cjay
Posted: Mon Dec 28, 2009 7:16 am Post subject: mag blow tubes |
I've spent the last hour perusing build sites with no luck. Does anyone have some pics on how to hook the blow tubes into the mags? There seems to be a logical port, but before I remove it I thought I'd ask.
Since I'm on the subject, can anyone point me to procedures for proper timing?
much obliged,
cjay
ricksked(at)cox.net Guest
Posted: Mon Dec 28, 2009 7:59 am Post subject: mag blow tubes |
Cjay'
They don't hook to the mag, the tubes blow air from the back baffle and should be directed towards the part of the mag that houses the condenser....I used one inch scat flanges mounted on the baffle and one inch scat tube bent to shape with safety wire and secured the wire with red RTV...I can shoot you a pic in a little while when I get to the hangar
Rick S.
N246RS
Posted: Mon Dec 28, 2009 8:02 am Post subject: mag blow tubes |
I just re timed mine, let me find the procedure...way different than automotive...do you have a timing module? I managed to get both mags almost perfectly in sync thanks to the help of a Lycoming loving friend who helped me out...
Rick S.
Posted: Mon Dec 28, 2009 8:10 am Post subject: mag blow tubes |
AFAIK, mag and alternator blast tubes just channel cooler air to the
area, not really inside them. I think there may be a chance of blowing
debris (bugs) into the mag causing more problems than high heat.
Linn
cjay wrote:
much obliged,
cjay
http://forums.matronics.com/viewtopic.php?p 78987#278987
Posted: Mon Dec 28, 2009 8:42 am Post subject: mag blow tubes |
Here is a great article from AVWeb on adjusting the timing, I have to find my Lycoming manual disc for the factory procedure which is the same with much older pictures!!
http://www.avweb.com/news/maint/184370-1.html
Rick
---- cjay <cgfinney(at)yahoo.com> wrote:
much obliged,
cjay
planesmith(at)hotmail.com Guest
Posted: Mon Dec 28, 2009 8:44 am Post subject: mag blow tubes |
Hi Cjay C
Here are some pictures of what I did. The left one is hooked via cushion clamps to the engine mount and the right one is hook to the bolt stud that would hold the vacuum pump.
Vern Smith (#324)
www.aviationstop.com
| Quote: | Subject: mag blow tubes
Date: Mon C 28 Dec 2009 07:16:30 -0800
--> RV10-List message posted by: "cjay" <cgfinney(at)yahoo.com>
I've spent the last hour perusing build sites with no luck. Does anyone have some pics on how to hook the blow tubes into the mags? There seems to be a logical port C but before I remove it I thought I'd ask.
Since I'm on the subject C can anyone point me to procedures for proper timing?
much obliged C
cjay
http://forums.matronics.com/viewtopic.php?p=278987#278987
&========================Hotmail: Trusted email wit5/direct/01/' target='_new'>Sign up now. |
692.51 KB |
5625 Time(s) |
730.15 KB |
5625 Time(s) |
Posted: Mon Dec 28, 2009 10:25 am Post subject: mag blow tubes |
In case it is not clear from the pictures C the air is ducted just over the outside not into the mags. As a side note depending on your engine monitoring system the "logical port" will be used for an electronic tach pickup.
Vern
Subject: RE: mag blow tubes
Date: Mon C 28 Dec 2009 09:32:15 -0700
.ExternalClass .ecxhmmessage P {padding:0px;} .ExternalClass body.ecxhmmessage {font-size:10pt;font-family:Verdana;} Hi Cjay C
Vern Smith (#324)
much obliged C
cjay
Hotmail: Free C trusted and rich email service. [quote][b]
cjay
Posted: Mon Dec 28, 2009 11:17 am Post subject: Re: mag blow tubes |
| planesmith(at)hotmail.com wrote: | In case it is not clear from the pictures C the air is ducted just over the outside not into the mags. As a side note depending on your engine monitoring system the "logical port" will be used for an electronic tach pickup.
Vern�
thanks guys, your support is invaluable, and timely, I had an answer before headin to the hangar!
