flysrv10(at)gmail.com Guest
Posted: Tue Apr 11, 2006 5:02 pm Post subject: Flap hing bracket bearings |
Hello Everyone. I am in process of installing my flaps in
anticipation of flying the 10 REALLY soon. I purchased the QB wings
and the hinge brackets were of course installed. The holes in the
flap brackets are larger than an AN$ bolt which tells me that there
is supposed to be a bearing inserted in them.
I cannot however locate any bearings or bushing on the parts list or
reference to them in the Manual. Can someone tell me if they are
supposed to come installed in the brackets (perhaps they forgot to
install them) or a part no so that I can call Van and ask for them.
The Van guys are traveling and Bruce (at Vans) was unable to help. I
am so close that I can taste the first flight and don't want to wait
a couple of more days for the guys at Van to return.
Thanks.
Do not Archive.
Kermanj Rob
robkermanj at gmail dot com
Tim(at)MyRV10.com Guest
Posted: Tue Apr 11, 2006 5:22 pm Post subject: Flap hing bracket bearings |
Yep, the brackets get bushings. You'll need to carefully use a reamer
on those hole so they are nice and snug when you press them in. They
should be in some parts bag. The plans show them, so check the
list against the part number. FYI: You can't have the bushings
installed until the bottom skins go on, or the skin won't fit over
the brackets.
Rob Kermanj wrote:
Thanks.
Do not Archive.
Kermanj Rob
Posted: Tue Apr 11, 2006 6:14 pm Post subject: Flap hing bracket bearings |
Thanks for the quick reply. What kind of bushing are they? Bronze?
Brass? aluminum? Do they need to be fabricated by me?
I have checked the plans and cannot find ANY references (in
related/logical sections) to the part and installation instruction.
Can you point me to the right place in the manual?
My bottom skin is installed and as I said, I am assembling the plane
for it's first flight.
Thanks again.
Do not archive.
On 4/11/06, Tim Olson <Tim(at)myrv10.com> wrote:
the brackets.
> Thanks.
> Do not Archive.
> Kermanj Rob
Posted: Tue Apr 11, 2006 7:23 pm Post subject: Flap hing bracket bearings |
I think the're Bronze, and they aren't fabricated, but they
come complete.
I see them on page 22-8, BUSHING 1/4x3/8x.250.
Rob Kermanj wrote:
Thanks again.
Do not archive.
> the brackets.
> Tim Olson - RV-10 N104CD - Flying
> do not archive
>> Thanks.
>> Do not Archive.
>> Kermanj Rob
Rick S.
Posted: Tue Apr 11, 2006 8:13 pm Post subject: Flap hing bracket bearings |
Rob,
They are or at least they look like bronze. You should have 6 of them somewhere with your kit. They look like little bronze donuts. I used sandpaper on a drill bit and lapped the hinge bracket just a little. I used a C-Clamp and two pieces of wood to press them into the bracket, once the one dise was fluch I used a socket on one side to allow the bushing to get to it's final position, they are wider than the hinge bracket and center on the hole with equal reveal on each side.
Rick S.
40185
Fuse/Finish
_________________ Rick S.
RV-10
40185 |
Posted: Wed Apr 12, 2006 1:45 am Post subject: Flap hing bracket bearings |
Thanks again. I will look for them.
come complete.
> Thanks again.
> Do not archive.
>> the brackets.
>> do not archive
>>> Thanks.
>>> Do not Archive.
>>> Kermanj Rob
Posted: Wed Apr 12, 2006 3:24 am Post subject: Flap hing bracket bearings |
Thank you all for your response. I found the reference to these
bushings on a revision sheet.
On 4/12/06, Rob Kermanj <flysrv10(at)gmail.com> wrote:
| Quote: | Thanks again. I will look for them.
> come complete.
> do not archive
> > Thanks again.
> > Do not archive.
> >> the brackets.
> >> do not archive
> >>> Thanks.
> >>> Do not Archive.
> >>> Kermanj Rob
rvreynolds(at)macs.net Guest
Posted: Wed Apr 12, 2006 4:43 am Post subject: Flap hing bracket bearings |
They are in Bag 1255, 6X BUSHING 1/4X3/8X.250 FLAP BUSHING
Richard Reynolds
On Apr 12, 2006, at 5:43 AM, Rob Kermanj wrote:
> come complete.
> do not archive
>> Thanks again.
>> Do not archive.
>>> reamer
>>> They
>>> the brackets.
>>> do not archive
>>>> wings
>>>> there
>>>> list or
>>>> them.
>>>> help. I
>>>> wait
>>>> Thanks.
>>>> Do not Archive.
>>>> Kermanj Rob
ninepapa(at)bendbroadband Guest
Posted: Wed Apr 12, 2006 6:34 am Post subject: Flap hing bracket bearings |
Page 22-8
Posted: Wed Apr 12, 2006 11:02 am Post subject: Flap hing bracket bearings |
Thank you. I did not get them in my Kit but was able to locate them
locally. Thanks again.
Do not archive.
On 4/12/06, John Hilger <ninepapa(at)bendbroadband.com> wrote:
Page 22-8
