph Capen
mrobert569(at)hotmail.com
PostPosted: Mon Jan 04, 2010 6:10 pm    Post subject: Van's oil cooler shutter Reply with quote
ralph C
Check the van's catelog.  They have a oil cooler door that works from the cockpit.  They call it the oil cooler vent and/or oil shutter.  It works quite well.
Mike Robertson
Das Fed
[quote] Date: Mon C 4 Jan 2010 17:03:14 -0500
To: rv-list(at)matronics.com; lycomingengines-list(at)matronics.com
Subject: Van's oil cooler shutter
--> RV-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net>
Thanks in advance!
Ralph Capen
Hotmail: Trusted email wit5/direct/01/' target='_new'>Sign up now.
bobbyhester(at)newwavecom
PostPosted: Mon Jan 04, 2010 6:55 pm    Post subject: Van's oil cooler shutter Reply with quote
I have the van's oil cooler shutter and this weekend with it completely closed with OAT of 20 degrees I was only getting between 140-150 degrees oil temp on a one hour flight. I'll see if I can find my pictures. I take it completely off in the hot months and usually see about 170-190.
XP-O360 regular baffles shutter in frt of oil cooler.
Surfing the web from Hopkinsville, KY
Visit my web site:
http://home.newwavecomm.net/bobbyhester/RVSite.htm
steve wrote: [quote] Just flew back from California to Topeka, Ks. Outside departure temp was 19 when I left Topeka and arrival temp was 12. I flew at 10,500 and 9,500 over the rockies. My oat temp was never above 28 F however the sensor is in the cabin air inlet area and I'm told it reads high due to the engine heat. But, I was able to very the oil temp between 160 and 180 the entire way. It works! If you want some pix I'll send them (they're still in the camera). Installation was easy as was the cable routing. I would do it again in a heart beat. And, no. I'm not going to mention the temperature in Southern California!!!
Steve Stucky
RV-7
From: Ralph E. Capen <recapen(at)earthlink.net> (recapen(at)earthlink.net)
To: rv-list <rv-list(at)matronics.com> (rv-list(at)matronics.com); lycoming engine list <lycomingengines-list(at)matronics.com> (lycomingengines-list(at)matronics.com)
Sent: Mon, January 4, 2010 4:03:14 PM
Subject: RV-List: Van's oil cooler shutter
--> RV-List message posted by: "Ralph E. Capen" <recapen(at)earthlink.net (recapen(at)earthlink.net)>
Thanks in advance!
Ralph Capen
N822AR (Patience) (at) N06 47hrs - almost done withntent also available via the -Matt Drall============
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
PostPosted: Mon Jan 04, 2010 7:48 pm    Post subject: Van's oil cooler shutter Reply with quote
I found my pictures:
http://picasaweb.google.com/bobbyhesterKY/OilCoolerShutter#
Visit my web site:
Thanks in advance!
Ralph Capen
brucerv84us(at)hotmail.co
PostPosted: Tue Jan 05, 2010 4:30 pm    Post subject: Van's oil cooler shutter Reply with quote
Steve C I take it your not using the shutter style oil cooler set-up. If possible when the photo's are available try to host them and post a link for us to learn from. TIA C Bruce
RV-8
Date: Mon C 4 Jan 2010 17:13:35 -0800
Subject: Re: Van's oil cooler shutter
.ExternalClass DIV {;} Just flew back from California to Topeka C Ks.  Outside departure temp was 19 when I left Topeka and arrival temp was 12.  I flew at 10 C500 and 9 C500 over the rockies.  My oat temp was never above 28 F however the sensor is in the cabin air inlet area and I'm told it reads high due to the engine heat.  But C I was able to very the oil temp between 160 and 180 the entire way.  It works!  If you want some pix I'll send them (they're still in the camera).  Installation was easy as was the cable routing.  I would do it again in a heart beat.  And C no. I'm not going to mention the temperature in Southern California!!!
Steve Stucky
RV-7
To: rv-list <rv-list(at)matronics.com>; lycoming engine list <lycomingengines-list(at)matronics.com>
Sent: Mon C January 4 C 2010 4:03:14 PM
Thanks in advance!
