emrath(at)comcast.net Guest
Posted: Fri Nov 20, 2009 8:29 pm Post subject: Gretz Heated Pitot Tube attaching |
Folks,
I have a Gretz Heated Pitot Tube and mount. Unfortunately the pitot tube
fitting does not extend far enough to be able to attach the line to the tube
once the tube is in the mount. I'd like to hear from anyone that has found
the solution to this problem so I don't have to "reinvent the wheel".
Marty in Brentwood TN, RV-6A finish assembly.
MNellis
Joined: 16 Aug 2008 Posts: 15 Location: Georgetown, TSX
Posted: Fri Nov 20, 2009 8:42 pm Post subject: Gretz Heated Pitot Tube attaching |
Marty, it's been a bizillion years since I installed my Gretz Pitot
tube so I can't offer much other than a few pictures. Here is the
technique I used and maybe it will help you out.
http://bmnellis.com/WingSkinning3.htm
Mike Nellis
RV6 Fuselage Roll Bar
Folks,
_________________ Mike Nellis
RV6 Fuselage |
Posted: Sat Nov 21, 2009 3:18 am Post subject: Gretz Heated Pitot Tube attaching |
What I have done in the past is to extend the line from the wing down
through the mount so you can attach the line externally, then push the
pitot with the attached line into the mount and secure. Then later it
is servicable without opening the wing.
-Mike
On Nov 20, 2009, at 11:26 PM, "emrath" <emrath(at)comcast.net> wrote:
Folks,
tube
the tube
has found
Matt Dralle Site Admin
Joined: 08 Nov 2005 Posts: 27835 Location: Toledo Washington (KTDO) USA
Posted: Sat Nov 21, 2009 10:07 am Post subject: Gretz Heated Pitot Tube attaching |
At 08:26 PM 11/20/2009 Friday, you wrote:
Folks,
Hi Marty,
Here are some detailed pictures of my Gretz Heated Pitot in the RV-8. Might give you some ideas:
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category 982&log=81655&row=151
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category 982&log=81656&row=150
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category 982&log=81657&row=149
http://www.mattsrv8.com/users/display_log.php?user=MattsRV8&project=638&category 982&log=81658&row=148
RV-8 #82880 N998RV
Windscreen Installation (ack)...
_________________ Matt Dralle
Posted: Sat Nov 21, 2009 5:06 pm Post subject: Gretz Heated Pitot Tube attaching |
Marty,
I made a pair of short AN4 tubes that connect inside the mast and extend
outside (up in th the wing). There I have a set of AN4 connectors that
allow me to disconnect the 'mess from within the access panel.
Ralph Capen
Posted: Sun Nov 22, 2009 4:34 pm Post subject: Gretz Heated Pitot Tube attaching |
Nice installation Matt, but my Pitot was purchased long ago without the
electronic module and the tube sticking up from the pitot is only about 1.5"
long, terminating in a AN4 tube fitting.
Marty
Time: 10:07:44 AM PST US
Subject: Re: Gretz Heated Pitot Tube attaching
Folks,
tube
| Quote: | once the tube is in the mount. I'd like to hear from anyone that has found
Hi Marty,
give
you some ideas:
RV-8 #82880 N998RV
evmeg(at)snowcrest.net Guest
Posted: Mon Nov 23, 2009 7:38 am Post subject: Gretz Heated Pitot Tube attaching |
Loosen the screws holding the mast (mount) to the wing and push it up inside
the wing. This will leave the end of the tubing exposed where the flare nut
is so you can attach the pitot to it. Then pull the mast back down and
reattach it. Thats how mine works...hope this is your answer.
Evan
