Posted: Fri Dec 11, 2009 6:24 am Post subject: water heat for the cockpit |
Hi guys,
I'm looking for a best installation of a coolant heater for the cabin.
My heat muff works o.k. down to freezing, but I'm looking at components
that might offer better cabin warming. Perhaps you Canadians have
a list of parts that better describes what you used and
how you made connections within the cabin.
Even pictures would be nice.
ter_turn(at)yahoo.com Guest
Posted: Fri Dec 11, 2009 7:43 am Post subject: water heat for the cockpit |
Larry, I'm working on a liquid cooled engine also and am curious as to why you don't pipe warm radiator air through the floor of the cockpit?
Terry
601XL Plans
To: stratus-list <stratus-list(at)matronics.com>; zenith601-list(at)matronics.com; zenith701801-list(at)matronics.com
Sent: Fri, December 11, 2009 8:19:12 AM
Subject: water heat for the cockpit
flyboy3847(at)onecommail. Guest
Posted: Fri Dec 11, 2009 8:22 am Post subject: water heat for the cockpit |
Hey Larry,
We have a heater box with a core in it. It's attached to the outside of the
left lower firewall. Dennis made it from 4130 sheet steel .025 of there
abouts. We then drilled holes in the firewall and devised a bottom door
that shuts the heater off in the summer and lets air in the winter. Ask
Dennis. I think he has pics. If not I'll take some and send them to you.
Leroy
bryanmmartin
Posted: Fri Dec 11, 2009 8:33 am Post subject: water heat for the cockpit |
If you are going to use exhaust air from the regular radiator, you would have to make sure that only fresh air was coming in to the radiator. With the radiator mounted below the belly, as most are, you would get a lot of air from the engine compartment passing through the radiator and possibly even engine exhaust gasses.
Better to use a separate heater core. The bypass hose is a convenient source for heater flow. My setup just recirculates the cabin air through the heater, I get enough fresh air leaking in from the aft fuselage through the rudder cable tunnel. Air leaks out through the gap below the canopy frame.
On Dec 11, 2009, at 10:27 AM, Terry Turnquist wrote:
| Quote: | Larry, I'm working on a liquid cooled engine also and am curious as to why you don't pipe warm radiator air through the floor of the cockpit?
Terry
601XL Plans
_________________ --
Bryan Martin
do not archive. |
