grosseair(at)comcast.net Guest
Posted: Sat Dec 19, 2009 1:58 pm Post subject: Lycoming IO-360 engine mounts |
I have an engine mount that was designed for a Lycoming IO-360 C1D6 200
hp with the angle valves. I'd like to mount an IO-360 B1E 180 hp
straight valve engine on it in an experimental aircraft. I know both
engines take Type I 30 degree dynafocal mounts, but what I'm not sure of
is if the bolt pattern is the same. I think it should be the same, but
does anyone know for sure? Is there anything else I should be concerned
about?
John Grosse
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
