Transponder Question
robin1(at)mrmoisture.com
PostPosted: Sat Jan 02, 2010 3:28 pm    Post subject: Transponder Question Reply with quote
I am laying out my “Budget” RV-8A panel and have a transponder question. And yes I know this is the -10 list but I think I still have privileges here.
I am unclear what is the lowest priced Garmin Transponder that will ultimately work with ADS-B and other traffic warning systems.
I understand that the GTX-330 is their top of the line and is IFR certified but will the GTX-237 work with things like Navworx and TIS? It does not appear to be the case.
Robin
Phase 1 of Panel design (~$30K):
 Filesize:  98.08 KB
 Viewed:  13108 Time(s)
 Filesize:  38.54 KB
Tim Olson
PostPosted: Sat Jan 02, 2010 3:45 pm    Post subject: Transponder Question Reply with quote
Robin, the 330 is the only one that does Mode-S tis, and
therefore would be the only one that you could use with
NavWorx Composite-TIS function. If you buy a cheaper
one without Mode-S, you'll only get ADS-B targets.
With the 330, you can get either, via their box...assuming
the G900 uses the same standard interface they use
for other things.
here.
Robin
Kellym
PostPosted: Sat Jan 02, 2010 6:35 pm    Post subject: Transponder Question Reply with quote
Keep in mind that a 330 locks you into the 1090ES standard for ADSB,
while it looks like UAT will continue to be a more flexible and robust
system. If you want to keep options open, buy a low end Mode A/C
transponder for now. BTW, there is no such thing as IFR transponder.
They all have to meet a single TSO to be legal to use in aircraft. As
long as you avoid certain airspace, it is still legal to fly IFR with no
transponder. Might get some ATC complaints, however.
for other things.
> privileges here.
> Thanks,
> Robin
Kelly McMullen
KCHD
Tim Olson
PostPosted: Sat Jan 02, 2010 8:03 pm    Post subject: Transponder Question Reply with quote
I wouldn't say that a 330 locks you into anything, really.
It is about the best way to get Mode-S TIS right now, but
you don't get the ES part unless you buy the ES upgrade
for something like $1200. So in actuality, it would give
you the flexibility to go ES as your "OUT" for ADS-B if
you needed to, although for not much more money you could
go with a UAT and feed the Wx data to an onboard device.
You're right, for now you could get a low-end Mode C
transponder and save some money, but if you go with a 330
you'll have TIS right now, and, the transponder won't be
obsoleted by the ADS-B stuff coming forward. I know Mode
S is "going away", but the timeframes are still a ways
out there....and look at how VOR's, LORAN, and things like
that were also supposed to be "going away". So really, what
it comes down to is, if you're really trying to save every
dollar you can, and you don't have any care for Mode S TIS,
then go ahead and just buy a 327 or something. But, if you
buy a 330, you can get Mode S TIS today, and that same box
will work fine for you going forward, whether you choose
a UAT or go the ES route. What I don't have a clue about
is if the 327 is going to have any upgrade path to ES...and
if it doesn't, it may be safer to just go the 330 route.
The added cost isn't in extreme dollars.
Also, just today I was watching Mode S TIS targets in the MSP
area coming through the NavWorx ADS600 ADS-B receiver....it
can take GTX330 Mode S Targets and output them to your device,
along with outputting TIS-B targets. So with something like
that, it gives some benefit to having either system. The one
thing better would be active traffic, but to really get a
good system that gives bearing, range, and altitude to
"intruders", you're going to spend maybe 5X or 6X the price,
and have to do some real good top and bottom fin antennas.
> for other things.
> Tim
>> Thanks,
>> Robin
Kelly McMullen
PostPosted: Sat Jan 02, 2010 8:40 pm    Post subject: Transponder Question Reply with quote
All nice benefits, which also carry the price of anyone and everyone
that wants to track where you go being able to, because your Mode S
code is unique to your aircraft, regardless of VFR/IFR status. But if
you don't mind, you can see the same thing the controllers see on
radar, with a greater time lag, already 6 secs behind when it shows on
the scope. I've flown from St Paul to EAU in a TIS equipped aircraft.
IIRC it stopped supplying traffic about 50 miles east of St Paul, at
outer range of MSP radar. Maybe if I were more used to it I'd want it.
> Keep in mind that a 330 locks you into the 1090ES standard for ADSB, while
> it looks like UAT will continue to be a more flexible and robust system. If
> you want to keep options open, buy a low end Mode A/C transponder for now.
> BTW, there is no such thing as IFR transponder. They all have to meet a
> single TSO to be legal to use in aircraft. As long as you avoid certain
> airspace, it is still legal to fly IFR with no transponder. Might get some
>> for other things.
>> Tim
>>> here.
>>> Thanks,
>>> Robin
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
cloudvalley(at)comcast.ne
PostPosted: Sun Jan 03, 2010 6:57 am    Post subject: Transponder Question Reply with quote
Hi TIme,
My wife, Ruth and I were RV10 builders but sold our empennage a little over a year ago, after getting your axle kit. We had to regroup because our farm here isn't selling yet, but it is a money- maker and we are sure it will. We may get a moslty done RV-10 when we sell.We see lots of RV ers when we fly the 79 Tiger we bought up to Independence for lunch all the time, from Eugene, Oregon.
