hansriet
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Sat Nov 07, 2009 5:04 pm Post subject: FAA grounds 601 and 650 |
On Sat, Nov 07, 2009 at 04:32:43PM -0800, hansriet wrote:
They didn't quite ground it. They "strongly recommended" that the aircraft
not be flown again until the necessary modifications are made.
AMD has not issued the safety bulletin yet. Since there is no safety
bulletin yet, it's still legal to fly the SLSA version.
I'm told that it's been in development for a while, but know nothing about
it. I'll be calling the factory Monday to get the scoop.
Jay Maynard, K5ZC, PP-ASEL, CFI-SP http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
wjones(at)brazoriainet.co Guest
Posted: Sat Nov 07, 2009 5:11 pm Post subject: FAA grounds 601 and 650 |
Anyone have an idea what will be required
sabrina
Posted: Sat Nov 07, 2009 5:14 pm Post subject: Re: FAA grounds 601 and 650 |
psm(at)att.net Guest
Posted: Sat Nov 07, 2009 6:37 pm Post subject: FAA grounds 601 and 650 |
Hi Sabrina,
I am impressed. I have always thought the German V-1 power plant
might be useful for airplanes - at least to some degree.
I'd sign up for a copy of your design if not for the fact that my
limitation to fly only LSA compliant planes prevents use of anything
except reciprocating engines. (I hope they will change this to
include electric motors soon.)
Paul
At 05:14 PM 11/7/2009, you wrote:
| Quote: | I am currently working on a pulse jet powered flying motorcycle. :O)
Scotsman
Joined: 27 Aug 2007 Posts: 89 Location: Johannesburg, South Africa
Posted: Sat Nov 07, 2009 11:33 pm Post subject: Re: FAA grounds 601 and 650 |
Does this also now mean that the FAA is also wrong?
_________________ Cell +27 83 675 0815 |
lwhitlow
Joined: 15 Jan 2006 Posts: 76 Location: Valparaiso Indiana
Posted: Sun Nov 08, 2009 9:11 am Post subject: Re: FAA grounds 601 and 650 |
Questions For Discussion
1. The FAA is saying that the E-AB guys should use the AMD fixes How will we get these drawings and parts?/ I am not a customer of AMD I bought a kit from the boys in Mexico MO. Anybody on the list have any contact with the Zenith in Mexico MO?? I'm assuming they are doing the changes for AMD and are the ones really doing the drawings and making the parts??
2. The AMD Letter refers to the EU/UK LAA mass balance weights drawings and I've read that. However, the LAA doc also calls for a carry through spar mod that AMD makes no mention of. SOOOOOO are we gonna have to do the carry through mod or not???
3. The AMD docs say the plane should be placarded per the November 2009 bulletin. So how do the E-AB guys get that bulletin?
What a mess. I think its poor planning and PR and engineering practice to point to a EU / UK LAA document that is not drawn and managed by the designer / manufacturer, and not at least discuss WHY you are NOT saying we should do everything in this document but only do part of it.
Zenith /AMD may not feel the spar mod is needed but at least say that or SAY SOMETHING! To be mute on the issue is NOT ACCEPTABLE!!
I'm ready, willing and able to do any mod to my nearly complete 601XL but I want words from Zenith as to their reasoning behind only implementing part of the LAA letter and not all of it
Zenith NOW IS THE TIME TO SPEAK UP!!! Every day you waste not addressing these questions devalues my aircraft, your investment in the 601 / 650 program and the Zenith Aircraft company.
I believe that no matter what problems may exists with the 601 /650 they are all fixable and we can have a safe respected airplane, but that requires the factory and designer to step up and say something
Larry Whitlow
601XL Jabiru 3300
N69102 (reserved)
I was about 90% done but now I apparently have more to do
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Sun Nov 08, 2009 11:15 am Post subject: Re: FAA grounds 601 and 650 |
Larry,
I was thinking of the same questions. I'm a plans builder, and have never had any dealings with AMD. Why is the FAA acting as if AMD is the manufacturer? Why aren't the recommendations coming out of Zenith instead of AMD? My airframe is also almost complete.
My hope is that Zenith (not AMD) puts out a design update soon that addresses all of the FAA's concerns, and that those changes are provided to us builders at no additional cost.
