Ammeter help
klburris
PostPosted: Sat Dec 19, 2009 11:25 pm    Post subject: Ammeter help Reply with quote
Folks;
Looking for some help in locating an ammeter installation kit of some sort, similar to B&C AEC9035-1 (discontinued). Ideally, it would have a current sensor such as a Tamura L08P050D15 (50 amp or a little smaller) with the required signal processing built in and come with an edgewise 50-0-50 (or 30-0-30) analog panel meter. I was surprised there was not something already made up (or at least easier to find) as I would think there would be a market for it. All help greatly appreciated. Thanks in advance.
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->
-- Keith
 Filesize:  4.29 KB
 Viewed:  12078 Time(s)
 Filesize:  7.65 KB
PostPosted: Sun Dec 20, 2009 7:33 am    Post subject: Ammeter help Reply with quote
At 01:18 AM 12/20/2009, you wrote:
Folks;
-- Keith
The AEC9035 was a proposed project that never
made it to the market. Too complex and too expensive
to build for the value delivered. Battery ammeters
are of limited utility and require a higher level
of understanding to be as useful as a simple LV
warning light and perhaps alternator load-meters.
In a system that's designed with attention to failure
mode effects analysis and complimented by (Plans-B
for critical failures), the ammeter offers no
useful data for operating the airplane. Its most
powerful function is as a diagnostics tool.
Hence, the market is small. We do offer a customized
kit for the installation of load meters on one
or dual alternator systems. These use the simple,
stable, accurate metallic shunts and simple, low
cost, pivot and jewel, d'Arsonval meters . . .
[img]cid:.0[/img]
See:
https://matronics.com/aeroelectric/Catalog/AEC/9007/9007.html
This approach proved the most elegant for ruggedness,
stability of calibration and cost of ownership when
the builder desires a panel display of current.
 Filesize:  70.14 KB
 Viewed:  12063 Time(s)
jonlaury
PostPosted: Sun Dec 20, 2009 12:05 pm    Post subject: Ammeter help Reply with quote
Keith,
This is a very tidy, versatile unit at an attractive price. Check out the user manual.
http://www.aircraftdigital.com/DIGITAL_AMMETER.html
PostPosted: Sun Dec 20, 2009 1:04 pm    Post subject: Ammeter help Reply with quote
At 02:02 PM 12/20/2009, you wrote:
Keith,
I've seen this (or similar) instruments used
as a loadmeter. You set it up to read a 100A
shunt (50mv = 100.0) and then size the shunt
to the full scale value of alternator. A little
label over the AMPS nomenclature to read LOAD
allows the single instrument to be switched to
multiple systems.
Bob . . . [quote][b]
klburris
PostPosted: Mon Dec 21, 2009 11:25 pm    Post subject: Ammeter help Reply with quote
Folks;
Thanks to all who replied-all of it useful. However, I need an explanation, most likely from Bob regarding ammeters.
Bob, I recently purchased rev 12 of the Connection. Page 4-9, last paragraph says:”… [b]A zero center, battery ammeter is the most desirable and should be the first electrical system instrument you install[/b]”.
Again, on page 7-12, last paragraph, you state: “…[b]if you plan only one electrical system instrument, make it a battery ammete[/b]r.”.
<![if !supportEmptyParas]> <![endif]>With the above being in your book and presumably vetted by yourself, I became confused when I read in your response to my original post, the following: “…Battery ammeters are of limited utility…” and again ”… the ammeter offers no useful data for operating the airplane…”<![if !supportEmptyParas]> <![endif]>I need to ask – did I completely misinterpret the book? I have Rev 12, which I am led to believe is the most current (no pun intended), or has your mind changed substantially since 12 was published? If that is the case, would you be willing to expound and elucidate on the subject of the necessity of ammeters in the cockpit? Thanks in advance.
<![if !supportLists]>n <![endif]>Keith
<![if !supportLists]>n <![endif]>PS – The book is great. I did not become aware of it until I attended an EAA SportAir class where it was highly recommended.
