Oxygen quality (was: Air bottles)
brian
PostPosted: Tue Jan 10, 2006 7:39 am    Post subject: Oxygen quality (was: Air bottles) Reply with quote
cgalley wrote:
medical. In reality ALL oxygen at this time is fractionally distilled
from liquid air.
Yes. All three, welding O2, ABO, and medical O2 are 100% identical. They
are "tested" to different standards but all are identical and come from
the same source.
So you can fill your supplemental oxygen from any of these
three but cheapest is the same as the most expensive.
Right.
Welding oxygen
works fine but if Medicare is paying, get it from the medical house.
And you may run into a need for a prescription if you are buying medical
O2. It is also more expensive than welding O2.
BTW, I used to fill my O2 bottle in the USVI for $11 at the local
welding supply place. I used it almost every trip to and from the US as
I would typically operate at 15,000-18,000 feet.
Brian Lloyd 2243 Cattle Dr.
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
Brian Lloyd
L39parts(at)hotmail.com
PostPosted: Tue Jan 10, 2006 8:01 pm    Post subject: Oxygen quality (was: Air bottles) Reply with quote