Dan
| lwhitlow wrote: | Questions For Discussion
Larry Whitlow
601XL Jabiru 3300
N69102 (reserved)
I was about 90% done but now I apparently have more to do |
_________________ Scratch building XL with Corvair Engine |
Doug.Norman(at)sportaviat Guest
Posted: Sun Nov 08, 2009 11:41 am Post subject: FAA grounds 601 and 650 |
AMD is the manufacturer for the SLSA version. The SLSA is the only version
which the FAA has any hold over; and even that is indirect. Owners of SLSA
airplanes are required (by law) to pay attention to SA/Ds issued by their
manufacturer. It's not a suggestion for us. For SLSAs, the issuance of a
SA/D by their airplane's manufacturer is the same as an issuance of an AD by
the FAA for a standard airplane.
By hitch-hiking on the AMD Safety Alert/Directive, the FAA can push the
Zodiac experimental community to pay attention - they can't force their
attention; but if they could, they would. The FAA is couching E-AB and ELSA
adherence to the AMD SA/D as an airworthiness issue which you ignore at your
peril. They can't force you, but if you have an incident, and you have not
made the changes, then (their reasoning is that) you knowingly operated your
aircraft in a non-airworthy condition - which is against the FARs.
I suspect that Zenith will publish the AMD pages as the design which Zenith
customers should use. And, Zenith will probably make kits available for the
retrofit.
Best of luck,
Doug Norman, CFI, AGI
AMD Zodiac N601DN
leinad
Posted: Sun Nov 08, 2009 12:02 pm Post subject: Re: FAA grounds 601 and 650 |
Doug,
You say the FAA has no hold over us Experimental builders, but as I haven't completed my build and the FAA has to inspect it and grant an airworthiness certificate for it, it seams like they do have at least some hold over us EAB guys.
Dan
| Doug.Norman(at)sportaviat wrote: | AMD is the manufacturer for the SLSA version. The SLSA is the only version
retrofit.
Best of luck,
AMD Zodiac N601DN
bryanmmartin
Posted: Sun Nov 08, 2009 12:58 pm Post subject: FAA grounds 601 and 650 |
Unless things have changed quite a bit since I got my inspection, the
airworthiness inspection is primarily a paperwork inspection. My
inspector looked over my plane in just a bit more detail than you
would give to a typical pre-flight inspection, The primary points of
the inspection were to make sure all the forms were properly filled
out, the panel was properly marked, all the placards and markings were
in place and make sure all the required documents were in the
airplane. The inspector is not likely to get out your plans and go
over them in detail to make sure you followed them correctly.
On Nov 8, 2009, at 3:02 PM, leinad wrote:
Doug,
Dan
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
Posted: Sun Nov 08, 2009 1:08 pm Post subject: FAA grounds 601 and 650 |
That's an excellent point. I don't know what a DAR would do given the
current facts and circumstances.
Doug
afterfxllc(at)aol.com Guest
Posted: Sun Nov 08, 2009 1:25 pm Post subject: FAA grounds 601 and 650 |
I would bet every DAR will know of the FAA's decision and will not issue an airworthiness if the mods aren't done. I beleve they have to request permission from their field office to preform the inspection so a DAR that doesn't know of the mods is not going to happen.
Jeff
jmaynard
Posted: Sun Nov 08, 2009 1:32 pm Post subject: FAA grounds 601 and 650 |
On Sun, Nov 08, 2009 at 11:15:29AM -0800, leinad wrote:
| Quote: | I was thinking of the same questions. I'm a plans builder, and have never
Because the FAA can't deal with Zenith for much of anything. The FAA *can*
deal with AMD, as the manufacturer of the SLSA version (*not* Zenith). As
far as the FAA is concerned, for the SLSA, AMD *is* the manufacturer.
leinad
Posted: Sun Nov 08, 2009 5:52 pm Post subject: Re: FAA grounds 601 and 650 |
Bryan,
I recall a thread on this some time ago. Inspections run the gamut from a cursory look over the plane and check of the paper work to all day long affairs where every detail that can be gotten to is scrutinized. I really don't know what to expect on inspection day. I just have to be as ready as I can be. I'm sure I'll make the required mods, I'm just not sure what they are or where the information will come from.
I"m guessing that mass balance of the ailerons will be part of the change. Does this mean the flex hinges are out? Just another of many questions.
Anyone interested should come to chat to talk about this tomorrow night.
