Tom Jones
Posted: Mon Dec 07, 2009 6:11 am Post subject: 503 oil injection retrofit |
I want to install an oil injection system on a 503 DCDI. It has an electric starter on mag end. There is a hole in the center of the cover plate above the starter that appears to be for the oil pump drive shaft.
This engine I purchased new in 1994 and it has never had an oil injection installed on it. There are no holes for the injection in the intake manifolds.
I am wondering how big a job it is and what parts I need and where to find them.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Blumax008(at)aol.com Guest
Posted: Mon Dec 07, 2009 6:48 am Post subject: 503 oil injection retrofit |
In a message dated 12/7/2009 9:12:57 A.M. Eastern Standard Time, nahsikhs(at)elltel.net writes:
| Quote: | | I want to install an oil injection system on a 503 DCDI. |
Take it from an old hand (very old hand) at ultralights & 2-sicle motors...DO NOT install an oil drive system. Keep mixing your fuel & oil. It's much more reliable & a hell of a lot less trouble. You're just asking for trouble.
Bill Catalina
Class of '78
aoldman(at)xtra.co.nz Guest
Posted: Mon Dec 07, 2009 9:33 pm Post subject: 503 oil injection retrofit |
Totaly agree. Keep it simple . Mixe your own fuel.
Downunder
MK111c
503
Tom Jones
Posted: Tue Dec 08, 2009 5:45 am Post subject: Re: 503 oil injection retrofit |
I agree. Premixing is simple and bullet proof. My Kitfox is bare bones and I like to keep it that way as much as I can.
My main reason for wanting to convert to the oil injection is to reduce carbon build up. I have to taxi over a mile each way to take off and again after landing. Also there is a University flight school at my local airport so there are almost always five or six or more planes doing touch and goes or stop and goes so I sit there for ever waiting for an opening to take off.
At 50 hours there was plenty of carbon in the piston ring grooves.
People flying 503s with oil injection tell me they go 150 hours or more and the pistons are still clean as a whistle. I think my carbon build up is due to all that low rpm taxiing and idling at 50:1 oil ratio. It about broke my bank account just to buy the gaskets to do the de-carbon work. Rotax has become pretty proud of their parts.
Classic IV
Ellensburg, WA |
Posted: Tue Dec 08, 2009 6:42 am Post subject: 503 oil injection retrofit |
In a message dated 12/8/2009 8:47:34 A.M. Eastern Standard Time, nahsikhs(at)elltel.net writes:
| Quote: | People flying 503s with oil injection tell me they go 150 hours or more and the pistons are still clean as a whistle.
Well, good luck on installing that oil injection.
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Tue Dec 08, 2009 7:05 am Post subject: Re: 503 oil injection retrofit |
| Tom Jones wrote: | I agree. Premixing is simple and bullet proof. My Kitfox is bare bones and I like to keep it that way as much as I can.
People flying 503s with oil injection tell me they go 150 hours or more and the pistons are still clean as a whistle. I think my carbon build up is due to all that low rpm taxiing and idling at 50:1 oil ratio. It about broke my bank account just to buy the gaskets to do the de-carbon work. Rotax has become pretty proud of their parts. |
The main thing you have to check for if you want to fit the oil injection is if your crankshaft has the square driver hole in the end of the shaft. Check that first before you buy anything. The oil pump drive shaft fits into this hole and it's required to use the pump.
A rotax dealer might be able to tell you at what serial no. this was introduced, but I'd still visually check this anyway. You can't miss it - it's a big square hole right on the end of the crank.
If it doesn't have that, you're SOL (unless you buy an updated crankshaft).
I always ran 50:1 premix as well, mostly just because I liked the simplicity and I'm always really anal about gas that I put into my planes (so didn't ever forget to mix the oil in). But everyone I've talked to who runs the oil injection has reported zero problems. The leaning of the oil at idle is another benifit.....
LS
_________________ LS
Titan II SS |
Tom Jones
Posted: Tue Dec 08, 2009 8:06 am Post subject: Re: 503 oil injection retrofit |
| Quote: | | A rotax dealer might be able to tell you at what serial no. this was introduced, but I'd still visually check this anyway. You can't miss it - it's a big square hole right on the end of the crank. |
Thanks for the heads up. According to the serial number my engine has the injection drive shaft provision in the end of the crank.
I have an injection pump located and will check the local Ski Doo shop for a price on a reservoir system. The Aircraft engine rotax shops want 2 hunskies for the tank, filter and line.
The last thing I need to figure out now is the injection ports in the intake manifolds. Is that a special nozzle or is it just a an open barbed tube that I could drill a hole in the manifold and install?
Classic IV
Ellensburg, WA |
lucien
Posted: Tue Dec 08, 2009 8:28 am Post subject: Re: 503 oil injection retrofit |
| Tom Jones wrote: | | Quote: | | A rotax dealer might be able to tell you at what serial no. this was introduced, but I'd still visually check this anyway. You can't miss it - it's a big square hole right on the end of the crank. |
The last thing I need to figure out now is the injection ports in the intake manifolds. Is that a special nozzle or is it just a an open barbed tube that I could drill a hole in the manifold and install? |
Yeah this was a change that came along with the oil injection. The newer intake manifolds already have the fittings in them, the older ones don't have them.