 Filesize:  4.29 KB
 Viewed:  12042 Time(s)
 Filesize:  7.65 KB
PostPosted: Tue Dec 22, 2009 7:01 am    Post subject: Ammeter help Reply with quote
At 01:21 AM 12/22/2009, you wrote:
Folks;
Connection. Page 4-9, last paragraph says:”… A
desirable and should be the first electrical system instrument you install”.
“…if you plan only one electrical system
instrument, make it a battery ammeter.”.
Keith
Aha! You read the book! I'm pleased that you've
not only noted this 'disconnect' but that you brought
it to the attention of the List . . . Oh yes, thank
you for the kind words. I'm pleased that you found the
work useful.
The chapter on instrumentation is one of the oldest
in the book . . . and is seriously in need of updating.
An explanation of what I've written (both times)
is in order.
Many, many moons ago, folks who where bolting the
first generators, batteries and rudimentary mobile
electro-whizzies to cars. They no doubt pondered the
best way to tell the operator of the automobile that
things were going well in the production, storage
and utilization of electrical energy.
If you had an opportunity to fill one hole on
the instrument panel with a electrical system
monitoring instrument in 1915, what would your
choice be? A voltmeter would be cool. 7 volts
or more with the engine running and all electro-
whizzies turned on would be a comforting thing
to know. But you could still have a soggy
battery. Hmmmm . . . well, we DO load test the
battery every time the car is started . . . but
then, there's not much advance warning of battery
aging . . .
Alternatives to voltmeters were ammeters . . .
simpler, much more rugged than voltmeters, but
where to install it? As it turns out, placing
a -0+ ammeter in series with the battery charge/
discharge line showed promise. If the ammeter
reads zero, then the battery is 'happy' (or
everything is turned off!). By 'happy' we mean that
bus voltage is high enough to keep the battery
from being discharged . . . and the battery has
taken on all the charge it can . . . AT THAT
PARTICULAR bus voltage. Hmmm . . . assuming that
the regulator's set-point is where it belongs
then the battery-ammeter's interpretation is
simple and accurate.
Now, you not only have a means by which day-to-
day wellness of the system can be watched,
you can compare today's ammeter actions after
engine-start with those you observed a month
ago . . . oh yeah, you DO take note of such
things while conducting a 3-page check-list,
right?
The battery ammeter was a useful and probably
the most practical thing you could do for a
machine that never leaves the ground.
But I'd bet not one driving citizen in 1000
understood and could accurately interpret what
the ammeter was telling them. I recall an
episode in my teenaged years where my favorite
mechanic was talking with a customer who just
drove up to complain that his battery "wasn't
charging". He had tried many times to explain
to the man that the battery would 'charge' only
when it needed to . . . and all other times
the ammeter should and would read zero.
So, in the context of my life-experiences
up to the time I wrote that chapter, yeah,
the battery ammeter was a pretty informative
device. Indeed, virtually all single engine
Cessna's sported this as the only electrical
system instrument for decades. In fact,
those-who-know-more-about-airplanes-than-we-do
have decreed:
FAR 23.1351(d) Instruments. A means must exist to indicate to
appropriate flight crewmembers the electric power system
quantities essential for safe operation.
(1) For normal, utility, and acrobatic category airplanes with direct
current systems, an ammeter that can be switched into each generator feeder
may be used and, if only one generator exists, the ammeter may be in the
battery feeder.
(2) For commuter category airplanes, the essential electric power system
quantities include the voltage and current supplied by each generator.
Charles Kettering would probably be pleased that
his ideas from 1912 were adopted as policy by an
agency of government. Problem is that while battery
ammeters are capable of displaying some important
information about electrical system function, they
have serious drawbacks. (1) the folks looking
at the instrument need to understand what the readings
mean based on some 'empathy' with how various components in
the system are behaving and (2) they're not easily
implemented in the Z-figures using SHUNTS because
we'd like NOT to bring alternator b-leads into the
cockpit if we can avoid it. Furhter, we don't want
to run starter current through a shunt that is
trying to resolve readings down 1 or 2 amps on
a 2" instrument.
