dlm46007(at)cox.net Guest
Posted: Wed Dec 30, 2009 9:48 am Post subject: lightning strike |
Found one other anecdote: A Lancair took a strike and lost one com port of a three screen Chelton system. engine info was lost until he could disconnect the third screen. He then was able to access all info albeit on two screens.
Posted: Wed Dec 30, 2009 9:50 am Post subject: lightning strike |
Recived this from a friend
This was in the day before EFIS. Both strikes were in the Merlin. The first one we were climbing out of Dallas dodging thunderstorms at 8 to 10 thousand feet when we got hit---We immediately lost both radios and the autopilot. We did get communication back eventually but I can’t remember about the autopilot. The nose cone was mush and there were several pinholes around the plane, mostly on wing tips and the bottom of the fuselage.
Another time we were climbing through 14000 feet between cells and in the open—I was flying and we heard close thunder and I felt a slight jolt on the yoke—Neither I or the other guy had any thought of a strike but we later found we had taken a hit again on the nose, and a nick out of the left prop and a crack in the left thrust bearing. We did not lose comm or any other equipment—Both generators were knocked off but we reset and got them back.
Posted: Wed Dec 30, 2009 10:13 am Post subject: lightning strike |
The pilot of a Skymaster across from my hangar at MLB was scrutinizing his airplane, and I went over to see what was up. He and his wife were on the way home when they flew between two big thunderheads, and got hit by lightning. It took out a 1/2 dime size chunk from the prop, and traveled back to the horizontal stab where it removed a whole line of rivets from a rib, a burn hole in the elevator and left on a static wick after making it frazzled. He said nothing failed. I asked him what the strike sounded like, and he said he didn't know. "I couldn't hear anything but my wife screaming!!!"
Linn
DLM wrote: [quote] (at)font-face { font-family: Calibri; } (at)font-face { font-family: Tahoma; } (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.0in 1.0in 1.0in; } P.MsoNormal { MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } LI.MsoNormal { MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } DIV.MsoNormal { MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman","serif"; FONT-SIZE: 12pt } A:link { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline; mso-style-priority: 99 } A:visited { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline; mso-style-priority: 99 } SPAN.EmailStyle17 { FONT-FAMILY: "Calibri","sans-serif"; COLOR: #1f497d; mso-style-type: personal-reply } .MsoChpDefault { FONT-SIZE: 10pt; mso-style-type: export-only } DIV.Section1 { page: Section1 } <![endif]--> <![endif]--> Recived this from a friend
href="http://www.howtocrimp.com">www.howtocrimp.com
| [b]
AV8ORJWC
Posted: Wed Dec 30, 2009 10:53 am Post subject: lightning strike |
Each of those bearings on the control surfaces should be checked for resistance to movement and welding marks. That is the purpose for bonding straps. Our fleet of regional aircraft are hit regularly - we may even hold the record for most hits in each year. Every strike requires a grounding of the aircraft until a thorough inspection is completed. We use a Megger, which most RV-10 owners might not have access to confirm the continued function of static dissipation wicks. The charge wants to get out of the aircraft and is quite stubborn in its seeking the path of least resistance to that goal.
Some might reconsider not flying anywhere near thunderheads to avoid the damage.
Just food for thought to those who do not build with straps, P static wicks or fly near Q's.
John Cox
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Linn Walters
Sent: Wednesday, December 30, 2009 10:09 AM
Subject: Re: FW: lightning strike
Linn
| Quote: | | href="http://www.aeroelectric.com">www.aeroelectric.com href="http://www.buildersbooks.com">www.buildersbooks.com href="http://www.homebuilthelp.com">www.homebuilthelp.com href="http://www.howtocrimp.com">www.howtocrimp.com href="http://www.matronics.com/contribution">http://www.matronics.com/contribution href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List href="http://forums.matronics.com">http://forums.matronics.com |
[quote] [/b][/b][/b][/b][/b][/b][/b]www.aeroelectric.com[/b]www.buildersbooks.com[/b]www.homebuilthelp.com[/b]www.howtocrimp.com[/b][/b]http://www.matronics.com/contribution[/b][/b][/b][/b][/b][/b][/b][/b][/b]http://www.matronics.com/Navigator?RV10-List[/b][/b][/b][/b]http://forums.matronics.com[/b][/b] [b]
MauleDriver(at)nc.rr.com Guest
A lightning strike on an all electric airplane seems to be an exposure,
but in my very limited experience, I think a manageable one.
I've flown close to thunderstorms and will do so again. But I stay
visual when flying IFR. A very workable solution to flying around FL
and the SE US on a summer afternoon. I avoid underneath, stay in the
system, and use XM and ATC to avoid the cells. JAX controllers rock.
Under certain conditions, I'll do it at night.
I fly solid IMC when there aren't thunderstorms in it.
But, I scared myself for an extended period of time in an early IFR
flight when flying IMC with embedded cells. I never became aware of
lightning but assumed it was there somewhere. The cells were light but
distinct; smooth dry flight interrupted by turbulent vertical drafts and
varying amounts of rain. It didn't seem 'light' at the time. This was
pre-XM and even pre-Cheap Bastard so I had no eyes. ATC was vectoring
me around the build-ups until they stopped (too busy). Not knowing when
or how strong the next cell encounter would be was slow torture. A 180
put me over high ground before VFR would be reached. Landing required
more plan changing than I was comfortable doing. Straight ahead would
put me in flat land VFR before not too long so I droned on.
Thunderstorms - manageable but stay visual. Hours hand flying in solid
IMC - rare but quite doable. Embedded cells in solid IMC - not
manageable with only XM-eyes. I guess that's a personal minimum of sorts.