Dan
| bryanmmartin wrote: | Unless things have changed quite a bit since I got my inspection, the
Doug,
Dan
Bryan Martin
N61BM, CH 601 XL,
do not archive. |
service(at)eipdiesel.com. Guest
Posted: Sun Nov 08, 2009 6:34 pm Post subject: FAA grounds 601 and 650 |
Go to the ZAC website, all the mod info is on there.
Greg Cox
pchap(at)primus.ca Guest
Posted: Sun Nov 08, 2009 8:11 pm Post subject: FAA grounds 601 and 650 |
At 21:33 08-11-09, you wrote:
There's a massive number of changes!
As a brief initial summary:
(Note I may be wrong somewhere as I'm doing this quickly and am not
personally involved with an XL)
SPARS (or at least, p1 of the Zenair Upgrade)
- main spar top cap - L angle extrustion, for about half span
(and some bolts in place of rivets)
- doubler for the main spar web at the wing root (with a spacer)
- rear spar doubler around the aileron pushrod cutout
- doubler plate for rear spar channel inboard
- rear spar top cap - L angle for full span
CENTER SECTION (p2 of the Zenair Upgrade)
- center spar top cap doubler
- additional L doubler for center spar top cap
- new heavier front wing uprights
- 4 heavy L angle uprights on center spar to brace it
- web doubler for spar at wing attach bolts (and shims)
WINGS & FUSELAGE (p3 of the Zenair Upgrade)
- new style support channel for aileron bell crank
- L angles to reinforce the rib with bell crank (2 on top, 2 on bottom)
- angles to brace the forward fuselage around the wing uprights (Z
angle to the front, L angle to the aft)
- gussets to brace the top of the wing uprights (front and aft)
- longer angles around seat pan cutouts
- new thicker rear wing attach plates
- more rivets inboard between spar and wing skin
Peter Chapman
Toronto, ON 601 HDS / 912 / C-GZDC
Posted: Sun Nov 08, 2009 8:58 pm Post subject: FAA grounds 601 and 650 |
Hi Peter,
Your list of changes only considers the drawings currently posted as
AMD changes. There's a lot more to be done to meet Chris Heintz's
requirements including aileron mass balance, control system
sensitivity change, and I have no idea what else.
If you read the 7 page Q&A you will see there are a bunch of changes
in the "Package" not included in the 3 pages of drawings.
Still, I am glad the whole thing is coming to a conclusion. I intend
to install all the changes on my plane.
Paul
XL awaiting engineering changes.
At 07:30 PM 11/8/2009, you wrote:
| Quote: | There's a massive number of changes!
Peter Chapman
lwhitlow
Posted: Sun Nov 08, 2009 9:48 pm Post subject: Re: FAA grounds 601 and 650 |
Here's the link to the mods
http://www.zenithair.com/news/ntsb-astm-4-09a.html
OK That was faster than I expected.
I do have sympathy for what Chris said in his answer to Question 2 about non-disclosure per NTSB rules and he mentions they are being sued as reasons they have not spoken much on the matter. I was un-aware anyone had started legal action.
OK so a few of my questions have been addressed well, but a few have gotten more cloudy
I note the EXTENSIVE spar mods both in the wing and in the center section, and do wonder about how much weight is getting put in here??
The drawings are great but has this been done on an actual 601?? are there pictures yet?? I know this is hot off the presses but have they actually replaced these parts on a completed aircraft?
And of course the hard to pin down "is it flutter or not issue?" OK so we beef it up to prevent it. Great! Chris addresses it in Question 8 that yes Weights are now going to be used. But unless I'm looking through it I see no drawings of the weights. I have the LAA drawings but I really would like it if a set would come from Zenith and the people who know the aircraft. Are we supposed to use the LAA drawings???
I wonder how long it will be before we can get the upgrade kits in hand?? I never did the final close on my wings so I'm pretty good there but some of the spar work is gonna be a pain in the butt on a mostly finished fuselage..
Small price to pay I suppose...
Larry Whitlow
601XL Jabiru 3300 Sensenich Composite prop
N69102 (Reserved)
90% done with the first build
0% done with the mods
jmaynard
Posted: Mon Nov 09, 2009 4:24 am Post subject: FAA grounds 601 and 650 |
On Sun, Nov 08, 2009 at 09:48:45PM -0800, lwhitlow wrote:
| Quote: | And of course the hard to pin down "is it flutter or not issue?" OK so we
Yes. The AMD safety alert specifically says that the LAA instructions are to
be followed for the aileron balance weights only.
