spitfire55
Joined: 08 Apr 2008 Posts: 2 Location: Winnipeg,Manitoba
Posted: Sun Nov 08, 2009 6:33 pm Post subject: wing mod |
The drawing for the new wing mod are now on Zenith's web site!
_________________ William Studdy CH 250 Built,Flying,Sold |
Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
Posted: Mon Nov 09, 2009 12:42 am Post subject: Question re wing mod |
I just had a quick look through the modification drawings and already have a question that someone might be able to answer:
Drawing 6-ZU-1, Part 6-ZU-1-2, Wing Root Doubler
This doubler is installed on front side of spar root, which results in a 0,063" thicker overall spar root. Does this match the center spar in the fuselage with its original width? Or is the distance between the spar caps in the fuselage somewhat flexible?
Anyway: I will implement all modifications (although some of them are a real pain in the ..., even on my still incomplete XL) .
Finally I like how Zenair is laying open their documentation, in particular the load test report to ultimate load from Sep 09!
Martin
_________________ Martin Pohl
Zodiac XL QBK
8645 Jona, Switzerland
http://www.pohltec.ch/ZodiacXL/Main.html |
psm(at)att.net Guest
Posted: Mon Nov 09, 2009 2:04 am Post subject: wing mod |
Hi Martin,
I'm not sure of the answer to your question, but I will take a guess.
The existing structure is pretty tight in the mating area. Perhaps
it will be loosened in the process of following the instructions we
don't yet have. Also, perhaps this opening is the reason for
replacing the current wing uprights with parts 6-ZU-2-4. This could
make room for a wider spar carry through.
Paul
XL - used to be complete, but now there is more fun to have . . .
At 12:42 AM 11/9/2009, you wrote:
| Quote: | I just had a quick look through the modification drawings and
William Dominguez
Posted: Mon Nov 09, 2009 5:45 am Post subject: wing mod |
I have noticed the same thing. The spar root is now .063 thicker but the spacers remain the same. It would be easy to add a small .063 plate to the spacer however, this would make the center spar rear web to move a little backward and a little up, possibly necessitating a shim between the bottom flange of the center spar rear web and the floor. For planes that have their center spar already drilled to the fuselage, this might not be an option because the already drilled holes might no longer match.
William Dominguez
Zodiac 601XL Plans
Miami Florida
http://sites.google.com/site/billplane/
Sent: Mon, November 9, 2009 3:42:49 AM
Subject: Re: wing mod
--> Zenith-List message posted by: "Martin Pohl" <mpohl(at)pohltec.ch (mpohl(at)pohltec.ch)>
Martin
Martin Pohl
Zodiac XL QBK
_________________ William Dominguez
Zodiac 601XL Plans
Miami Florida
http://www.geocities.com/bill_dom |
maarten versteeg
Posted: Mon Nov 09, 2009 7:17 pm Post subject: wing mod |
Hello Martin,
Yes, this is an aspect that confuses me too, the original wing spar
slides between
the front and back part of the center spar and this certainly doesn't
allow for a
0.063 Al wing root doubler. Just pushing it in wouldn't make the to
parts of the
spar lay flat on top of each other. If this stiffening of the wing spar
is required
then the two pieces of the center spar will need to be moved further
apart. This
can only be done when the two parts are detached at the top and removed at
least the from part is removed form the plane. I would say the only way to
properly install this is to remove the whole from part of the center
spar and make
a new one, with spacers that are 0.063 longer.
Looking at the front wing uprights that are now to be extrusions I am also
confused since the wing uprights that they replace were not wend to 90
degree so
I don't understand how a 90 part can replace the larger angle.
Clearly with these three drawings there are many questions remaining and an
instruction of how to install will be needed to clarify all of this.
- Maarten, 601xl plans build,
was somewhere halfway the fuselage but now ....
_________________ Maarten Versteeg
601XL scratch building wings |
Martin Pohl
Posted: Tue Nov 10, 2009 4:04 pm Post subject: Re: wing mod |
Answer from Zenair:
You will also have to take the front and rear halves of the center spar
apart to install the doublers that go on top. When you do that, you will
reset the width of the center spar. All of this will be covered by the photo
guides. We are currently putting together all of the assembly information as
quickly as possible. All of this information will be posted on the website
as soon as its available.
Zodiac XL QBK
