Vortex Generators
Goto page 1, 2  Next
galinhdz(at)gmail.com
PostPosted: Sun Dec 13, 2009 4:11 pm    Post subject: Vortex Generators Reply with quote
All;
I installed Vortex generators on the bottom of my KIS4 elevator. It made no difference on climb or cruise that I could tell but on a BIG difference on approach and landing. I had a significant increase in elevator authority at low airspeed and could keep the nose at a higher attitude than before all the way to touchdown. This was especially evident when I easily kept the nose off the runway for a good 500ft after touchdown. The nose wheel finally touched down at a significantly slower speed than I had been able to do before. Before the VG installation, no matter how hard I tried to keep the nose wheel off the runway, as soon as the mains touched the nose came firmly down.
I used the STOLSPEED Vortex Generators available at Aircraft Spruce: http://www.aircraftspruce.com/catalog/appages/stolspeed.php
The hardest part of the entire installation was trimming the provided 3M dual side tape once I painted them. Surprised)
Galin
N819PR
sstearns2(at)yahoo.com
PostPosted: Sun Dec 13, 2009 4:35 pm    Post subject: Vortex Generators Reply with quote
Where did you put them? On the leading edge or back near the elevator?
Sounds like a good idea.
Scott
--- On Sun, 12/13/09, Galin Hernandez <galinhdz(at)gmail.com> wrote:
Subject: Vortex Generators
To: kis-list(at)matronics.com
Date: Sunday, December 13, 2009, 4:09 PM
All;
Galin
N819PR
ollow target=_blank>www.aeroelectric.com
/" rel=nofollow target=_blank>www.buildersbooks.com
ofollow target=_blank>www.homebuilthelp.com
llow target=_blank>http://www.matronics.com/contribution
=nofollow target=_blank>http://www.matronics.com/Navigator?KIS-List
et=_blank>http://forums.matronics.com
PostPosted: Sun Dec 13, 2009 5:00 pm    Post subject: Vortex Generators Reply with quote
Scott;
They go on the rear of the tail with the VGs 4" in front of the gap between the elevator and the stabilizer. Here is an image of where they go looking up at the tail. I only had 4 VGs left over when the job was completed. I will take a picture and post it on my web page. Remember, they go on the BOTTOM of the tail.
Galin
N819PR
On Sun, Dec 13, 2009 at 6:26 PM, Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)> wrote:
Scott
--- On Sun, 12/13/09, Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)> wrote:
From: Galin Hernandez <galinhdz(at)gmail.com (galinhdz(at)gmail.com)>
All;
Galin
N819PR
_blank">www.aeroelectric.com
.com" target="_blank">www.buildersbooks.com
et="_blank">http://www.matronics.com/Navigator?KIS-List
 Filesize:  16.53 KB
 Viewed:  21464 Time(s)
PostPosted: Sun Dec 13, 2009 5:59 pm    Post subject: Vortex Generators Reply with quote
I made the elevator on my two place with an extra 2" of chord to get more pitch control. The VGs are a good idea too. That seems to me to be the perfect place for them.
Scott
Subject: Re: Vortex Generators
Date: Sunday, December 13, 2009, 4:58 PM
Scott;
Galin
N819PR
Scott
All;
Galin
N819PR
PostPosted: Sun Dec 13, 2009 9:57 pm    Post subject: Vortex Generators Reply with quote
Mine was already built so I didn't have that option. Surprised)
Galin
N819PR
On Sun, Dec 13, 2009 at 7:58 PM, Scott Stearns <sstearns2(at)yahoo.com (sstearns2(at)yahoo.com)> wrote:
[quote] I made the elevator on my two place with an extra 2" of chord to get more pitch control.  The VGs are a good idea too.  That seems to me to be the perfect place for them.
Scott
Scott;
Galin
N819PR
On Sun, Dec 13, 2009 at 6:26 PM, Scott Stearns <sstearns2(at)yahoo.com> wrote:
Scott
All;
Galin
N819PR
kentpyle(at)iland.net
PostPosted: Mon Dec 14, 2009 9:55 am    Post subject: Vortex Generators Reply with quote
Galin, I had the same results. The elevator seemed soft upon trying to flair. With the installation of the generators, the elevator seems much firmed. I glued mine in place with shoe goo. Kent
w
PostPosted: Mon Dec 14, 2009 1:13 pm    Post subject: Vortex Generators Reply with quote
Shoe-goo, now THAT is an idea. Was it a messy or a fairly clean install? I totally agree that the elevator seems much firmer at the low speed and at the flare. I am sold on them.
Galin
N819PR
On Mon, Dec 14, 2009 at 11:54 AM, Kent Pyle <kentpyle(at)iland.net (kentpyle(at)iland.net)> wrote:
[quote] Galin, I had the same results.  The elevator seemed soft upon trying to flair.  With the installation of the generators, the elevator seems much firmed.  I glued mine in place with shoe goo.  Kent
w
PostPosted: Tue Dec 15, 2009 9:00 am    Post subject: Vortex Generators Reply with quote
Galin, any of the goo's obtained at the hardware store should work. I put the goo on a popsickle stick so I could control the amount. Keep the goo in the center of the generator so when pressed in place it will create a mess. A piece of paper towel will help control any mess. ( I had very little smearing. Kent
76papa(at)dishmail.net
PostPosted: Tue Dec 15, 2009 9:33 am    Post subject: Vortex Generators Reply with quote
Do you lose any speed in cruise with them?
