Paul A. Franz, P.E.
Posted: Tue Dec 08, 2009 5:43 pm Post subject: Leaded gasoline and two stroke oil recommendation |
On Tue, December 8, 2009 3:33 pm, WurlyBird wrote:
clip clip
| Quote: | My buddy who has many thousand hours behind and in front of 2 strokes told me to use
the air cooled 2 stroke oil because even though it is water cooled it burns like an
air cooled as far as temps go. It is much higher in performance then what the water
cooled 2 stroke oil is meant for.
In the tests that Lockwood did with Rotax and Pennzoil-Quaker State it looks to me
like there is little difference between the Outboard formulation (water cooled) and
the Air cooled formulation:
<http://www.ultralightnews.com/features/oiltest.htm> (link courtesy of Guy)
Both performed much better than a mineral oil or synthetic in comparison. Their tests
were done using premix 50:1 with premium unleaded gasoline (no alcohol). They pointed
out that the results would likely have been better using a synthetic with a leaner
(100:1) premix but were concerned about corrosion due to the minimal amount of
residual oil left on bearing surfaces when the engine was not running for extended
periods asis often the case with airplanes left sitting in hangars for days or even
longer at a time.
As I understand it, fouling that occurs on the piston rings will reduce the conductive
heat transfer coefficient between the piston and the cylinder wall causing the piston
to be too hot. Also fouling on the upper surface of the piston and in the cylinder
head effectively raises the compression ratio which could lead to detonation and
consequently severe engine damage. Lead in gasoline causes more deposits and it seems
to me that two strokes are more vulnerable to damage due to these deposits. There are
additives that can be used to help with this problem and probably you should carry
enough to treat the Avgas you have to buy on a cross country trip.
Those Lockwood/Pennzoil tests didn't compare their product to other formulations so I
would say they are probably not the only choice but appear to be satisfactory two
stroke oils for Rotax engines.
One of our list members, "Leonard Perry" <akflyer_2000(at)yahoo.com> has a great deal of
experience with Rotax two strokes in airplanes and in snowmobiles and that is in
Alaska. He has recommended and uses a Citgo two stroke oil. Besides being good, it
also offers price advantage.
Here's the reference sheet for SUPERGARD® Sea & Snow® 2-Cycle Engine Oil which is a
synthetic blend. Use when TC-W3 oils are not recommended.
<http://www.docs.citgo.com/msds_pi/10008.pdf>
I think Lenny uses SUPERGARD® Air Cooled 2-Cycle Engine Oil.
SUPERGARD Air Cooled is a premium performance lubricant designed for use in all
air-cooled two stroke cycle engines.
<http://www.docs.citgo.com/msds_pi/10009.pdf>
I am inclined to use one of those simply because Lenny said so. I would consider
getting an anti-lead fouling additive to mix with Avgas (100LL) when you must use it.
Many are sold with the TCP designation which originally stood for tricresylphospate. I
believe the toxicity is so high that it is no longer marketed but functional
substitutes are still called TCP. Hopefully Lenny will comment to verify what I've
said.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
"Great nations which fail to meet their responsibilities are consigned
to the dust bin of history. We grew from that small, weak republic
which had as its assets spirit, optimism, faith in God and an
unshakeable belief that free men and women could govern themselves
wisely. We became the leader of the free world, an example for all
those who cherish freedom. If we are to continue to be that example --
if we are to preserve our own freedom -- we must understand those who
would dominate us and deal with them with determination."
-- Ronald Reagan
"Honor, justice, and humanity, forbid us tamely to surrender that
freedom which we received from our gallant ancestors, and which our
innocent posterity have a right to receive from us. We cannot endure
the infamy and guilt of resigning succeeding generations to that
wretchedness which inevitably awaits them if we basely entail
hereditary bondage on them."
-- Thomas Jefferson, Declaration of the Causes and Necessities of
Taking up Arms, 6 July 1775
"American conservatives are those who seek to conserve our nation's
First Principles, those who advocate for individual liberty,
constitutional limits on government and the judiciary, and the
promotion of free enterprise, strong national defense and
traditional American values."
-- Mark Alexander - Publisher, PatriotPost.US
A government which robs Peter to pay Paul can always depend on the
support of Paul.
-- George Bernard Shaw
"With respect to the two words 'general welfare,' I have always
regarded them as qualified by the detail of powers connected with
them. To take them in a literal and unlimited sense would be a
metamorphosis of the Constitution into a character which there is a
host of proofs was not contemplated by its creators."
--James Madison
"I am commonly opposed to those who modestly assume the rank of
champions of liberty, and make a very patriotic noise about the people.
It is the stale artifice which has duped the world a thousand times,
and yet, though detected, it is still successful. I love liberty as
well as anybody. I am proud of it, as the true title of our people to
distinction above others; but ... I would guard it by making the laws
strong enough to protect it."
-- Fisher Ames, letter to George Richard Minot, 1789
"Never in the history of the world has there been a situation so bad
that the government can't make it worse."
-- Unknown
"We, the members of the New Republican Party, believe that the
preservation and enhancement of the values that strengthen and
protect individual freedom, family life, communities and
neighborhoods and the liberty of our beloved nation should be at the
heart of any legislative or political program presented to the
American people."
-- Ronald Wilson Reagan (1911 - 2004)
"Man, once surrendering his reason, has no remaining guard against
absurdities the most monstrous, and like a ship without rudder, is the
sport of every wind. With such persons, gullibility, which they call
faith, takes the helm from the hand of reason and the mind becomes a
wreck."
-- Thomas Jefferson
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
akflyer
Posted: Wed Dec 09, 2009 7:26 am Post subject: Re: Leaded gasoline and two stroke oil recommendation |
Here's the reference sheet for SUPERGARD� Sea & Snow� 2-Cycle Engine Oil which is a
<http>
Paul, this is what I use. In fact, I just bought another 40 gallons of it, so I should be good to go for awhile.
We use it in the planes, boats and snow machines with great results. No issues to date, with 10s of thousands of collective miles and hours and not one oil related issue. At 12 bucks a gallon, I am sticking with it.
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
