Placard Location
stevesimmons(at)charter.n
PostPosted: Sat Nov 14, 2009 11:48 am    Post subject: Placard Location Reply with quote
Does anyone have a suggestion on where to put the 2” EXPERIMENTAL placard on the Kolb Mark III classic I do not want to put them on the fabric? I am thinking about putting them on the outside of the cabin doors at the bottom.
russkinne(at)mac.com
PostPosted: Sat Nov 14, 2009 12:11 pm    Post subject: Placard Location Reply with quote
Why not the boom tube?do not archive
style="color: blue; text-decoration: underline; ">www.aeroelectric.com
href="http://www.buildersbooks.com" style="color: blue; text-decoration: underline; ">www.buildersbooks.com
style="color: blue; text-decoration: underline; ">www.homebuilthelp.com
style="color: blue; text-decoration: underline; ">http://www.matronics.com/contribution
style="color: blue; text-decoration: underline; ">http://www.matronics.com/Navigator?Kolb-List
blue; text-decoration: underline; ">http://forums.matronics.com
jlsk1(at)frontiernet.net
PostPosted: Sat Nov 14, 2009 1:41 pm    Post subject: Placard Location Reply with quote
I put mine on the Bottom of the gap seal, where it is visible to both pilot & pasenger by looking up, (at the bottom of the seal while it is in place). My DAR had no problem with it there, though I waited to install it when he came to inspect it.
Jim Kmet
MK-3C
CXookeville, TN
slyck(at)frontiernet.net
PostPosted: Sat Nov 14, 2009 1:46 pm    Post subject: Placard Location Reply with quote
The lift struts.obviously biased BB
rickofudall
PostPosted: Sat Nov 14, 2009 2:07 pm    Post subject: Placard Location Reply with quote
Russ, It has to be where the passenger can see it while entering the aircraft. The bottom of the doors works well. It's out of sight when flying and looks cool sitting on the tarmac, IMHO.
Rick Girard
On Sat, Nov 14, 2009 at 2:10 PM, russ kinne <russkinne(at)mac.com (russkinne(at)mac.com)> wrote:
[quote] Why not the boom  tube?do not archive
elleryweld(at)aol.com
PostPosted: Sat Nov 14, 2009 2:30 pm    Post subject: Placard Location Reply with quote
My EXPERIMENTAL stickers are on the inside of the cockpit along side the seat on both sides
Ellery in Maine
PostPosted: Sat Nov 14, 2009 4:11 pm    Post subject: Placard Location Reply with quote
Russ/Gang:
The experiemental placard is to be placed where the passenger can easily see it as he enters the aircraft.
If the passenger enters the aircraft from the tail boom, that would be a good place to put it. Wink
mkIII - With experimental placard placed on the bulkhead behind the passenger seat.
[quote] : Re: Placard Location
Jason Omelchuck
PostPosted: Sun Nov 15, 2009 8:29 am    Post subject: Re: Placard Location Reply with quote
I put mine on the floor right against where the the floor transitions up to the front edge of the seats.
mdnanwelch7(at)hotmail.co
PostPosted: Sun Nov 15, 2009 12:18 pm    Post subject: Placard Location Reply with quote
 Kolb guys C
  I'll be needing to install my "experimental" signs on my MkIII soon(ish) C and I haven't checked the regs C but is the location only for the benefit of the passenger C and not the public walking by?
  In other words C can the placement just be inside the cabin (in sight of the passenger) C with no need to have one outside?
Mike Welch
MkIII CX
Hotmail: Trusted email with powerful SP target='_new'>Sign up now. [quote][b]
lcottrell
PostPosted: Sun Nov 15, 2009 3:53 pm    Post subject: Placard Location Reply with quote
I don't remember the exact wording, but it has to be plainly visible to anyone that is getting into the airplane. I put mine on the top of the lift struts. Very noticeable to anyone entering the plane but not so noticeable in flight. You would have to be higher and in front of the plane to see it. You can just barely see it on the left side strut.
Larry C[img]cid:B0CE8E27278F45EC8AD27E7359AB6135(at)larryPC[/img]
 Filesize:  110.21 KB
 Viewed:  8225 Time(s)
rowedenny
PostPosted: Mon Nov 16, 2009 2:45 am    Post subject: Placard Location Reply with quote
Steve,
I put mine up the wing struts on the upper side.
You hardly notice them except when you are getting in and out.
Dennis Rowe
