Skis required
jdmcbean(at)kitfoxaircraf
PostPosted: Fri Dec 11, 2009 2:54 pm    Post subject: Skis required Reply with quote
This may be a little pre-mature.. but we have a new set of wheel penetrating skis becoming available.. They are Composite and are currently setup of the Grove gear (will be for tube shortly) Total weight is approximately 14 lbs per ski and can be setup for 600-6, 800-6 or 8.50-6 tires. Give a call for more info.
Fly Safe !!
John & Debra McBean
Ph 208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
 Filesize:  182.05 KB
 Viewed:  6341 Time(s)
Av8r3400
PostPosted: Fri Dec 11, 2009 3:44 pm    Post subject: Re: Skis required Reply with quote
$$ How much? $$
Av8r3400
Kitfox Model IV-1200 W/912UL & IVO
Kitfox Model IV-1050 W/912UL & Warp
YouTube Videos
dave
PostPosted: Sat Dec 12, 2009 1:51 am    Post subject: Re: Skis required Reply with quote
THose look like the one a guy makes here in Canada and if so about 1500$ or so.
http://www.turbulence.ca/an/skisan.html#History
Here is used ones for 450 a pair.
http://rotaxaircraft.com/forum/viewtopic.php?f=27&t=155
I have 4130 Skis available. You send the specs and size wanted for other than 3/4 " axle size on Standard tube gear.
8 to 12 " wide and 48 to 60" long.
Prices starting at 850$ for straight skis with UHMW bottoms.
Considering Wheels Skis for King fox and other 21 " tires as they seem the most popular tire going.
21 " tires available for 35 $ each
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
davedawe(at)msn.com
PostPosted: Sat Dec 12, 2009 4:45 am    Post subject: Skis required Reply with quote
 Hi
I have a fiberglass set (3) new C asking $350
Dave
Kitfox ll
[quote] Subject: Re: Skis required
Date: Sat C 12 Dec 2009 01:51:44 -0800
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com>
Rotax Dealer C Ontario Canada
http://www.cfisher.com/
Awesome *New Forum *
http://www.youtube.com/profile_videos?user=kitfoxflyer
http://forums.matronics.com/viewtopic.php?p=277283#277283
Get a great deal on Windows 7 and see how it works the way you want. See the Windows 7 offers now.
msm_9949(at)yahoo.com
PostPosted: Sun Dec 13, 2009 5:47 pm    Post subject: Skis required Reply with quote
Dave,
Could you send pics and specs? I assume you bought them for your model 2. Did you use them? How did they work out?
I'm interested.
Marco Menezes N99KX
Model 2 582-90 C-Box 3:1 w/clutch
Hersey, Michigan
--- On Sat, 12/12/09, David Dawe <davedawe(at)msn.com> wrote:
Subject: RE: Re: Skis required
To: "kitfox-list(at)matronics.com" <kitfox-list(at)matronics.com>
Date: Saturday, December 12, 2009, 7:10 AM
Hi
I have a fiberglass set (3) new, asking $350
Dave
Kitfox ll
Date: Sat, 12 Dec 2009 01:51:44 -0800
Rotax Dealer, Ontario Canada
ollow target=_blank>www.aeroelectric.com
/" rel=nofollow target=_blank>www.buildersbooks.com
ofollow target=_blank>www.homebuilthelp.com
llow target=_blank>http://www.matronics.com/contribution
el=nofollow target=_blank>http://www.matronics.com/Navigator?Kitfox-List
et=_blank>http://forums.matronics.com
dave
PostPosted: Tue Dec 15, 2009 3:22 am    Post subject: Re: Skis required Reply with quote
Marco, pics and videos are all posted .
Dave
[quote="msm_9949(at)yahoo.com"]Dave,
I'm interested.
Marco Menezes N99KX
Hersey, Michigan
To: "kitfox-list(at)matronics.com" <kitfox>
Hi
Dave
Kitfox ll
--> Kitfox-List message posted by: "dave" <dave>
dave
PostPosted: Mon Jan 18, 2010 5:04 am    Post subject: Re: Skis required Reply with quote
Pictures posted here and videos to follow
http://rotaxaircraft.com/forum/viewtopic.php?f=27&t=167
Kitfox Skis
4130 tube 12 x 48 "
2 main skis with UHMW bottoms $850.00
Tail ski with UHMW $150.00
These come unpainted. Powder coated add 150$ for a set of three.
You rig the cables, if you want the cables and bungees all ready for you to bolt on add $75 a ski
you will get 1/8" crust cutter cable, safety cables , mil spec bungees. Bolts and tabs to bolt on.
The skis in pics I can ship out same day for $1100.00 plus crate and shipping. IN Ontario that will be about 150 $ or so.
Or you can Pick up Near London Ontario.
Down payment today and your skis will be ready within a week.
Custom made skis for most planes.