Ralph Capen
Hotmail: Powerful Free email with ect/01/' target='_new'>Get it now. [quote][b]
steve282s(at)yahoo.com
PostPosted: Wed Jan 06, 2010 6:00 am    Post subject: Van's oil cooler shutter Reply with quote
I'm using the shutter style add-on from Vans that fits between the baffle behind cyl #4 and the oil cooler. The shutter deflection is then operated via an automotive choke style cable mounted near the instrument panel. I'll try to get the pix posted today. But, I'm old, retired, tired, and this is hard.
steve
282S VariEze
283S RV7
To: Matronics <rv-list(at)matronics.com>
Sent: Tue, January 5, 2010 6:21:44 PM
Subject: RE: Van's oil cooler shutter
Steve, I take it your not using the shutter style oil cooler set-up. If possible when the photo's are available try to host them and post a link for us to learn from. TIA, Bruce
RV-8
Date: Mon, 4 Jan 2010 17:13:35 -0800
.ExternalClass DIV {} Just flew back from California to Topeka, Ks. Outside departure temp was 19 when I left Topeka and arrival temp was 12. I flew at 10,500 and 9,500 over the rockies. My oat temp was never above 28 F however the sensor is in the cabin air inlet area and I'm told it reads high due to the engine heat. But, I was able to very the oil temp between 160 and 180 the entire way. It works!  If you want some pix I'll send them (they're still in the camera). Installation was easy as was the cable routing. I would do it again in a heart beat. And, no. I'm not going to mention the temperature in Southern California!!!
Steve Stucky
RV-7
Thanks in advance!
Ralph Capen
Hotmail: Powerful Free email with ect/01/' target='_new'>Get it now. [/quote]
PostPosted: Thu Jan 07, 2010 7:04 am    Post subject: Van's oil cooler shutter Reply with quote
Hi Ralph,
Finally some pix. Let me know if they don't come through. I'll move it away from Yahoo. Unfortunately I didn't take a pic of the shutter before installation, but it is about 3/8 in thick and same width and length as the cooler. You mate it up to the cooler then, using the cooler as a drill guide, drill through the shutter for the mounting holes. Stick the bolts through the cooler and the shutter and then bolt that assy to the baffle. The control cable mounts to an arm that swings (aircraft) left and right to vary the shutter air opening. It mounts to this arm via a collar and set screw the same as the carb heat set up. Be certain you have upper cowl clearance before final assembly. As you can see from the photos, the shutter, when fully opened still blocks a portion of the air into the cooler. I have NOT determined if or how much effect this will have on summer activities. I suspect it will have some effect. If that is the case, removing the shutter is as simple as removing and reinstalling four bolts. Shouldn't even have to remove the oil lines. The hard part is messing with the cowl. I guess, just do it at oil change. The acuator cable is also from Vans. It's the standard cable they use for carb heat and cabin heat. I side mounted my throttle quadrant forward of the left arm rest - ala Dan Checkoway. The push pull knob is then attached to the small bracket that secures the engine control cables prior to entering the quadrant - just below the left airvent eyeball. Winter time flying works great. Jury still out on the hot summer Kansas days.
Congrats on Patience (love the name). Fly safe.
Steve Stucky
VariEze 282S
RV-7 283S (Wake Turbulence)
Sent: Mon, January 4, 2010 3:07:49 PM
Thanks in advance!