So I guess I'm saying if I get hit by lightning and the entire
electrical system is zonked, I'll fly the plane and land it because I
don't plan to be in the clouds.
DLM wrote:
| Quote: | Found one other anecdote: A Lancair took a strike and lost one com
bwestfall
Posted: Wed Dec 30, 2009 11:04 am Post subject: lightning strike |
Many years ago a friend of mine who used to fly Fokker F28’s before they were retired from his airline got hit by lightning. He said it sounded like a shotgun blast went off. It did trip a few breakers but nothing failed entirely on the airplane. It hit pretty close to the nose and exited out the tail somewhere. I don’t recall the specifics but he said there were a bunch of burn marks at the exit point and a pinhole where it hit. The F28 probably didn’t have a single computer chip in it. He used to carry along the garmin pilot III we use in our GA planes just to make me jealous of the max speed when I used it next and he always said… “There’s more technology in this handheld then the entire rest of the jet”.
Linn
DLM wrote:
<![endif]--> <![endif]-->Recived this from a friend
[quote] [b]
Bob Turner
Posted: Wed Dec 30, 2009 11:40 am Post subject: Re: lightning strike |
Something to keep in mind: most of these experiences were in all-metal airplanes. Sitting inside a conducting cage offers quite a bit of protection.
But in a -10 the upper half of my body will be inside a non-conducting fiberglass shell. It is very hard to predict how it would react to a lightning strike.
I plan to stay far away from TRW.
_________________ Bob Turner
RV-10 QB |
Bob Turner
Posted: Wed Dec 30, 2009 11:44 am Post subject: Re: lightning strike |
Here's a regional airliner after a lightning strike.
RV-10 QB |
Bob Turner
Posted: Wed Dec 30, 2009 11:49 am Post subject: Re: lightning strike |
sorry, attachment didn't attach. Try again.
373 Bytes |
13970 Time(s) |
RV-10 QB |
Bob Turner
Posted: Wed Dec 30, 2009 11:54 am Post subject: Re: lightning strike |
if it doesn't attach this time I'll give up.
 Download |
| Filename: |
lightning.pdf |
25.98 KB |
| Downloaded: |
588 Time(s) |
RV-10 QB |
AV8ORJWC
Posted: Wed Dec 30, 2009 12:54 pm Post subject: lightning strike |
Working for that exact airline that Ben is referencing with the
F-28/CRJ-700 turbofans and DHC8 turboprop, they all get their fair share
of lightning exposure. I have a lot of respect for lightning after
getting slapped by it on my first flight decades ago as a zero time
pilot and it happening right after liftoff. PDX tower saw the bolt and
asked if we were okay. I did not know any better at the time. I have
learned that it can cause significant structural damage, destroyed
static wicks, composite panels blown off and component damage which can
ignite adjacent flame resistant materials. It merits consideration.
Your picture Bob looks to be fire damage of the wire looms running to
the CB panels, aft of the CO's seat. It could indeed be lightning but
more likely the secondary effect of playing with Mother Nature on her
terms.
Years ago we had some great posts here on the RV-10 site of static wick
types, locations and advantages of bonding wires between control
surfaces and the primary structure. Our engine shop sees too much of
internal engine damage so I do not want to mitigate the position of P&W
on their mandatory inspection requirements. Our airline would not like
me to release some of the pictures which have been acquired
(clandestinely) while performing "Normal" day to day maintenance. But
Thanks Bob for the post.
The imprint of Thor's hammer!
Bob Turner wrote:
Phil.Perry(at)netapp.com Guest
Posted: Wed Dec 30, 2009 1:41 pm Post subject: lightning strike |
..... converting Bob's PDF to JPG so the attachment works on the mailing list.
Here it is:
Phil
207.43 KB |
13937 Time(s) |
30.67 KB |
13937 Time(s) |
folgie(at)comcast.net Guest
Posted: Wed Dec 30, 2009 1:43 pm Post subject: lightning strike |
This was not a lighting strike.....Cause by a fire inside while on the
Ground.
rv10(at)colohan.com Guest
This URL offers a better image and explanation of that photo:
http://www.snopes.com/photos/airplane/lightning.asp
Chris
On Wed, Dec 30, 2009 at 11:54 AM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote] --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=279270#279270
http://forums.matronics.com//files/lightning_145.pdf
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
"_blank">www.howtocrimp.com
le, List Admin.
Tim Olson
Posted: Wed Dec 30, 2009 1:48 pm Post subject: lightning strike |
Man that was some big hole!
Tim Olson - RV-10 N104CD
Bob Turner wrote:
ricksked(at)cox.net Guest
Bob Turner
Posted: Wed Dec 30, 2009 3:56 pm Post subject: Re: lightning strike |
I was mis-informed about the lightning photo (too gullible, I guess). Thanks for the correction.
But I'm still worried about the non-conducting fiberglass cabin, when it comes to lightning.
RV-10 QB |
Posted: Wed Dec 30, 2009 4:45 pm Post subject: lightning strike |
You could probably install a lightning rod; perhaps Deems can come up with a
mod. Perhaps a refueling probe from E6 in the forward cowl. From what I
understand there are going to be many more acceptable ways for the
electricity to get though our aircraft than fiberglass.
Posted: Wed Dec 30, 2009 6:59 pm Post subject: lightning strike |
(in the background Johnny Mathis sings "Chances Are" over and over .....
chances are since the fiberglass is non conducting ...(don't really know
about the carbon fiber!) that any lightning strike will hit the
aluminum, looking for the least resistance to ground. It probably
wouldn't be any difference wet since pure water doesn't conduct well.
Having said that .... lightning really does some strange things and it
all depends on Mother's attitude at the time.
Linn
Bob Turner wrote:
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p 79313#279313
