jchang10
Posted: Fri Dec 11, 2009 3:52 pm Post subject: Front Baffle screw access |
This is my 3rd attempt. sorry for any repeat posts.
How did you guys get access to the screws that hold the front baffle, right underneath the prop governor? I am still trying to figure out how to drill it, let alone get a screw driver to it.
Hopefully, the image was attached okay below!
Also, are there any recommendations for exactly how to align the CB-1001A baffle in relation to the cowl? The plans don't give much info here. The plans also don't seem to indicate any baffle material for this area. I am wondering if I shoot for a tight fit or leave a gap for the cowl to come on and off?
Thanks!
Jae
40533
52.43 KB |
2518 Time(s) |
dlm46007(at)cox.net Guest
Posted: Fri Dec 11, 2009 5:43 pm Post subject: Front Baffle screw access |
A 90 angle drill and short threaded drill bits. Why hot put SS cap screws in
there with an Allen wrench.
Posted: Fri Dec 11, 2009 6:23 pm Post subject: Front Baffle screw access |
I second the angle drill. Also, I use a #3 bolt & a universal socket.
Jesse Saint
Saint Aviation
jesse(at)saintaviation.com
352-427-0285
screws in
jchang10
Posted: Sat Dec 12, 2009 11:03 am Post subject: Front Baffle screw access |
ok, thanks for the replies. looks like i'll replace that screw with
something easier to access.
jae
40533
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