We bought this low-time Tiger last year and put in a 430 WAAS and a GMX200.( Also bought a 696 which we love) This year we had a GTX330 installed, along with a PMA700 audio panel when our transponder went out near Gorman in Calif. We love it. At least it shows the traffic vectors for aircraft in the vicinity of busy airspace, and it can be upgraded later..hopefully by someone who buys our Tiger after the farm sells, so we can upgrade our plane. We want to fly all ver when we move to Ohio near wife's brother. We keep reading about all your flying adventures, and are jealous. As long as we have this farm we have to work in the summer,selling produce at the Farmers' market, and ony have time for short trips. Oh well..patience..
Talk to you later Tim, and thanks for all your input.
Brian and Ruth
Tim Olson
PostPosted: Sun Jan 03, 2010 11:34 am    Post subject: Transponder Question Reply with quote
Yeah, I was wondering how that Tiger was treating you. Do you know
how they are on grass? I'm looking for a time builder for Andrea now
that she's got her certificate, and I was thinking RV7A/9A, but maybe
a Tiger wouldn't be so bad if it can handle grass.
Well, hope you have good luck selling the farm eventually!
cloudvalley(at)comcast.net wrote:
[quote] Hi TIme,
later...hopefully by someone who buys our Tiger after the farm sells, so
Brian and Ruth
lbgjb10
PostPosted: Sun Jan 03, 2010 1:57 pm    Post subject: Re: Transponder Question Reply with quote
didn't realize that 330 worked with ADS-B, thought it was only S mode. Does my 18 month old 330 have that capacity?? does it need different antenna?? upgrade?? larry
Larry and Gayle N104LG
Tim Olson
PostPosted: Sun Jan 03, 2010 2:39 pm    Post subject: Transponder Question Reply with quote
It doesn't.....but Navworx can receive via arinc from the 330 and mix
that mode s with their ads-b to send to your display, depending on
your avionics choices and configuration.
http://forums.matronics.com/viewtopic.php?p 79930#279930
PostPosted: Sun Jan 03, 2010 3:54 pm    Post subject: Transponder Question Reply with quote
I think you do need an additional antenna 4' away from the Transponder
antenna. About $110.00 from Navworx. I forgot what type of antenna but
it's a common aviation antenna. I plan the add the Navworx to two ships
so I will figure it out sooner or later (most likely later).
Robin
Tim Olson
PostPosted: Sun Jan 03, 2010 4:13 pm    Post subject: Transponder Question Reply with quote
It's just a normal shark-fin Transponder antenna. One wire. Oh and
you'll add a GPS antenna. On mine I put the GPS antenna under the
vertical stab fairing, since I don't consider this as "critical to
navigation". You can feed GPS in to the box from some other source,
but the requirements of that GPS spec are pretty stringent, per ads-b
requirements, so I figured the simple way was to just use the built-in
GPS.
The active traffic systems use like 4 wires for the antenna, or
something like that, and the blade is much larger.
The antenna for Ads-b is smaller and mounts on the belly.
ships
Robin
dlm46007(at)cox.net
PostPosted: Sun Jan 03, 2010 5:18 pm    Post subject: Transponder Question Reply with quote
Officially you need 6 ft between your UAT antenna and the Garmin
transponder. 4 ft may work. UAT antenna is a DME antenna.
rv10builder(at)verizon.ne
PostPosted: Sun Jan 03, 2010 5:30 pm    Post subject: Transponder Question Reply with quote
Tim;
You mention the shark fin transponder, is that a specific requirement or
does any transponder antenna work the same?
Thanks!
Sent: Sunday, January 03, 2010 4:13 PM
Subject: Re: Re: Transponder Question
navigation". You can feed GPS in to the box from some other source, but
GPS.
The active traffic systems use like 4 wires for the antenna, or something
> Robin
jesse(at)saintaviation.co
PostPosted: Sun Jan 03, 2010 5:45 pm    Post subject: Transponder Question Reply with quote
The 330 doesn't provide ADS-B, it just allows the Mode-S information to go to the ADS-B, and somehow show both on the same display. I don't know the details, but your 330 can't provide ADS-B.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
PostPosted: Sun Jan 03, 2010 5:58 pm    Post subject: Transponder Question Reply with quote
Hi TIm,
Ruth told me that the Tiger does well on grass. She has landed it on grass and taxied...does well. She has 2000 hrs, mostly in Tigers (110 hrs in an overpriced Cirrus SR20 we had for 6 months). When we sell (we do have two interested clients now), I will have to get my certificate before we sell it. But it will be so great to move on with our lives. Talk to you later Tim.
Brian
PostPosted: Sun Jan 03, 2010 6:20 pm    Post subject: Transponder Question Reply with quote
Hi again TIm,
I was ambiguos about the word sell. I meant that we have two interested clients in the farm, not the plane..we are about to put some leather seats in it also. Got a very good bid from someone in Aurora, Oregon near Vans. I know we won't get our money all back when we sell 179GT, but we will at least have some fun with it before we move, and perhaps for a short while after. Th epanel pics are from before we had the GTX 330 and PMA 7000 audio panel installed. Also hard wired the 696 on the co-pilot's side. It shows traffic also.
Brian
 Filesize:  256.91 KB
 Viewed:  13044 Time(s)
 Filesize:  302.95 KB
 Filesize:  292.74 KB
 Filesize:  340.53 KB
Tim Olson
PostPosted: Sun Jan 03, 2010 6:35 pm    Post subject: Transponder Question Reply with quote
I think I asked that question of them during my install too, and was
just highly encouraged to use a shark fin. From an aerodynamic
perspective I think it's better too. You want a DME/Transponder
antenna that works in that range from 960-1220mhz. I think
mine is the RAMI AV-74
Tim Olson - RV-10 N104CD
Pascal wrote:
Tim;
Thanks!
> GPS.
> Tim
>> Robin
