Dual Battery Contactor
rv8iator
PostPosted: Mon Dec 07, 2009 10:05 am    Post subject: Dual Battery Contactor Reply with quote
Just came across a new (to me) product from Cole Hersee. This is a battery contatctor with a dual battery voltage sensor and control module added on. From the literature this appears to be a simple solution to automatic isolation and control of a dual battery, single alternator electrical system.
Take a look at the lit. and comment. Upon first blush this appears to supplant the dual contactor with a single contactor and a voltage sense and control circuit.
http://www.colehersee.com/pdf/hot_feed/D-617_SmartBatteryIso.pdf
Chris Stone
RV-8
Newberg, OR
Dual_Battery_contactor.pdf
 Filename:  Dual_Battery_contactor.pdf
 Filesize:  2.68 MB
 Downloaded:  580 Time(s)
C. Stone (RV8iator)
skywagon
PostPosted: Mon Dec 07, 2009 3:37 pm    Post subject: Dual Battery Contactor Reply with quote
Chris,
Thanks for the tip and lead on a great solution for preserving alternators
from high stress loads...
David
C185D
Grants Pass, OR
dgolden(at)golden-consult
PostPosted: Mon Dec 07, 2009 4:49 pm    Post subject: Dual Battery Contactor Reply with quote
control circuit.
<snip>
This looks very much like what Yandina (marine electronics) calls a combiner. I
have one on my 1976 GMC motor home. It is installed across the factory installed
isolator (diode). The difference that I see, is that the combiner we're using on
our motor homes works both directions (i.e. chassis -> house and house ->
chassis). What this means is that if we are on the road it charges the house
battery(s) and if we are docked with shore power (or the generator running), the
chassis battery will also be charged.
It works as advertised and I'm happy with it. I have the Cobiner 100 (good for a
100 amp alternator). It lists at $79.95 and on sale for $59.95 which is what I paid.
Dennis
Dennis Golden
Golden Consulting Services, Inc.
PostPosted: Mon Dec 07, 2009 6:44 pm    Post subject: Dual Battery Contactor Reply with quote
It appears to be a "smart" contactor that doesn't close
until the upstream system voltage exceeds 13.2 volts.
It appears also that you can force the contactor closed
for cranking assist.
I.e. just like a plain vanilla aux battery contactor with
an aux battery management module built in. You'd still
have a manually switched battery master contactor.
(o o)
===========o00o=(_)=o00o=========
< Go ahead, make my day . . . >
< show me where I'm wrong. >
PostPosted: Tue Dec 08, 2009 9:02 am    Post subject: Dual Battery Contactor Reply with quote
At 05:34 PM 12/7/2009, you wrote:
Chris,
alternators from high stress loads...
Not sure there is "benefit" to be realized for shielding
an alternator from "high stress" loads.
As converters of mechanical to electrical energy, these
devices have specifications. They also tend to be designed
for a particular marketplace task. The prudent designers,
manufacturers and installers of such devices understand the
capabilities and limits. That understanding is factored
into satisfaction of design goals and establishment
of maintenance programs.
Subscribing to the notion of "stress mitigation" on
an alternator by programming the manner in which loads
are applied to the machine suggests that design goals,
capabilities and limits are suspect or perhaps known
to be poorly married.
The aux battery management module for OBAM aircraft was
first proposed in an article I wrote for Sport Aviation
many moons ago. The intent of this device was to provide
automatic management of an auxiliary battery included
to power flight critical electro-whizzies. The ABMM
prevented connection of the aux battery to the system
unless bus voltage was high enough to avoid discharging
the battery (i.e. alternator on line). Hence the 13.0
volt switchpoint calibration for closing the contactor.
The corollary idea was that the ABMM opens the contactor
automatically during alternator shut down or failure
thus isolating the aux battery and preserving contained
energy for a specific task.
The product being discussed appears to perform in
precisely the same manner where it's desirable
to isolate a RV vehicle battery from recreational
electro-whizzies battery unless the alternator
is available to service BOTH batteries.