Al
w
PostPosted: Tue Dec 15, 2009 11:10 am    Post subject: Vortex Generators Reply with quote
Al;
Not that I can tell but I haven't made any tests for actual data.
Galin
N819PR
On Tue, Dec 15, 2009 at 11:27 AM, Alfred Rosa <76papa(at)dishmail.net (76papa(at)dishmail.net)> wrote:
[quote] Do you lose any speed in cruise with them?
Al
w
"_blank">www.aeroelectric.com
.com/" target="_blank">www.buildersbooks.com
PostPosted: Tue Dec 15, 2009 11:55 am    Post subject: Vortex Generators Reply with quote
Not that I can determine. Kent
Flyinisfun(at)aol.com
PostPosted: Tue Dec 15, 2009 4:54 pm    Post subject: Vortex Generators Reply with quote
This is Jesse Wright and have been reading the results of V.T. generators on the elevator stab. underneath. This has been one of my problems in a flair. The elevator is so soft that I loose where I am at with it and over control because I can's feel anything. Has anyone tried them on the 2 place and would they be installed about the same location, about 4 inches forward of the hinge line?
  Jesse
bakerocb
PostPosted: Tue Dec 15, 2009 8:12 pm    Post subject: Vortex Generators Reply with quote
12/15/2009
Hello Jesse, What are you doing with your engine RPM during the final stages
of the approach and during the flare?
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
PostPosted: Wed Dec 16, 2009 12:00 pm    Post subject: Vortex Generators Reply with quote
Jesse;
As far as I can tell they would also be about 4" forward of the hinge line. But I would contact STOLSPEED (stolspeed(at)gmail.com (stolspeed(at)gmail.com)) directly and ask them just to be sure.
Galin
N819PR
On Tue, Dec 15, 2009 at 6:44 PM, <Flyinisfun(at)aol.com (Flyinisfun(at)aol.com)> wrote:
[quote] This is Jesse Wright and have been reading the results of V.T. generators on the elevator stab. underneath.  This has been one of my problems in a flair.  The elevator is so soft that I loose where I am at with it and over control because I can's feel anything.  Has anyone tried them on the 2 place and would they be installed about the same location, about 4 inches forward of the hinge line?
                  Jesse
PostPosted: Wed Dec 16, 2009 4:02 pm    Post subject: Vortex Generators Reply with quote
Jessie, not being an aeronautical engineer, I can not say for sure, however, I think they would work just fine for your two place. The four inch placement may or may not be the correct spacing. Read the instruction and they should tell you the correct placement. The bottom of the surface is the correct placement. Kent
randy.ott(at)gmail.com
PostPosted: Mon Dec 21, 2009 10:45 am    Post subject: Vortex Generators Reply with quote
I put the vortex generators on my Tr-1.
Big big difference! Wow , I now have elavator authority at slow speeds.
I was only able to do 4 touch and goes because of fog moving in, but I was able to land and stop in tthe first 1000 feet of runway for
The first time ever! I placed the leading edge of the generator 4 inches forward of the elevator gap. I have
The O320 engine configuration. More testing to come... Initial results are fantastic!
Randy
N96BT. Tr1
On Dec 16, 2009, at 3:40 PM, "Kent Pyle" <kentpyle(at)iland.net (kentpyle(at)iland.net)> wrote:
[quote] Jessie, not being an aeronautical engineer, I can not say for sure, however, I think they would work just fine for your two place. The four inch placement may or may not be the correct spacing. Read the instruction and they should tell you the correct placement. The bottom of the surface is the correct placement. Kent
ftyoder(at)yoderbuilt.com
PostPosted: Mon Dec 21, 2009 12:23 pm    Post subject: Vortex Generators Reply with quote
Randy,
Do you have the original elevator size or did you build in the aprox 1" cord extension?
I have the extension and have plenty of elevator authority. On slow speed landings I run out of aileron control with a cross wind,
but still have plenty of elevator.
If I didn't have the extension I think I would try the Vortex Generators before rebuilding the elevator.
I also regularly use 'OC's' procedure of adding a little power on short final, to kill a high sink rate.
N52TY TR-1
PostPosted: Mon Dec 21, 2009 2:30 pm    Post subject: Vortex Generators Reply with quote
Yes I have the original elevator!
On Dec 21, 2009, at 12:19 PM, "F. Tim Yoder" <ftyoder(at)yoderbuilt.com (ftyoder(at)yoderbuilt.com)> wrote:
[quote] Randy,
N52TY TR-1
PostPosted: Mon Dec 21, 2009 2:44 pm    Post subject: Vortex Generators Reply with quote
Randy, good news! I thought this was simpler than adding to the elevator cord. Kent
PostPosted: Thu Dec 24, 2009 5:36 am    Post subject: Vortex Generators Reply with quote
All;
I put pictures of the VG installation on my web page.
http://puertoricoflyer.com/cgi-bin/photoalbum/view_photo/2529251
http://puertoricoflyer.com/cgi-bin/photoalbum/view_photo/2529250
Galin
N819PR
On Mon, Dec 21, 2009 at 4:36 PM, Kent Pyle <kentpyle(at)iland.net (kentpyle(at)iland.net)> wrote:
[quote] Randy, good news!  I thought this was simpler than adding to the elevator cord.  Kent
Goto page 1, 2  Next
Page 1 of 2