I don't see why if you're good with drilling and tapping that you couldn't drill and tap the holes yourself. I'd be sure and use the rotax fittings tho, since you can be sure they have just the right orifice size for metering the right amount of oil, etc. And I'd make sure to place the holes where they are on the new manifolds.
Otherwise you have to get new manifolds, surely super pricey from Rotax.
But I've never modded the older manifolds so I don't know of any gotchas. I'd talk it over with a rotax mechanic like Thom or any of the other folks on here. Or ask the dealer (maybe you can trade in your old manifolds?)
LS
Titan II SS |
thesupe(at)hotmail.com Guest
Posted: Tue Dec 08, 2009 9:53 am Post subject: 503 oil injection retrofit |
Tom C my old CPS catalog shows a coolant recovery bottle which they say can also be used as a oil injection reservoir. Part # 1609 price was $14.95 (in 2002) Maybe they still sell it. Jim Chuk
| Quote: | Subject: Re: 503 oil injection retrofit
Date: Tue C 8 Dec 2009 08:06:36 -0800
To: rotaxengines-list(at)matronics.com
--> RotaxEngines-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net>
> A rotax dealer might be able to tell you at what serial no. this was introduced C but I'd still visually check this anyway. You can't miss it - it's a big square hole right on the end of the crank.
I have an injection pump located and will check the local Ski Doo shop for a price on a reservoir system. The Aircraft engine rotax shops want 2 hunskies for the tank C filter and line.
The last thing I need to figure out now is the injection ports in the intake manifolds. Is that a special nozzle or is it just a an open barbed tube that I could drill a hole in the manifold and install.
Tom Jones
Classic IV
503 Rotax C 72 inch Two blade Warp
Ellensburg C WA
http://forums.matronics.com/viewtopic.php?p=276695#276695
Windows LiveT Hotmail is faster and more secure than ever. Learn more. |
79.87 KB |
12404 Time(s) |
capedavis(at)yahoo.com Guest
Posted: Tue Dec 08, 2009 1:57 pm Post subject: 503 oil injection retrofit |
Tom, I flew a 503 490hrs on premix using pensoil for air cooled engines had it rebuilt before I sold it . The rebuilder said almost no carbon !
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Sent: Tue, December 8, 2009 8:45:44 AM
--> RotaxEngines-List message posted by: "Tom Jones" <nahsikhs(at)elltel.net (nahsikhs(at)elltel.net)>
My main reason for wanting to convert to the oil injection is to reduce carbon build up. I have to taxi over a mile each way to take off and land. At 50 hours there was plenty of carbon in the piston ring grooves and it about broke my bank account just to buy the gaskets to do the de-carbon work. Rotax has become pretty proud of their parts.
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p=276680#276680
www.homebuip; &n================
dave
Posted: Tue Dec 08, 2009 4:25 pm Post subject: Re: 503 oil injection retrofit |
Tom,
Call Bob Robertson 1-866-418-4164
he sells a ton of the oil injection change over kits.
You will not beat him in service and parts.
He makes everything you need in one package.
Oil Injection is far superior to pre mix. And although you have a few more parts they have a 99.99999% reliability.
Your plugs will last 100 hours easy now .
It works, it really does.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
Posted: Wed Dec 09, 2009 10:10 am Post subject: 503 oil injection retrofit |
In a message dated 12/8/2009 4:58:18 P.M. Eastern Standard Time, capedavis(at)yahoo.com writes:
| Quote: | Tom, I flew a 503 490hrs on premix using pensoil for air cooled engines had it rebuilt before I sold it . The rebuilder said almost no carbon !
Well said Chris but I think the "other side" is well entrenched in their thinking too. We'd have as hard a time changing their minds as they would have changing ours. So if they're happy, so be it.
That being said...I've been flying 2 cycle ultralights since 1978, have multiple thousands of hours in them & my favorite principle is K.I.S.S...and I think we all know what that means. My next best saying is..If it ain't broke, don't fix it.
The less crap you have hanging on a motor, the less crap you have to deal with...especially at tear down & inspection. Some people have so much unnecessary crap on their planes it would take hours if not days getting it all off just to get to a problem.
Now think of an ultralight pilot broke down in the bush...100 degrees, 95% humidity, mosquitos, no-see-ums, sweat pouring into your eyes...and a motor loaded with crap that you have to remove (and replace) to get to your problem...or...that may be the cause of your problem.
My best running trike is a DFS with a simple 503, pull start & manual choke with an E.I.S.
Get my drift?
Tom Jones
Posted: Wed Dec 09, 2009 1:34 pm Post subject: Re: 503 oil injection retrofit |
Anyone premixing with an engine that came with oil injection want to trade me their manifolds for a pair without the injection ports? I'll pay shipping plus $20.
Classic IV
Ellensburg, WA |
