Posted: Mon Dec 21, 2009 12:20 pm Post subject: Card Compass Question |
Bro. Richard C
I was kidding C of course C about the ionization C etc. Cetc....
But C John's question was about engine instruments. I don't think a demagnetizer will hurt or affect them.
However C I wasn't referring to "any" electrical instruments (or a compass). It may very likely effect these things....only a true labratory test would tell.
As usual C the safe thing to always recommend is; check with the manufacturer!! They're the people that would know what is safe for their instrument to get next to C or not.
Mike Welch
Hotmail: Trusted email with powerful /' target='_new'>Sign up now. [quote][b]
Posted: Mon Dec 21, 2009 2:52 pm Post subject: Card Compass Question |
an old fashioned magnetic tachometer might be compromised.BB
On 21, Dec 2009, at 3:05 PM, Mike Welch wrote:
Quote: | >Anybody else got a simple explanation to answer my question, "Will the >degausser damage my electric engine instruments?"
Quote: | john h - Getting ready to exercise my right to flight, this afternoon.
Okay, okay, I'll be serious.
Electric temperature instruments are designed to reflect the difference in resistance and current, i.e. the electrical current generated by two dissimilar metals when exposed to temperature. The sending units are "thermisters"...temperature dependant resisters". The higher the temperature the lower the resistance, (due to the electrical current flowing between to dissimilar metals)
The gauge simply displays the present resistance, but it does so on a scale that is calibrated in temperature degrees.
It is very doubtful a demagnetizer can have any effect on electrical engine gauges, unless the demagnetizer is on, and momentarily passing near an instrument, affecting it's electrical activity....but the gauge would not experience any after effects.
IMHO.
Mike Welch
Hotmail: Trusted email with Microsoft’s powerful SPAtarget='_new'>Sign up now. Quote: |
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.howtocrimp.com">www.howtocrimp.com
tclongo(at)att.net Guest
Posted: Mon Dec 21, 2009 3:26 pm Post subject: Card Compass Question |
John/Gang: When I degaussed my MK III I had the compass out because I would
put it in the dash area and it would be of by 90 deg but all my other
instruments were in the dash. It did not affect any of them, did not think
it was a good idea to leave the compass in since it works on magnetic field,
also after I was done when I held compass inside where it mounted it now
read correctly so it was a good before and after test. Tom
Description: |
 Download |
Filename: |
winmail.dat |
Filesize: |
3.31 KB |
Downloaded: |
463 Time(s) |
elleryweld(at)aol.com Guest
Posted: Mon Dec 21, 2009 3:44 pm Post subject: Card Compass Question |
Tom
I wouldn't be so sure about it not affecting a Tach I had to replace that one because it was not reading correctly It might not have been affected by the degaussed you did to it, it may have been an inferior Tach I would rather believe
Ellery in Maine
Michael Sharp
Joined: 10 Jan 2006 Posts: 118 Location: Oak Grove, MO (Kansas City)
Posted: Mon Dec 21, 2009 3:48 pm Post subject: Card Compass Question |
Mike,
Now THAT’S Funny!
If you delouse it wrong it might create a tear in the time space continuum… and we can’t have that!!! LOL
Mike
The other one in Missouri
Do Not Archive..
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Mike Welch
Sent: Monday, December 21, 2009 1:00 PM
Subject: RE: Re: Card Compass Question
Quote: | If it works for you, I will probably try it on my mkIII. Wonder if it will
> damage engine instruments? Anybody know?
> john h
> mkIII
John, all others,
Yes, as the following formula shows, it will affect your ionization calibration gauge, especially if placed between, or right next to the photon mass emitter;
From the basic k-space formula, it follows immediately that we reconstruct an image simply by taking the inverse Fourier transform of the sampled data, viz.
Mike Welch
MkIII CX
Your E-mail and More On-the-Go. Get Windows Live Hotmail Free. [url=ow.%3c/a%3e%0d%0a%0d%0a%3cpre%3e%3cb%3e%3cfont%20size=2%20color=000000][/url]www.homebuilthelp.com href="http://www.matronics.com/contribution">http://www.matronics.com/cDralle, List Admin. to browse Archive Search more: href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List Web href="http://forums.matronics.com">http://forums.matronics.com ===========
_________________ The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike |
Posted: Mon Dec 21, 2009 3:56 pm Post subject: Card Compass Question |
Quote: | put it in the dash area and it would be of by 90 deg but all my other
Tom
Thanks, Tom/Gang:
That is the info I was looking for, someone that had actually degaussed
their fuselage and instrument panel, and the results they obtained with
electric engine instruments installed.
My mag compass has always been about 90 degrees off, but changes in size of
error as the aircraft is rotated around its axis.
I've flown the mkIII with an inop mag compass for nearly 3000 hours. Would
be nice to be able to use it to maintain my heading on long cross country
flights, rather than contantly looking down at my thigh to read the GPS. If
I am lucky, I can pick out a terrain feature, water tank, tower, barn, etc.,
and stay on course that way.
I'm getting antsy to take a trip in my little bird.
_________________ John Hauck
Titus, Alabama |
racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Mon Dec 21, 2009 4:26 pm Post subject: Re: Card Compass Question |
A degaussing coil CAN kill engine instruments that incorporate D’Arsonval meter movements (most do) as this mechanism depends on an internal magnet which you really would not want to de-magnetize. Digital meters? I dunno’.
