lifeofreiley2003(at)yahoo Guest
Posted: Wed Apr 12, 2006 6:39 am Post subject: P-Mags P-Mags |
I would send the P-Mags back to the manufacture for a 100% full replacement as the 900 rpm range is unacceptable!
Darrell
sportav8r(at)aol.com Guest
Posted: Wed Apr 12, 2006 7:18 am Post subject: P-Mags P-Mags |
They (emagair) don't seem to think so.
khorton01(at)rogers.com Guest
Posted: Wed Apr 12, 2006 2:08 pm Post subject: P-Mags P-Mags |
On 12 Apr 2006, at 10:34, Darrell Reiley wrote:
<lifeofreiley2003(at)yahoo.com>
Does it really matter if the P-Mag can't handle an electrical power
loss at idle on the ground?
What is idle rpm in flight at typical airspeeds? What would the
operational consequences be to having to keep the engine at 1,000 rpm
minimum in flight, if the electrical system had failed?
Ottawa, Canada
http://www.kilohotel.com/rv8
Posted: Wed Apr 12, 2006 3:11 pm Post subject: P-Mags P-Mags |
No I guess you could say it doesn't matter but here's what's advertised...
"P-MAG offers a unique solution. Instead of backing-up the aircraft buss, the P-MAG produces its own power (at 700 rpm and above). The aircraft buss acts as the back-up most of the time. With this arrangement, dual electronic ignitions can be run "clean". No back-up batteries and no back-up magnetos."
I guess if you wanted you could take off with a 70 rpm mag drop on one mag and a 300 prm mag drop on the other mag.
When I spend my hard earned $$$'s I want to get what I paid for.
Darrell
Ottawa, Canada
"Do Not Archive"
Darrell Reiley
RV7A "Reiley Rocket"
N622DR Reserved
michele.delsol(at)microsi Guest
Posted: Wed Apr 12, 2006 9:22 pm Post subject: P-Mags P-Mags |
PMag minimum RPM has been discussed in the past. The consensus seems to have
been that the whirlwind effect would maintain the propeller spinning above
700 RPM, which means that the PMags should put out power. Now, if the PMag
is not generating its own power above 700 RPM then it is not up to specs.
This is another issue which should definitely be taken up with eMagair and
is probably a case by case issue.
Michele - RV8 Fuselage - going the dual PMag route.
Bob Barrow
Posted: Thu Apr 13, 2006 12:58 am Post subject: P-Mags P-Mags |
On their website EMAG is vague about the RPM required for providing
sufficient power to run the EI. For instance on the PMAG page they say:
"produces its own power at 700 RPM and above". However on the FAQ page they
say: "will operate at 700 to 800 RPM".
Personally I'd be getting worried if it took 900 RPM to keep the EI
operating because that might be getting very close to the edge if you pulled
the throttle fully at slow speed on final. If there was cessation of ship's
power for any reason then the engine could quit...and it would not start
again. At altitude you might be able to push the nose over and get the RPMs
up but at lower levels this would not be an option.
I'm inclined to agree with Michele and Darrell on this one....900 RPM is
over EMAGs specifications and may produce a quite slender safety margin (if
any at all).
[quote]From: Michle Delsol <michele.delsol(at)microsigma.fr>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: RE: P-Mags P-Mags
Date: Thu, 13 Apr 2006 07:16:54 +0200
have
Posted: Thu Apr 13, 2006 2:03 am Post subject: P-Mags P-Mags |
One solution I am considering is to have a small back up rechargeable
battery just for the PMags - sort of a redundant electrical system which
would automatically turn on if current feeding the PMag were to fail.
Warning lights would tell me if the redundant system was low voltage wise,
another light would light up if the PMags were not getting their power form
the main electrical system. This should pretty well take care of just about
all risks of not getting power into the PMag.
Michle
rv9jim(at)juno.com Guest
Posted: Thu Apr 13, 2006 7:10 am Post subject: P-mags P-mags |
If that becomes a safety issue, I intend to add to my pre-landing check
list: "Ignition" to battery", "boost pump on" ect. You start it that
way and leave it on until I take the active. Another way would be to tie
it to the boost pump switch. That way, any time you are on the ground or
getting ready to land, boost pump on also turns on the battery feed to
the "P" mags. BTW, I have two "P" ignitions units on my engine. I have
not flown yet but later this year. Now that it is noted, I may wire it
so either way I set the switches, I will have battery power to the "P"
ign. unit. That way I won't have to "add" to do something else. Just
trying to follow the KISS principal.
Jim
klwerner(at)comcast.net Guest
Posted: Thu Apr 13, 2006 7:42 am Post subject: P-Mags P-Mags |
One might as well do away with the more expensive P-Mag, and install the E-Mag if you plan to have a secondary powersource anyway besides the "MAIN" Alternator/-Battery.
What is the point of having a self-powered P-Mag if you then have to come up with multiple warning systems to monitor and possibly aid it's self-powering function? How about a magneto with no external source to worry about???
I would personally prefer dual Lightspeeds instead, to be powered by a small Ignition-battery to power them exclusively (...but the LSE's could also be switched to the main battery if need be).
This way you always have uninterrupted juice to the Sparklers, and this setup will also prevent the problems some very popular Starters have due to temporary voltage drop during the starting sequence.
Do not archive my two cents worth, ...but I wish to each its own, after all it is experimental!
