LOOKING FOR RIGHT ANGLE BNC CONNECTOR
Geoff Heap
PostPosted: Mon Nov 30, 2009 7:11 am    Post subject: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
Bob or anyone. I cannot find a right angle BNC connector for my Icom A210. I know this sounds easy but let me explain. I have a Fuel Header tank behind my panel, against the firewall. When my radio is mounted there is only about 1”-1½” space at the rear of the radio available for the Coax cable so I need a Right angle BNC connector. NOTE I did not say adaptor. The Radio needs a Male PUSH/PULL connector. Not the twist on twist off. (Those are easy to find). With the radio came a straight BNC connector. I can push that in and add an adaptor but the combined length of the two is too much. What I need is a right angle PUSH/PULL Male or even a Tee connection Male-female/female. Cruising around the web I can't seem to find one. Surely they exist? Your assistance would be real nice.....Geoff
PostPosted: Mon Nov 30, 2009 9:02 am    Post subject: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
The connector your looking for is:
http://www.aeroelectric.com/Pictures/Connectors/Coax/TED_9-30-10_A.jpg
http://www.aeroelectric.com/Pictures/Connectors/Coax/Ted_9-30-10.jpg
Did a search on TED, "9-30-10", and connector and got 24,000 hits.
( It's MATRONICS FUND RAISER MONTH! )
( Do your part to keep this marvelous )
( tool sharp and available to all our )
( brothers in the OBAM aviation )
( community. )
PaulR
PostPosted: Mon Nov 30, 2009 9:17 am    Post subject: Re: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
Is it possible to find one of these that is a crimp on? I need to replace the one on the back of my GTX-327 and I'd rather have a crimp on than a solder connection.
Paul
Paul Rose
N417PR
RV-9A
Geoff Heap
PostPosted: Mon Nov 30, 2009 10:09 am    Post subject: Re: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
Bob. This is the straight PUSH/PULL that I said that I already have. If I now connect a right angle adapter to it, its too long to fit into my panel. I need a 90 degree version of the 9-30-10. Then I can slide my radio into place, but only just. Go to the link below and see the fourth picture. If that tee connector was a PUSH/PULL male instead of a Twist on/off male it would work.
http://www.youravcablestore.com/rca-to-bnc-adapter.html
 Filesize:  7.43 KB
 Viewed:  38930 Time(s)
berkut13(at)berkut13.com
PostPosted: Mon Nov 30, 2009 11:28 am    Post subject: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
As Bob's picture shows, the 9-30-10 IS a 90-degree connector - coax comes
out the small opening shown at the top and that would be 90-degrees from the
connector that mates with the radio. What you are describing doesn't add
up. I have the Icom A200 installed (same tray).
Are you using the radio mounting tray? If so, then it has one of these
connectors natively installed in the tray and it IS already 90-degree. If
you have the tray installed in the panel, and the panel on the plane, that
is as far forward at it gets. Sliding the radio into the tray changes
nothing dimensionally.
Are you describing "sliding" the mounting tray into position in the panel?
If you are, I think you are going to have to "make" some room on that header
tank, re-position the radio tray, or change to a shorter radio.
A picture or two here might help us all understand what your specific
problem is.
James Redmon
Berkut #013/Race 13
www.berkut13.com
Geoff Heap
PostPosted: Mon Nov 30, 2009 12:05 pm    Post subject: Re: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
Thanks James. I just spoke to “support” at Iacom. I was directed to the installation guide for the a200. This guide uses the fitting that Bob suggested. However, they showed how to solder the connector, which made clear to me the fact that the small opening IS the 90° connection. I thought that Bob was offering me another straight connector. For the A210, IACOM switched from the part that you have James to the straight one that I have. Problem solved now. Thanks to all…Geoff
Speedy11(at)aol.com
PostPosted: Sat Dec 12, 2009 6:50 am    Post subject: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
Use a 90 degree BNC adapter if you like, but I recommended against using them. I had a tight spot for an antenna connection and used a 90 degree BNC. I had very poor radio transmissions. I sent the radio back to Garmin for repairs, I changed the coax and recrimped new connectors, I checked the antenna - nothing seemed to help. I finally decided to try removing the 90 degree and ran the coax straight into the antenna. Instantly the problem was solved. I don't know what the problem was with the 90 BNC, but I recommend never using them.
But, I'm just an ignorant layman. Just ask my wife.
Stan Sutterfield
I found a 90deg replacement it's a little expensive at $25 ea. Nice thing there
is no soldering required. I also found a few sites that have it in stock.
ianxbrown
PostPosted: Sat Dec 12, 2009 8:05 am    Post subject: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
Why would 90 degree connectors all be faulty because one person had one? It's probably not a good use of time to do a survey of the membership of this list, but I for one use a 90 degree BNC connector to my com antenna and my GPS antenna and both are fine. I suspect, Stan, that you had a dud and that there is nothing fundamentally wrong with 90 degree, or any other connector for that matter, that a manufacturer puts time, tooling, testing effort into.
