clemwehner
Posted: Sat Jan 02, 2010 10:30 pm Post subject: water temp guage |
We're getting near done on a KFIV-912.
But, when I planned the panel a few years ago, I included a Westach quad gauge with CHT, and also made a hole for a separate water temp guage. Now that I think about it, why would I need both? Doesn't CHT equal water temp in an engine with water cooled heads?
Am I missing something?
thanks for the help,
Clem
Lawton OK
KFIV-912 getting near done.
_________________ Clem
Oklahoma
Kitfox IV-912, under construction since 1991 |
lcfitt(at)sbcglobal.net Guest
Posted: Sat Jan 02, 2010 11:00 pm Post subject: water temp guage |
Clem,
I was looking at the cad drawings for my first Kitfox to see how I wanted to
set up the panel for the new one, and I too had the temp gauge slotted in
there. I also used the Quad gauge and as you are suggesting, filled the
hole with something else - had an extra turn and bank.
Lowell
Paul A. Franz, P.E.
Posted: Sat Jan 02, 2010 11:15 pm Post subject: water temp guage |
On Sat, January 2, 2010 10:26 pm, CLEMWEHNER wrote:
| Quote: | We're getting near done on a KFIV-912.
Good design choice. You won't regret that decision.
| Quote: | Now that I think about it,
heads?
In a word - no. I definitely would have both CHT and water temp gauges.
If it were mine I would use water temp gauge also.
| Quote: | Am I missing something?
The quad CHT is important if you want to run lean of peak because you know the
temperatures in each cylinder head. However, without fuel injection you still might
not elect to run lean of peak. But if the cylinders run close in temp, you definitely
can get significant fuel savings running lean of peak in cruise.
The water temperature gauge is an essential instrument too. It will let you know if
you're exceeding that T-stat controlled temp or that your operating temperature is too
low. The cyl head temp reading will be much higher than the water temperature since
the sensor is generally placed against the head under a spark plug. CHT is also
effected by power setting whereas T-stat controlled water temperature should remain
constant at all power settings.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
"Children should be educated and instructed in the principles of
freedom. ... If we suffer [the minds of young people] to grovel and
creep in infancy, they will grovel all their lives. ... The
foundation of national morality must be laid in private families...
How is it possible that Children can have any just Sense of the
sacred Obligations of Morality or Religion if, from their earliest
Infancy, they learn their Mothers live in habitual Infidelity to
their fathers, and their fathers in as constant Infidelity to their
Mothers? ... We have no government armed with power capable of
contending with human passions unbridled by morality and religion.
Avarice, ambition, revenge, or gallantry, would break the strongest
cords of our Constitution as a whale goes through a net. Our
Constitution was made only for a moral and religious people. It is
wholly inadequate to the government of any other. ... The only
foundation of a free Constitution, is pure Virtue, and if this
cannot be inspired into our People ... they may change their Rulers,
and the forms of Government, but they will not obtain a lasting
Liberty. ... A Constitution of Government once changed from Freedom,
can never be restored. Liberty, once lost, is lost forever."
-- John Adams
"An unlimited power to tax involves, necessarily, a power to
destroy; because there is a limit beyond which no institution and
no property can bear taxation."
-- John Marshall, McCullough v. Maryland, 1819
"Thomas Jefferson told us 'having a revolution every now and then
is a good thing,' and the people -- we the people -- are going to
have to fight back hard if we're not going to lose our country."
-- Rep. Michele Bachman (R-MN)
"[T]he government of the United States is a definite government,
confined to specified objects. It is not like the state governments,
whose powers are more general. Charity is no part of the legislative
duty of the government."
-- James Madison
In general, the art of government consists of taking as much money as possible from
one party of the citizens to give to the other.
-- Voltaire (1764)
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
Fox5flyer Guest
Posted: Sun Jan 03, 2010 5:00 am Post subject: water temp guage |
Clem, way back when I ran my 582 with my KF2 I used CHT sensors along with EGT and coolant sensors. I don't know whether they CHT sensors did me much good, but (IIRC) they always ran about 40 to 50 degrees hotter than the coolant temps. I always thought that if I had some sort of coolant blockage that allowed boiling in the heads (highest point), I would know it immediately with the CHT. I don't know if this would compare with the 912, though. Mainly, I like a lot of instruments so that if something suddenly is different it gets my attention.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
Dick Maddux
Posted: Sun Jan 03, 2010 7:14 am Post subject: water temp guage |
Paul,
By T-stat do you mean thermostat? Unless I am having a senior moment (I have many) I am not aware of a thermostat in the 9 series (unless you install an oil thermo) If there was one it wouldn't take 5-8 min for my engine to warm up enough to fly, or check the mags.
I also have the quad gauge that includes the CHT.The CHT pretty well equals a water temp gauge although both would be useful for comparison.
Dick Maddux
Fox 4
Milton,Fl
349.06 KB |
7468 Time(s) |
rdmac(at)swbell.net Guest
Posted: Sun Jan 03, 2010 11:21 am Post subject: water temp guage |
Clem,
I too have the quad gauge with CHT but it is good insurance to know what the over all temp of your coolant is running. I installed the sensor for my water temp in the spider tank on top of the engine.
Roger McConnell, Duncan, OK
Model 7 Trigear, Rotax 912uls
Flying sense Jan. 06
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of CLEMWEHNER
Sent: Sunday, January 03, 2010 12:27 AM
Subject: water temp guage
Clem
Lawton OK
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
Av8r3400
Joined: 22 Sep 2008 Posts: 83 Location: North Central Wisconsin (KRRL)
Posted: Sun Jan 03, 2010 1:35 pm Post subject: Re: water temp guage |
Correct, there is no thermostat in a 900 series Rotax unless it has been modified to accept one.
