zsmith3rd(at)earthlink.ne Guest
Posted: Tue Nov 24, 2009 10:15 am Post subject: More "Nets" |
Another possible source for netting, and other items not easily sewed on the typical home Singer,
(especially by the typical rivet puller) is your local "trucker's supply".
In most areas dump trucks, rock haulers, gravel haulers, etc, are required to put netting over their loads.
Usually some guy has a big industrial sewing machine and a selection of netting, some very long work tables (leveled) and giant sissors. These firms make nets-to-order.
Also, consider awning merchants. They cut & sew canvas, belting material, etc, and likely have the expertise to custom-fit your idea.
Be cautious about mentioning the word "airplane" as the price usually goes up.
Regards.
Zed
raymondj(at)frontiernet.n Guest
Posted: Tue Nov 24, 2009 4:23 pm Post subject: More "Nets" |
Get a net shuttle and make your own! I've made several for my boat.
Very easy to do.
Raymond Julian
Kettle River, MN.
Zed Smith wrote:
Regards.
Zed
edleg
Posted: Sat Jan 09, 2010 10:28 am Post subject: Re: More |
What is a "net shuttle"? and where does one get it? I did a google search and came up with nada.
edleg
Posted: Sat Jan 09, 2010 10:29 am Post subject: Re: More |
frank.goodnight(at)att.ne Guest
Posted: Sat Jan 09, 2010 11:46 am Post subject: More "Nets" |
Hi all,
Strictly a 1/2 educated guess.---could be the tool that fishermen use
to repair holes in gill nets-
Frank Goodnight
On Jan 9, 2010, at 12:28 PM, edleg wrote:
<ed_legault(at)yahoo.com>
http://forums.matronics.com/viewtopic.php?p 80818#280818
carlossa52(at)gmail.com Guest
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Sat Jan 09, 2010 12:12 pm Post subject: More "Nets" |
Ed
I presume what you are interesting in doing in making a net, IIRC, netting is the correct verb.
I used to have a book on how to net, and many years ago I made a few small nets. They make great shopping bags.
The net shuttle is just a handy device to hold a nice quantity of string (or whatever you are making the net from) while you maneuver the string and tie the knots to make up the net.
I made some shuttles out of plastic (like the sides of an empty antifreeze jug) similar to the ones shown in Carlos' link. The plastic wasn't stiff enough and they didn't work very well. I had better luck making them out of coat hanger wire, something like the attached dwg. Size is somewhat arbitrary, depending on the thickness of the string and the size of the mesh and the net dimensions.
Terry
At 02:37 PM 1/9/2010 -0500, Carlos wrote:
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done;
Balancing the ailerons and working on the wings
http://www.mykitlog.com/N47TP/ [quote][b]
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
Terry Phillips
Posted: Sat Jan 09, 2010 12:36 pm Post subject: More "Nets" |
Whoops! Forgot the attach.
Ed
Terry
ttp44~at~rkymtn.net
Corvallis MT
 Download |
| Filename: |
Netting_Shuttle.pdf |
24.95 KB |
| Downloaded: |
656 Time(s) |
Corvallis, MT
ttp44<at>rkymtn.net
n4546v(at)mindspring.com Guest
Posted: Sat Jan 09, 2010 5:16 pm Post subject: More "Nets" |
NET SHUTTLE SET
Shuttles are a required tool for net making and net repair. Shuttles
are used to store and dispense the twine as it woven through the net and
knots are tied. Shuttle size is determined by the size of twine you are
using and the mesh size of your net. Set includes 8 different sizes of
shuttles capable of a minimum 1/2 inch mesh up to a 4 inch turtle trap mesh.
Catalog # 971900
In Stock
$5.95 / EACH
http://www.jannsnetcraft.com/Search/shuttle.aspx
There you go...........
Randy, Las Vegas
2 KB |
15309 Time(s) |