Ralph Capen
N822AR (Patience) (at) N06 47hrs - almost done withalso available via the Web bsp; -Matt Dralle, ===========
 Filesize:  2.25 MB
 Viewed:  15986 Time(s)
 Filesize:  288.89 KB
 Filesize:  255.97 KB
 Filesize:  286.14 KB
 Filesize:  221.73 KB
PostPosted: Thu Jan 07, 2010 7:35 am    Post subject: Van's oil cooler shutter Reply with quote
Hi Bruce,
Finally some pix. Let me know if they don't come through. I'll move it away from Yahoo. Unfortunately I didn't take a pic of the shutter before installation, but it is about 3/8 in thick and same width and length as the cooler. You mate it up to the cooler then, using the cooler as a drill guide, drill through the shutter for the mounting holes. Stick the bolts through the cooler and the shutter and then bolt that assy to the baffle. The control cable mounts to an arm that swings (aircraft) left and right to vary the shutter air opening. It mounts to this arm via a collar and set screw the same as the carb heat set up. Be certain you have upper cowl clearance before final assembly. As you can see from the photos, the shutter, when fully opened still blocks a portion of the air into the cooler. I have NOT determined if or how much effect this will have on summer activities. I suspect it will have some effect. If that is the case, removing the shutter is as simple as removing and reinstalling four bolts. Shouldn't even have to remove the oil lines. The hard part is messing with the cowl. I guess, just do it at oil change. The acuator cable is also from Vans. It's the standard cable they use for carb heat and cabin heat. I side mounted my throttle quadrant forward of the left arm rest - ala Dan Checkoway. The push pull knob is then attached to the small bracket that secures the engine control cables prior to entering the quadrant - just below the left airvent eyeball. Winter time flying works great. Jury still out on the hot summer Kansas days. On the 7, the oil cooler mounts on the baffle behind cyl #7. Not sure of your cooler setup on the 8. My friends 8 is mounted on the lower left air entrance. I guess it's just a matter of routing the control cable differantly. Email me if you have questions.
ps I tried to get this to the list but I doubt it made it, so sending it to you and a couple others.
Steve Stucky
VariEze 282S
RV-8
Steve Stucky
RV-7
Thanks in advance!
Ralph Capen
 Filesize:  2.25 MB
 Viewed:  15985 Time(s)
 Filesize:  221.73 KB
 Filesize:  255.97 KB
 Filesize:  286.14 KB
 Filesize:  288.89 KB
bell
PostPosted: Thu Jan 07, 2010 8:14 am    Post subject: Van's oil cooler shutter Reply with quote
Just a little off topic. I will be ready to measure for hoses this weekend and intend to use the aeroquip 666 teflon hoses for both fuel and oil..i have planned to uses hoses with the integrated firesleeve…two questions..first, is the firesleeve absolutely the right thing to do. I have seen a lot of installations without it..Second, is there another source for these hoses besides spruce ie cheaper..
Back on topic…we installed the sw double pass filter and are thinking we may need to restrict airflow in the winter too..we were considering the somewhat less sophisticated duct tape alternative..
8A
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of steve
Sent: Thursday, January 07, 2010 9:02 AM
Hi Ralph,
Steve Stucky
VariEze 282S
Thanks in advance!
Ralph Capen
carl.froehlich(at)verizon
PostPosted: Thu Jan 07, 2010 8:56 am    Post subject: Van's oil cooler shutter Reply with quote
This looks like a nice way to control oil cooler air flow for those mounting coolers someplace other than the rear baffle:
4” version http://www.nonstopaviation.com/rv10-controller-cooler-p-14566.html?osCsid=bc77b7d1ef861c7cd83d92c5a28010dc
3” version http://www.nonstopaviation.com/controller-cooler-p-14592.html
Carl Froehlich
RV-8A (525 hrs)
RV-10 (systems install)
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Glenn Bell
Sent: Thursday, January 07, 2010 11:11 AM
8A
Hi Ralph,
Steve Stucky
VariEze 282S
Thanks in advance!
Ralph Capen
bell
PostPosted: Thu Jan 07, 2010 9:32 am    Post subject: Van's oil cooler shutter Reply with quote
Sorry…cooler..not filter..
Sent: Thursday, January 07, 2010 10:11 AM
8A
Hi Ralph,
Steve Stucky
VariEze 282S
Thanks in advance!
Ralph Capen
dsvs(at)ca.rr.com
PostPosted: Thu Jan 07, 2010 10:48 am    Post subject: Van's oil cooler shutter Reply with quote
You can get the hoses with integrated fire sleeve in brown or blue from Heber Aircraft in Torrance CA http://www.herberaircraft.com. They treat every order as an AOG so you will get very fast service. I used them for all my oil and fuel lines.
Don VS
RV7 flying
have planned to uses hoses with the integrated firesleeve.two
Back on topic.we installed the sw double pass filter and are thinking we may
8A
Hi Ralph,
Steve Stucky
VariEze 282S
_____
in the winter.
ranges.
Thanks in advance!
Ralph Capen