20 years later . . .
In our collective deliberations as designers,
fabricators, operators and maintainers of our
own airplanes we've adopted policy and practice
that MONITORS battery condition for the purpose of
meeting design goals for a lot more than 30 minutes
of battery-only endurance. It's unlikely that
even the most attentive pilot is able to resolve
a 20% drop in battery capacity by observing the
behaviors of a battery ammeter.
Further, accurate voltmeters are much easier
to come by compared to Uncle Charles' time. Shucks,
about everyone with a digital display throws a
voltmeter in just for grins. Regulator set-points
have become much more stable too. So as it turns
out now, the single most valuable electrical system
instrumentation today is a simple low voltage warning
light that says "Hey Zeek! . . . you're in battery-only
ops. Time to go to plan-B!".
Assuming your plan-B is well crafted and MAINTAINED,
you may confidently continue flight to airport of
intended destination without breaking a sweat.
This confidence comes with a price of admission.
You need to understand how all those things in your
airplane's electrical system work. What demands they
have for electrical power and what utility they
offer or comfortable termination of flight. You
then take it upon yourself to make sure those demands
are satisfied if and when the alternator quits. Even
with Z-13/8, you have greater ability or power electro-
whizzies if the big dog goes to sleep . . . but it
is STILL LIMITED.
The short answer is: The battery ammeter as a single
display of electrical system functionality can be and
has been quite useful for nearly 100 years. I
suggest that present day goals and expectations
for system performance would raise the eyebrows if
not elicit guffaws from our brethren who thought
their 1965 C-182 was the greatest thing on wings.
So without trashing what generators, flooded batteries,
venturi powered t/b, and yes . . . battery ammeters
offered us in the past . . . I'll suggest it's time to set
them aside in favor of more efficient and certainly more
capable recipes for success.
If your chunk of panel-glass comes with a hall-effect
sensor, you can certainly count the flow of electrons
in any wire you wish . . . including a battery cable.
No matter where you decide to install it, know that
the readings it offers are useful only if the observer
understands WHY they say what they do. The same observer
must be capable of sorting through the permutations that
resolve a sense of electrical system health. I.e.,
the ammeter is first a DIAGNOSTIC tool and a second a
poor warning tool. That little flashing LV WARNING
light is the elegant tool for flight operations.
Revision 13 to the book will have a whole new chapter
on monitoring the health of the electrical system.
PostPosted: Tue Dec 22, 2009 9:48 am    Post subject: Re: Ammeter help Reply with quote
Keith,
The most important electrical instrument is the voltmeter. If the voltage is above 14, then you know that the alternator is working and that the battery is being charged. If the voltage is below 14 and is slowly dropping, then the alternator is not working. Having a voltmeter or other low voltage warning is essential. An ammeter is optional.
The location of the current shunt or sensor is a matter of personal preference. The ammeter that you are considering, 30-0-30, measures current going into or out of the battery. Current should usually only flow into the battery (above zero indication) except when the engine is off or perhaps when short term heavy loads are turned on, such as motors. The information provided by this type of ammeter is not very useful because the voltmeter already tells if the battery is being charged or not.
Another possible location for the current shunt is in the alternator B lead. Current in the B lead only flows in one direction, so the meter would not have a below-zero scale. Since the alternator normally supplies current to the aircraft (not the battery), knowing this current is useful because you know that the alternator is working; and you also know how much total current the aircraft is using for charging the battery and operating the electrical equipment. Once the battery is fully charged, not much current flows into it. Then the ammeter indicates current being used by other electrical loads. If the alternator fails, the ammeter will read zero and you will not know how much current the aircraft is draining from the battery.
A third possible location for the ammeter shunt is in the wire supplying power to the Main Power Distribution Bus. The meter would not have a below-zero scale. In this location the ammeter will tell you exactly how much current is being used by your electrical equipment. You could turn on one device at a time to determine its current consumption. Wired like this, the ammeter will not tell you if the current is coming from the battery or from the alternator (but the voltmeter will).