Ian Brown
Noplugs
PostPosted: Sun Dec 13, 2009 8:14 am    Post subject: Re: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
The 90Deg replacement I mentioned previously is not a the common of the shelf BNC 90deg adapter. It is a replacement for the TED 9-30-10. I have them in my Terra radio trays. I see that ICOM has a straight version also, I understand they are used with several manufacture's equipment like King. So IF you have the "TED 9-30-10", the DBA-600 looks to be a nice clean application replacement for the "TED 9-30-10" Look at my attachment it shows both connectors and you can see it is not the common BNC 90deg adapter.
DBA-600%20Brochure.pdf
 Filename:  DBA-600%20Brochure.pdf
 Filesize:  88.16 KB
 Downloaded:  1281 Time(s)
Speedy11(at)aol.com
PostPosted: Sun Dec 13, 2009 3:54 pm    Post subject: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
Ian,
You are correct.
For my aircraft, I will never again use a 90 degree BNC connector.  I will find another way to make the desired connection(s).
Stan Sutterfield
Ian Brown
-----Original Message-----
Subject: Re: LOOKING FOR RIGHT ANGLE BNC CONNECTOR
Stan Sutterfield
rv8iator
PostPosted: Mon Dec 14, 2009 7:39 am    Post subject: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
For RF connectors of all types try...
90 degree
http://www.aaarfproducts.com/index.asp?PageAction=VIEWPROD&ProdID=43
RF connectors
http://www.pasternack.com/
Cable and connectors
http://www.fccable.com/
Chris Stone
RV-8
I found a 90deg replacement it's a little expensive at $25 ea. Nice thing there is no soldering required. I also found a few sites that have it in stock.
http://www.keenzo.com/showproduct.asp?ID=1274376
http://www.texomajet.com/ProductDisplay.aspx?CatID=148&SubCatID=869&CatName=RF%20CONNECTORS&SubCatName=ALL%20TRAY%20MOUNT
http://www.allaeroparts.com/ProductDisplay.aspx?CatID=148&SubCatID=869&CatName=RF%20CONNECTORS&SubCatName=ALL%20TRAY%20MOUNT
http://forums.matronics.com/viewtopic.php?p 77253#277253
http://forums.matronics.com//files/dba_600percent20brochure_381.pdf
C. Stone (RV8iator)
Geoff Heap
PostPosted: Mon Dec 14, 2009 7:55 am    Post subject: Re: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
My 10 cents is that the 9-30-10 is not an adaptor. The item in the A200 installation picture attached is a 9-30-10 from lanepilot.com. $25.00 with shipping. (or $52 from ICOM)
This part was a supplied item with the A200. They stopped when they came out with the A210.
Now a question.
I have soldered the connection in two places as shown.
When I solder the antenna connector on the other end. Should I also solder the braid to the connector body or should I separate the braid and ground it to the airframe or should I trim it back and not solder it anywhere. (I soldered braid to connector body)
Reason I'm asking is that all I'm getting from the speaker is a hissing sound. To keep it simple I started by hooking up the speaker only. nothing else. I suspect my coaxial wire (RG58 A/U) because when I pull the coax out of the A200 the noise is unchanged……..Geoff
 Filesize:  26.07 KB
 Viewed:  38832 Time(s)
Neal.George(at)hurlburt.a
PostPosted: Mon Dec 14, 2009 11:06 am    Post subject: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
Geoff -
The insulating and jacketing materials used in RG-58 are vulnerable to the temps encountered in soldering operations. RG-400 is much better suited to this application.
When using coax to feed an antenna, the shield must be electrically connected at both ends. On antennas that employ a BNC-type connector, the connector shells provide the circuit path from the radio case ground to the aircraft skin, which serves as the antenna ground plane. Whether the braid is soldered or clamped to the shell with some sort of threaded or crimped fastener is determined by the particular connector design.
It is quite possible that the heat of soldering was sufficient to melt the foam insulation separating the center conductor and the braided shield. If the two get together, things don't work so good, and transmitting could damage the radio's RF output circuit.
Finally, if you haven't checked/adjusted the radio's squelch setting, it may be set low enough that the hiss you're hearing is normal white noise. Tighten the squelch and see if the hiss goes away.
Neal
N8ZG
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.09 KB
 Downloaded:  1388 Time(s)
Geoff Heap
PostPosted: Tue Dec 15, 2009 5:46 am    Post subject: Re: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
Sorry. I wasn't complaining about the hiss. I was complaining that, that was all i got. I live under Philadelphia approach. Commercial craft at a couple thousand feet most of the day. I thought I would be picking up some of that. I'll borrow a hand held and test it with that on Saturday.
PostPosted: Tue Dec 15, 2009 7:22 am    Post subject: Re: LOOKING FOR RIGHT ANGLE BNC CONNECTOR Reply with quote
Geoff Heap,
Have you tried a portable antenna? Even a 22" wire will work. Just do not transmit. If you can not get the hiss to go away with the squelch adjustment, there is another squelch control on top of the radio accessible through a hole hidden under round aluminum foil.
Joe
Joe Gores