This is a PARTICULAR case where the recreational
battery is EXPECTED to be deeply discharged. Now,
if the vehicle battery has not been abused while
parked, then the bus is expected to rise above
13.0 (or 13.2) volts seconds after the engine
starts. This device would spare the alternator
from "high stress" loads only if BOTH batteries are
deeply discharged. But even then, I can't imagine
that the bus will stay below 13.2 volts for very
long even if the vehicle battery was drawn down
completely and the engine was started with jumper cables.
Finally, irrespective of number of batteries and
no matter how you've abused the batteries, your
alternator should be EXPECTED to happily deliver
full rated output for an indefinite period of time.
If not, there's something wrong with the selection
of alternator or the manner in which it has been
installed.
rv8iator
PostPosted: Tue Dec 08, 2009 10:22 am    Post subject: Dual Battery Contactor Reply with quote
This brings to mind a question as to what happens to the alternator when the load placed on it exceeds it's output capacity? Will the output voltage start to drop as capacity is exceeded? If overload is continued are the diodes the weak link in the chain? Will the diodes fail before overheating of the stator windings? What is the common failure mode?
Chris Stone
RV-8
C. Stone (RV8iator)
longg(at)pjm.com
PostPosted: Tue Dec 08, 2009 12:43 pm    Post subject: Dual Battery Contactor Reply with quote
Chris,
As Bob noted, the alternator will continue to output at its rated capacity as long as the regulator is demanding it. Each alternator should be able to run at its rated capacity for N hours before failing (some calculus test performed at the factory).
The bigger question is what are you doing in your cockpit while you are waiting for the alternator to explode and your bus architecture to melt down? Answer, you should be activating your fire gear. No, a diode won't immediately melt if you drop to 8 volts, but by then you should have your contingency plan in action. Should you experience 1 or more failures in any situation, you should start shedding load and if the alternator seems to be a problem, shut it down.
Two heads are better than one and one good battery and two alternators are better than 2-3 batteries any day.
Glenn
PostPosted: Tue Dec 08, 2009 4:11 pm    Post subject: Dual Battery Contactor Reply with quote
At 02:40 PM 12/8/2009, you wrote:
Chris,
In the aviation world we test alternators/generators/motors to rated
loads and worst case temperatures to meet specifications. If the customer
observes published limits, they have a high probability of seeing
the laboratory experience repeated in the field.
Exactly. I'll re-enforce that idea with the notion that
except for unanticipated failure, NOTHING that goes on
in your electrical system should be a surprise. I've written
often about failure mode effects analysis wherein all
normal and abnormal operating conditions are deduced,
studied for deleterious effect to be mitigated by design.
The ONLY way you're going to beat the (at)#$(at)# out of your
alternator is to jump-start with a DEAD battery and
then launch into the blue with all your electro-whizzies
turned on. Until the battery's recharge demands begin to
taper, the alternator will be running flat-out. The duration
of this event is generally a few tens of minutes at the
most. All other times, I would hope that the builder has
PREDICTED what loads can be serviced under any/all
conditions and is operating the airplane accordingly.
Chapter 17 in the 'Connection speaks to this process
in detail. I've also suggested that the hierarchy of
importance for surviving the flight experience stacks
up like this:(a) airframe, (b) owner/builder/pilot
(c) powerplant (d) all other things.
The significance of the second item goes far beyond
the knowledge and skills needed AFTER the wheels are
up. There is a great deal that can be done in the
craftsmanship, understanding and decisions made long
before the airplane leaves the shop . . . like due
diligence to the study of category (d).
[quote]Glenn
rv8iator
PostPosted: Wed Dec 09, 2009 6:20 am    Post subject: Dual Battery Contactor Reply with quote
Great thread! Thanks.
Chris
[quote]>
>Chris,
>Glenn
C. Stone (RV8iator)
PostPosted: Wed Dec 09, 2009 9:00 am    Post subject: Re: Dual Battery Contactor Reply with quote
"Two heads are better than one and one good battery and two alternators are better than 2-3 batteries any day." And Bob Nuckolls replied, "Exactly. I'll re-enforce that idea . . . . ."
