LED Interior Lights
norman96(at)telus.net
PostPosted: Tue Nov 17, 2009 5:52 pm    Post subject: LED Interior Lights Reply with quote
Hi everybody, I'm looking for suggestions on interior LED lighting. I'm after some small fixtures to light the floor and luggage areas. Also looking for some kind of LED strip light to do the panel. Any ideas on sources?
Norman Hunger
RV6A Delta BC
[img]cid:3837E949-A07F-4593-9890-701B4E7008E5(at)domain.invalid[/img]
Nov 17-09 - 10
 Filesize:  65.33 KB
 Viewed:  4836 Time(s)
jhnstniii(at)aol.com
PostPosted: Tue Nov 17, 2009 6:54 pm    Post subject: LED Interior Lights Reply with quote
Norman--Check out www.aircraftextras.com for electroluminescent lighting strips. I remember your name from the list years ago. Glad you're back on the project. It's looking good.
LeRoy Johnston RV-6A N176LD "Esperanza" 240+ hrs. Ohio
 Filesize:  65.33 KB
 Viewed:  4835 Time(s)
rvhad(at)yahoo.com
Pep Boys!
To: RV List <rv-list(at)matronics.com>
Sent: Tue, November 17, 2009 7:51:58 PM
Subject: LED Interior Lights
Norman Hunger
RV6A Delta BC
Nov 17-09 - 10
n343fd(at)yahoo.com
PostPosted: Tue Nov 17, 2009 9:21 pm    Post subject: LED Interior Lights Reply with quote
I got a strip of led lights from ACS. Used double sided tape under the glare shield and wired it to the dimmer for the post lights. Works great.
FLEXIBLE LED INSTRUMENT LIGHTS - WITH CIGARETTE LIGHTER AND DIMMER
Mike Divan
N64GH - RV6 (flying)
http://n64gh.blogspot.com/
FREEDOM IS NOT FREE - THANK THE AMERICAN SOLDIER FOR YOURS!
Remember it is the Soldier, Sailor, Airman, Marine and Coast Guard that guarantee your freedom NOT the "community organizer"!
To: rv-list(at)matronics.com
Sent: Tue, November 17, 2009 6:46:41 PM
Subject: Re: LED Interior Lights
Pep Boys!
Norman Hunger
RV6A Delta BC
Nov 17-09 - 10
david.nelson(at)pobox.com
PostPosted: Tue Nov 17, 2009 10:03 pm    Post subject: LED Interior Lights Reply with quote
Hi Norman,
I'm planning on installing 2x (one for the pilot and one for the passenger) of
these to the channel between the rollbar and rear bulkhead (tip-up). Each head
has a pair of red and white LEDS that'll be controlled by a locally small
switch to select either red or white.
http://www.periheliondesign.com/ledlights.htm
/\/elson
Norman Hunger
RV6A Delta BC
Nov 17-09 - 10
Bret Smith
PostPosted: Wed Nov 18, 2009 6:33 am    Post subject: LED Interior Lights Reply with quote
www.Superbrightleds.com
Bret Smith
RV-9A (Emp)
rv8iator
PostPosted: Wed Nov 18, 2009 7:14 am    Post subject: LED Interior Lights Reply with quote
Strip light LEDs in white and colors. Attach to underside of glareshield and windscreen bow.
http://www.mpja.com/prodinfo.asp?number=17362+OP
Chris Stone
RV-8
Newberg, OR
C. Stone (RV8iator)