It is up to the builder to decide if an ammeter is useful and if so, then where in the circuit to install it.
Joe
Joe Gores
jonlaury
PostPosted: Tue Dec 22, 2009 4:58 pm    Post subject: Ammeter Help Reply with quote
Keith thanks for bringing this up.
I was going to install an ammeter in my bird until this subject arose and and I really started thinking about what useful info the meter would provide.
I'm building an all electric plane and thought it would be useful to have an ammeter on board to aid in alternator-out conditions. I intend to conduct battery capacity tests, at my full E-bus load, between annuals so that, with an ammeter indicating load on the battery(s), I would have a reasonable idea of my electrical endurance during alt-out. My first inclination would be to land at the first opportunity. But I might choose a more convenient airport further away if I knew my battery(s) would last with a margin.
I suppose that a voltmeter might be more useful because I know at what voltage critical components become inop. Electronic ignition will work down to 7 volts, but at a cost in amps. Ditto electronic fuel injection with an even heavier amp load to drive injectors. Haven't tested my fuel pumps but I suspect the motor would be an amp hog as well at low volts.
So with the knowledge of battery ampacity from semi-annual tests and a knowledge of my full E-bus load, I would have a ballpark of my electrical endurance during alt-out and the rate at which the voltmeter was dropping would be a cross check.
OK! I now think that a voltmeter is more useful for determining electrical endurance than an ammeter that just tells me my burn rate, which I already know from system architecture calcs. An ammeter is similar to a fuel flow meter. Knowing how much fuel you're burning is not particularly useful without knowing how much fuel you have. If you can see your fuel level, you can change throttle settings accordingly. Ditto on electricity.
PostPosted: Tue Dec 22, 2009 7:50 pm    Post subject: Ammeter Help Reply with quote
Which is the basis for crafting Plan-B. When the
LV warning light comes on, it seems more useful to
KNOW in advance what equipment items you plan to
run. It's equally useful to KNOW in advance that
the battery was recently determined to contain
the energy YOU have set down in design goals
for YOUR plan B . . . of course this would include
any margins that contribute to your confidence
levels.
If you have an electrically dependent engine then
perhaps your plans should include a second alternator
capable of supporting the engine . . .
It's inarguable that a voltmeter COULD be used to
assist you in worrying about what ever energy remains
in the battery. I'll simply suggest this is something
akin having discovered that you may not have accurately
accounted for fuel necessary to make the leg . . .
whereupon cursing those lousy fuel gages becomes a
distraction to your piloting duties.
Watching the voltmeter with an alternator dead
is no less a distraction . . .
Well considered. May I further suggest that you
are best served by having a well crafted Plan-B
paired with a confidence that your well maintained
equipment will perform as designed?
So, when the light comes on, you need only
configure for plan-B ops and arrange to be on the
ground within parameters set by your well
considered and accurately achieved design goals.
Once on the ground, you'll discover that troubleshooting
the system requires voltmeters and/or ammeters
to supplement any such indicators that already
exist on the panel.
jonlaury
PostPosted: Wed Dec 23, 2009 7:51 am    Post subject: Ammeter Help Reply with quote
" If you have an electrically dependent engine then
capable of supporting the engine . . ." I'm working on it. The available vacumn pad on my Franklin turns at about 0.8:1 so the B&C 20 amp aux alternator won't put out enough juice below 2400 eng rpm to keep my E-bus alive. The B&C "stack 'o pancakes" 30 amp model for Continentals has some promise of fitting in a fuel pump drive hole on the accessory case.Even without a spare alternator, I'm VFR comfortable with the triple redundancy of an alternator and two batteriesto keep the fires lit.
PostPosted: Wed Dec 23, 2009 7:58 am    Post subject: Ammeter Help Reply with quote
lit.
Understand . . . let's strive to base your 'comfort'
on knowing as much about watt-seconds in the batteries
as you have gallons in the tanks.