I am not disagreeing but have questions:
Suppose that it is impractical to install two alternators on an electrically dependent engine in a VFR airplane. If a battery is properly maintained and periodically tested for capacity, is its risk of failure high enough to warrant a backup battery?
What if a cell in the battery shorts out? Will the alternator keep working? If no, then will the battery still have enough voltage and contain enough energy to supply the ignition system until a landing can be made? I assume yes, but do not know.
A small backup battery will provide peace of mind, knowing that there is an alternate current path in case of a failed terminal or connection in the main circuit. But is the benefit worth the extra weight?
Joe
Joe Gores
Sam
PostPosted: Wed Dec 09, 2009 9:24 am    Post subject: Dual Battery Contactor Reply with quote
Joe, I have an electrically dependent VFR plane, and I concluded that yes, it is worth it= to have the second battery.  I like to fly long cross countrys and from time to time I am over very lonely territory.-
Did you do a full electrical analysis of your devices for takeoff, climb, cruise, descent, landing, etc?  That should point out what you need. I'm going to try attaching one for you, if it doesnt go I will e-mail it to you offline.  It's not perfect, but you get the idea.
I wound up using two batteries of the same size.  I figured in the long run that would simplify things for me.
Regards.
Sam Hoskins
www.samhoskins.blogspot.com
On Wed, Dec 9, 2009 at 11:00 AM, user9253 <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)> wrote:
--> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com (fran4sew(at)banyanol.com)>
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=276838#276838
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
finley.xls
 Filename:  finley.xls
 Filesize:  24.5 KB
 Downloaded:  449 Time(s)
Sam Hoskins
longg(at)pjm.com
PostPosted: Wed Dec 09, 2009 9:48 am    Post subject: Dual Battery Contactor Reply with quote
Joe,
Fair question. Certainly not every installation (especially air-motive
types) will lend themselves to dual alternators. The second best backup
would be a second battery. As far as the alternator is concerned, let's
say for example the airplane started under its own power and the battery
had an issue as you flew along. The alternator would still generate
charging energy because it is already excited, however the battery is no
longer benefiting as it will not absorb the charge.
You may have experienced this in your car. You start your car, drive to
work and upon leaving work your car doesn't start, yes? Same deal. This
is why the landfill is full of old batteries and Pep
Boys is rich.
I find this retarded, but did you ever see someone jump start an
airplane and then take off into the wild blue yonder with their
alternator charging a junk battery? Happens every day. I, like you am
electrically dependent and my pet peeve is to ensure I have a battery
that will hold a starting charge for at least two weeks and perform at
normal or below temperatures when requested. It should, on occasion pass
Bob's recommended battery stress test.
A respectable RG battery will not have a catastrophic failure but will
go bad over time. Is the benefit of the extra battery worth it? How many
hours have you flown on one battery with your teeth grinding? One may
never fail, but two will make you feel better. For me two alternators
and one well maintained battery offers ample security and redundancy.
If I had a Subaru or other electrically dependent alternative air-motive
engine without second alt , I'd have a second battery, period.
Get out and fly!
Glenn
longg(at)pjm.com
PostPosted: Wed Dec 09, 2009 9:51 am    Post subject: Dual Battery Contactor Reply with quote
Sam,
FYI, great job on the plane! I’ve always liked this design. Maybe next build.
Glenn
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Sam Hoskins
Sent: Wednesday, December 09, 2009 12:22 PM
To: aeroelectric-list
Subject: Re: Re: Dual Battery Contactor
Regards.
Sam Hoskins
Joe
Joe Gores
le, List Admin.
PostPosted: Wed Dec 09, 2009 10:28 am    Post subject: Dual Battery Contactor Reply with quote
"Risk of failure high enough" is not quantified.