The cylinder head temp probe and coolant temp probes both read from the head casting, but from different places.
_________________ Thanks,
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos |
pwmac(at)sisna.com Guest
Posted: Mon Jan 04, 2010 9:16 am Post subject: water temp guage |
Correct Paul.
Both are the prudent way to go. Of course the Stat is a feature that
Rotax forgot, but is usually required unless one lives in the more
temperate clims. However I note that some builders use the shutters
on the radiator instead, which means a T gauge for coolant is even
more critical due manual control of the shutters. I don't think that
gauge should be engine mounted, but S/B in the coolant lines.
Paul W
with water cooled
> heads?
you still might
let you know if
temperature is too
temperature since
CHT is also
Paul A. Franz
Posted: Mon Jan 04, 2010 10:36 am Post subject: water temp guage |
I'm strugglin to understand this. It has always been my understanding that
temperatures relate to engine performance and longevity. I am personally
comfortable knowing my engine's temps. I need a bit of help understanding
how knowing the coolent temp in addition will help me protect my engine. I
flew lots of hours getting temp readings only from a cylinder head sensor
and an oil temp sensor. I have found that even then, both needles pretty
much follow each other during a warm up and flight and in the early days
were typically on the low side. That is where the small oil cooler and the
shutters came in. Then the same gauges showed the temps of the engine.
What am I missing? I could understand the need for numerous temp sensors
and gauges if the operation temperature ranges were critically narrow, but
when the ranges are over 50°? I'd rather save the ounce or two.
I found the following at:
http://www.rotaxservice.com/rotax_tips/engine_instruments.htm
Cylinder Head Temperature (CHT)
We found that many pilots confuse this instrument with a coolant temperature
instrument, and sometimes label it as such. The probe to this instrument
actually measures the temperature of the metal in your cylinder head. It
allows you to monitor the proper operation of the liquid cooling system that
cools your cylinder heads yet it does not measure the actual temperature of
that liquid.
Coolant temperature
No provision for a coolant temperature probe is provided on Rotax 4-stroke
engines and for good reason: the Cylinder Head Temperature instrument offers
a better insight into the proper operation of the liquid cooling system and
may reveal problems, such as the formation of air bubbles, that a coolant
temperature instrument would not.
Lowell
Paul A. Franz, P.E.
Posted: Mon Jan 04, 2010 7:04 pm Post subject: water temp guage |
On Mon, January 4, 2010 9:59 am, Lowell Fitt wrote:
I didn't realize there is no T-stat to regulate coolant temperature. In that case, I'd
expect coolant temperature to track power setting and because of capacity design,
coolant temperatures will be often lower than ideal. Here's what I mean,
thermodynamically speaking. The compression of an ideal gas follows:
PV**n = C P is pressure, V is volume and C is a constant.
For the two extremes of compression for air, adiabatic and constant temperature
compression, n = 1.41 (adiabatic) and n = 1.0 for isothermal compression. Adiabatic
compression occurs when there is no heat transfer to the surroundings and isothermal
compression is where all the heat of compression is transferred to the surroundings.
We would like to have the highest possible thermal efficiency of the engine which
would ideally be with adiabatic compression. This would be the condition with the
highest possible coolant water temperature (closest to adiabatic) and hence the least
heat of compression lost.
A coolant T-stat (Thermostat) would be ideally set for the highest possible
(allowable) temperature to do the following:
1) maximize the thermal efficiency of the engine
and
2) minimize the warm up time period where the most damage to the engine occurs due to
water vapor condensation and degradation of the engine oil and corrosion from the
formation of sulfuric acid in the crankcase.
Since Rotax has chosen not to provide thermostatically regulated coolant temperature
probably due to a desire for weight savings, I would expect water temperature and
cylinder head temperatures to both track power setting.
An additional benefit of having a T-stat and consequently a higher coolant temperature
would be more cabin heat if you have coolant routed to a cabin heater.
I plan to incorporate a T-stat in my 914 installation and a coolant temperature sensor
immediately upstream of the T-stat. I will also use CHT on each cylinder. In this
configuration coolant temperature will not track CHT. CHT will track power setting and
mixture. One thing that I also wish were possible on the 914 would be an intercooler
which would greatly extend engine life. (The 914 is turbo supercharged.)
that liquid.
Coolant temperature
Paul A. Franz
Bellevue WA
425.241.1618 Cell
"Besides the advantage of being armed, which the Americans possess
over the people of almost every other nation, the existence of
subordinate governments, to which the people are attached and by which
the militia officers are appointed, forms a barrier against the
enterprises of ambition, more insurmountable than any which a simple
government of any form can admit of."
-- James Madison, Federalist No. 46
"The accumulation of all powers, legislative, executive, and judiciary, in the
same hands, whether of one, a few, or many, and whether hereditary,
self-appointed, or elective, may justly be pronounced the very definition of
tyranny."
-- James Madison
Suppose you were an idiot. And suppose you were a member of
Congress. But then I repeat myself.
-- Mark Twain
"Determine never to be idle. No person will have occasion to complain
of the want of time, who never loses any. It is wonderful how much may
be done, if we are always doing."
-- Thomas Jefferson, letter to Martha Jefferson, 5 May 1787
"This Government, the offspring of your own choice, uninfluenced and
unawed, adopted upon full investigation and mature deliberation,
completely free in its principles, in the distribution of its powers,
uniting security with energy, and containing within itself a provision
for its own amendment, has a just claim to your confidence and your
support."
-- George Washington, Farewell Address, 1796
Bellevue WA
425.241.1618 Cell
Float Flyr
Posted: Tue Jan 05, 2010 7:31 pm Post subject: water temp guage |
I guess if you noticed your CHT climbing and the water temp holding steady
or even going low, you might guess that you were getting low on coolant.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
