Thom Riddle
Posted: Thu Nov 12, 2009 7:05 am Post subject: Bing 94 carb question |
I recently dissasembled, inspected and cleaned the Bing 94 carb on my Jabiru 2200A #1574. All is well after 240 hours.
Yesterday, I did the same for a customer's carb from Jabiru 2200A #2058. It is in great shape but I found one anomaly (or so it seems to me) and would like to find out if any of your Bing 94 carbs have this same thing. In the brass tube that receives fuel from starting chamber in the float bowl (not the main jet area but the small diameter chamber at one corner) there is a tiny hole in the side of this brass tube about 3/16" below the top of the fuel bowl, and thus above the normal fuel level in the bowl. If this hole is not supposed to be there it could be contributing to the cold start problem he is having by allowing excess air to be drawn in and less than full rich fuel charge during engine start.
My question is this: Have any of you seen this tiny hole in the side of the brass tube that picks up fuel in the start chamber? My Bing 94 does not have this nor does any Bing 64 carb on which i've worked (lots of them).
I spolke to Pete yesterday about this and he said he has never noticed this but would be looking at one of his carbs to see. I'd like to hear from any other Jabiru operators with Bing 94 carbs to see if this tiny hole is a manufacturing anomaly or "as designed" in the later engines.
I've attached a photo of the carb with the hole I'm asking about.
http://riddletr.googlepages.com/a%26pmechanix
| | - The Matronics JabiruEngine-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?JabiruEngine-List |
632.58 KB |
15704 Time(s) |
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
jd(at)lawsonimaging.ca Guest
Posted: Thu Nov 12, 2009 7:49 am Post subject: Bing 94 carb question |
Thom Riddle wrote:
Just checked the Bing (guess its a 94...) that came with my 3300a s.n. 1053
It does indeed have the hole as per your pic. Bing is unused/unneeded.
Regards, J.
Sonex #325 C-FJNJ, Jabiru 3300a, Prince P-Tip, Aerocarb
restoring the Johnston Special
http://cleco.ca
| J. Davis, M.Sc. | (computer science) |
| *NIX consulting, SysAdmin | email: jd at lawsonimaging.ca |
and now... Deep Thought #24, by Jack Handy
I don't think I'm alone when I say I'd like to see more and more planets fall
under the ruthless domination of our solar system.
Thom Riddle
Posted: Thu Nov 12, 2009 8:15 am Post subject: Re: Bing 94 carb question |
J.
Thanks for your quick reply. It is unlikely that this hole is in more than one carb if it is not intentional, so it is beginning to appear to me that this is a design change implemented sometime after mine was built.
Buffalo, NY (9G0)
- Anonymous |
zeprep251(at)aol.com Guest
Posted: Thu Nov 12, 2009 12:05 pm Post subject: Bing 94 carb question |
Thom,
Looks like the bottom of the tube has had a taper machined on it,like you would do to assist pressing it into the carb body.
G.Aman
Thom Riddle
Posted: Thu Nov 12, 2009 1:20 pm Post subject: Bing 94 carb question |
Just thought the hole would be below the float level if it were reversed.
Thom Riddle
Posted: Thu Nov 12, 2009 1:33 pm Post subject: Re: Bing 94 carb question |
Now that I know that this one carb is not the only one with this hole, I must assume that it is there by design and performs some desirable function. Since it is above the fuel level its purpose must be to allow some air to be drawn in along with the fuel in the starting chamber, in effect either leaning it somewhat or perhaps it helps to aerate or atomize it a bit. Only the Bing engineers will know the real reason it is there. My thoughts are pure speculation.
Buffalo, NY (9G0)
- Anonymous |
Lynn Matteson
Posted: Thu Nov 12, 2009 1:43 pm Post subject: Bing 94 carb question |
The Bing that was once on my engine (#2062) also has this hole, for
what it's worth.
Lynn Matteson
Jabiru 2200, #2062, 814.7 hrs
Countdown to 1000 hrs~185 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying (and learning)
On Nov 12, 2009, at 4:33 PM, Thom Riddle wrote:
<riddletr(at)gmail.com>
speculation.
Thom Riddle
Buffalo, NY
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x31
"Rules are for the guidance of wise men and the obedience of
fools."
- Pablo Mason
http://forums.matronics.com/viewtopic.php?p 72495#272495
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
debandpete(at)bigpond.com Guest
Posted: Thu Nov 12, 2009 6:25 pm Post subject: Bing 94 carb question |
I have seen these holes above fuel level on many carbs and yes, it is to aerate the fuel to assist in vaporisation.
Peter
On 13/11/09 08:33, Thom Riddle wrote: [quote] | Quote: | --> JabiruEngine-List message posted by: "Thom Riddle" <riddletr(at)gmail.com> (riddletr(at)gmail.com)
Thom Riddle
Buffalo, NY
Jabiru 2200A #1574
"Rules are for the guidance of wise men and the obedience of fools."
- Pablo Mason
[url=http://forums.matronics.com/viewtopic.php?p 72495#272495]http://forums.matronics.com/viewtopic.php?p 72495#272495[/url]
| [b]
