Old style cabin doors and fuel vents
Tommy Walker
PostPosted: Sun Nov 29, 2009 2:28 pm    Post subject: Old style cabin doors and fuel vents Reply with quote
Builders,
I have the old style lexan/aluminum doors on my 701.
After getting everything hooked up, I discover that when the doors are open to the stop, the lexan pushes against the fuel drain.
That has got to be a big problem since lexan and gasoline don't mix.
I wonder what some of you are doing keep the doors from pushing against the fuel drain?
Many thanks and as always, Do Not Archive.
Tommy Walker in Alabama
N8701T
Tommy Walker
N25A - Anniston, AL
dashwood
PostPosted: Sun Nov 29, 2009 3:02 pm    Post subject: Re: Old style cabin doors and fuel vents Reply with quote
my 701 has 2 vent holes about 1.5" across in the lexon at the drain places. has two more at the top of the window the same distance from the trailing edge of door.. looks like they belong there. have two more of the spin able vents in the leading edge of the windows all four are symmetrical from the edges.. till you put the doors up everyone assumes they are just vents
pic shows front one but the back blends in . i drew a line around it with text box but didn't shrink well.. the line is shaky the hole is perfect
new pics posted
 Filesize:  39.43 KB
 Viewed:  7117 Time(s)
 Filesize:  48.48 KB
 Viewed:  6913 Time(s)
 Filesize:  38.08 KB
Ross Alexander: CH701 driver 912ul 788tt
It only takes two things to fly, airspeed and money
n801bh(at)netzero.com
PostPosted: Sun Nov 29, 2009 4:58 pm    Post subject: Old style cabin doors and fuel vents Reply with quote
My 801 did the same thing... I switched the fuel drains to the "low" profile ones... I think they were the Safeair ones..... Poor planning on Zenith's part for sure.
Ben Haas
N801BH
www.haaspowerair.com
jpspencer(at)cableone.net
PostPosted: Sun Nov 29, 2009 6:19 pm    Post subject: Old style cabin doors and fuel vents Reply with quote
Tommy
I had to drill 2 holes in my door windows to clear the vents. The windows have gotten some fuel on them from leaking but so far haven't cracked or crazed
Joe
n752ms(at)softcom.net
PostPosted: Sun Nov 29, 2009 7:21 pm    Post subject: Old style cabin doors and fuel vents Reply with quote
Tommy.
The old 701's had the doors swing forward so the fuel drain wasn't a
problem. Like Ben I switched to the low profile drains and used a soft
rubber bumper form McMaster Carr to hold the door away from the drain.
Mark S.
ggower_99(at)yahoo.com
PostPosted: Sun Nov 29, 2009 11:39 pm    Post subject: Old style cabin doors and fuel vents Reply with quote
It depends on the size of the piece of aluminum where the door piano hidge attaches in the fuselage (I do not have the plans here to see the part number), we made a instalation test of the door before cutting it to sze, We left the drain about 1 inch away from touching the window..,
What we couldnt prevent was that the drain will leak the same week we were checking a radio noise, and the doors were left open all week long (we didnt fnished testing Sat night).
The hole shure looks like a little vent.
Saludos
Gary Gower.
710 912S
Flying from Chapala, Mexico.
--- On Sun, 11/29/09, n801bh(at)netzero.com <n801bh(at)netzero.com> wrote:
From: n801bh(at)netzero.com <n801bh(at)netzero.com>
Subject: Re: Old style cabin doors and fuel vents
To: zenith701801-list(at)matronics.com
Date: Sunday, November 29, 2009, 7:54 PM
Ben Haas
N801BH
Dwight Early
PostPosted: Mon Nov 30, 2009 2:11 pm    Post subject: Re: Old style cabin doors and fuel vents Reply with quote
Tommy,
I used the twist to open type of drain cock instead of the very soft spring loaded one that was on my 701 when I got it. Just make sure there is no drip on the valve before you open the door. The door cannot open this valve by accident.
Dwight Early
N701EF
Zenith CH701/Revmaster
Daleville, In
Tommy Walker
PostPosted: Mon Nov 30, 2009 4:01 pm    Post subject: Re: Old style cabin doors and fuel vents Reply with quote
Thanks for all the tips. I got several emails online and here on the matronics site.
N8701T
Tommy Walker
N25A - Anniston, AL