Even if it WERE quantified, suppose I tell you that
configuration A offers a 3.5 x 10^-6 failure rate
and configuration B is 9.3 x 10^-6 failure rate.
Hmmm . . . obviously configuration A is the better
choice.
Now, suppose the difference in dollars to install
configuration A versus B is $1600 and perhaps adds
8 pounds to the airplane's empty weight. How would
that influence your decision?
The point is that design goals for your project
are personal to you . . . a host of trade-offs
for operation, performance, convenience, weight,
initial costs, maintenance costs, etc. etc.
Flooded batteries USED to suffer cell shorts . . .
but only after they had been abused to internal
self-destruction in ground vehicles. Had those
batteries been maintained for aircraft service,
their ability to crank the engine would still
be quite strong when the replacement decision
is made. Further, their plates would still have
a good grip on the chunks of stuff that were
responsible for shorted cells.
The RG battery is physically incapable of
shorting. Active materials in plate pockets
is held captive by insulating materials. See
sequence of photos at:
http://aeroelectric.com/Pictures/Batteries/Concorde/
Here you see cast plates, fiberglas mat material,
porous jacket, which are placed around the negative
plate of a "buttered" plate. Alternating (+) and (-)
plates are sorted, stacked and weighed to match
cell-to-cell capacity. Finally, matched stacks are
installed in a battery case ready to attach inter-
cell connectors. There's no way that any (+) plate
is going to become shorted to a (-) plate in
any cell.
If it DID happen, the alternator would go into
current limited full output which would destroy remaining
"good" cells in what has to be an abused and flooded
battery. Since you're not going to use a flooded
battery . . . and you're going to implement a
battery maintenance program . . . shorted cells
are of zero concern.
What are you willing to "pay" for peace of mind?
None of us can properly advise you in that
decision. What we can offer is the proposition
that when you assemble a failure tolerant system
with good craftsmanship, likelihood of more than
one failure on any single tank full of fuel is
exceedingly remote.
PostPosted: Wed Dec 09, 2009 10:54 am    Post subject: Re: Dual Battery Contactor Reply with quote
To Sam and Glenn,
Thanks for your responses. And Sam, I received your Excel spreadsheet. I asked the above questions about dual batteries on behalf of my brother who is building a Corvair powered 601XL. I am building a RV-12 whose Rotax engine has dual independent ignition systems (except for the rotating permanent magnets). It seems that this is one of those situations where there is more than one way to do something. If it is someone else's airplane, then 1 battery is enough. But if you are going to be flying in the plane, then two batteries are better. Very Happy
Joe Gores
PostPosted: Wed Dec 09, 2009 12:45 pm    Post subject: Re: Dual Battery Contactor Reply with quote
Thanks for the reply, Bob. From your explanation, it seems highly unlikely that the battery will short out. The alternator is the main power source and the battery is a backup power source (for a limited amount of time). The Essential Bus switch is the backup for the main power contactor. The wires and terminals are not backed up, but they can be checked during pre-flight.
One could ask that same question about a BRS parachute. The weight and cost penalty are great for a system that will most likely never be used. But just think of the peace of mind that system offers. These are personal decisions that each builder has to make.
Joe
Joe Gores
PostPosted: Wed Dec 09, 2009 6:28 pm    Post subject: Dual Battery Contactor Reply with quote
Wires and terminals properly installed have about the same
order of reliability as prop bolts. This means proper tools
matched to terminals applied to wires that don't wave around
in the wind. Generally not difficult to accomplish.
What engine/alternator combination are you contemplating
and what devices are required for continued engine operations?
Yup, that's the universe we live in . . .
MauleDriver(at)nc.rr.com
PostPosted: Wed Dec 09, 2009 7:10 pm    Post subject: Dual Battery Contactor Reply with quote
And thanks Bob for teaching so many of us how to use "proper tools
in the wind".
"Generally not difficult to accomplish" Sounds so simple and yet this
pilot/unauthorized repair station managed to smoke a glider cockpit with
astoundingly poor wiring. Yes, a glider. I'm doing better now.
Thanks!