“The D’Arsonval movement is a DC moving coil-type movement in which an electromagnetic core is suspended between the poles of a permanent magnet.”
_________________ Jerry King |
Herb Graff
Posted: Mon Dec 21, 2009 4:57 pm Post subject: Card Compass Question |
A tachometer is usually using an aluminum disc, activated by "Eddie Currents", induced by rotating magnets. Sooo, degaussing that thing, could of course ruin the accuracy.
Herb Graff
Mark III N246KT
In a message dated 12/21/2009 6:45:00 P.M. Eastern Standard Time, elleryweld(at)aol.com writes:
Ellery in Maine
Posted: Mon Dec 21, 2009 9:33 pm Post subject: Card Compass Question |
Hi Ellery, That 2” tach always read too high the whole time I owned the MK III that is why I put the tiny tach in there. I did not degauss the cage until the last 15 hrs or so I put on plane because I kept trying different compasses only to get the same result, even borrowed one that was fine in another plane and it was off too, that is when I degaussed the cage and it read correctly. How many hours do you have on it now? Probably too cold to fly now. Tom in warm Florida
<![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com]On Behalf Of Ellery Batchelder Jr
Sent: Monday, December 21, 2009 6:44 PM
Subject: Re: Re: Card Compass Question
Tom
Ellery in Maine
Sent: Mon, Dec 21, 2009 6:25 pm
Subject: RE: Re: Card Compass Question [quote]John/Gang: When I degaussed my MK III I had the compass out because I wouldput it in the dash area and it would be of by 90 deg but all my otherinstruments were in the dash. It did not affect any of them, did not thinkit was a good idea to leave the compass in since it works on magnetic field,also after I was done when I held compass inside where it mounted it nowread correctly so it was a good before and after test. Tom<![if !supportEmptyParas]> <![endif]>--
Posted: Tue Dec 22, 2009 10:54 am Post subject: Card Compass Question |
At 08:46 PM 12/20/09 -0800, you wrote:
Quote: |
I had gas welded the fuselage of the J-6, and each cluster joint was highly
magnetized. Don't know why that is, but it happens.
Richard,
It has to do with the iron atom being polarized. As you heat up the tubes
and add material to weld them together, it allows the iron atoms to
re-orient them selves charge wise relative to the north and south magnetic
poles. As the joint cools they remain in this orientation and the joint is
polarized. If you weld up your fuselage in a fixture that is in a fixed
location, then all the welded joints will have the same polarized direction
and therefore a much greater influence on a compass.
Since energy input (heating in this case) will re-orient the iron atom
polarity in the joint, the adding of energy to the joint can also
disorientate it. This is what the tape eraser or the degaussing coil does.
It raised the energy in the joint and overwhelms the influence of the
earth's magnetic poles and leaves the iron atom polarities in a random
distribution where they cancel out each other effect.
The Germans built the V1 buzz bombs in fixed fixtures. As result the
guidance system was over powered by the accumulated magnetism of the
fuselage structure and skin. To get away from this problem the assembly was
mounted on a turntable with men riding along and they beat on the structure
with wood mallets as the turntable was rotated in the earth's magnetic
field. This normalized the structure to the point so that their guidance
system was affective.
This can be demonstrated by taking a bolt and checking to see if it is
magnetic. Then holding the bolt in alignment between the north and south
poles, strike the end of the bolt with a hammer. After doing so you will
find the bolt is magnetized.
Snow and cold. On my way to pay for next years hangar rent and check on the
FireFly. It is nice to have a warm shop in the basement to work in. Kubota
is backed into the garage, and the rotary snow plow is mounted ready to go.
Hope everyone has a nice holiday.
Jack B. Hart FF004
Winchester, IN
Rick Lewis
Joined: 03 Jul 2007 Posts: 122 Location: Kingston, Tn.
Posted: Tue Dec 22, 2009 1:18 pm Post subject: Re: Card Compass Question |
Thanks Jack for the info. Next time I'm visiting the Kolb Factory I will see if I can get there welder, Dennis, to rotate his fixture, welding unit, and himself violently while making our cages. This would have to be video-ed of course for U-Tube. He's a pretty good old boy and would do most anything for us but this may be asking to much. You just don't really know though until you ask.
Rick Lewis
WHAT ABOUT IT DENNIS???????????
russkinne(at)mac.com Guest
Posted: Tue Dec 22, 2009 5:35 pm Post subject: Card Compass Question |
PatCoors (and our other other brands) now all come in aluminum cans.
Very similar to your aluminium ones
Russ
On Dec 21, 2009, at 7:16 AM, pj.ladd wrote:
Quote: | --> Kolb-List message posted by: "pj.ladd" <pj.ladd(at)btinternet.com (pj.ladd(at)btinternet.com)>
Wet compass problem?
just don`t put your Coors carrier next to the compass.
Cheers
Pathref="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.matronics.com/contribution">http://www.matronics.com/co -Matt Dralle, List ======================
http://www.matronics--> http://forums.matronics.com
Posted: Wed Dec 23, 2009 3:17 am Post subject: Card Compass Question |
Very similar to your aluminium ones>>
Very good Russ. LOL
i used to know a skipper who had a place to put his beer right next to the compass. He said that he had swung the compass with the beer in place so the deviation was known and built in.
Cheers
Pat
