mjpienaar(at)shaw.ca Guest
Posted: Thu Nov 05, 2009 10:14 pm Post subject: Wing root fairing |
Hi Bill,
I was lokking at how you attached the wing root fairings and can figure out what you did on the fuselage but how did you attach the fairing onto the wing?
Cheers
Mike
wschertz(at)comcast.net Guest
Posted: Fri Nov 06, 2009 6:53 am Post subject: Wing root fairing |
The fairing is NOT attached to the wing. The wing will flex and has to be removed/installed. It just sits on the wing surface.
Bill Schertz
KIS Cruiser #4045
N343BS
Phase I testing
76papa(at)dishmail.net Guest
Posted: Fri Nov 06, 2009 9:04 am Post subject: Wing root fairing |
Wing root fairings are bonded to the fuselage and not the wing. When you remove the wing, the fairing stays with the fuselage.
Al
On Nov 6, 2009, at 9:52 AM, Bill Schertz wrote:
[quote]The fairing is NOT attached to the wing. The wing will flex and has to be removed/installed. It just sits on the wing surface.
Bill Schertz
KIS Cruiser #4045
N343BS
Phase I testing
[quote]---
jpetrie(at)sonicfactory.c Guest
Posted: Fri Nov 06, 2009 5:54 pm Post subject: Wing root fairing |
Not necessarily.
I bonded my route fairing to BOTH the fuselage AND the wing. After it was cured, I then cut it in half with a thin saw blade.
The end result is a VERY clean joint.
John
From: Alfred Rosa <[url=76papa(at)dishmail.net]76papa(at)dishmail.net[/url]>
Reply-To: <[url=kis-list(at)matronics.com]kis-list(at)matronics.com[/url]>
Date: Fri, 6 Nov 2009 11:58:46 -0500
Subject: Re: Wing root fairing
Al
Bill Schertz
KIS Cruiser #4045
N343BS
Phase I testing
[quote]---
bakerocb
Posted: Fri Nov 06, 2009 8:01 pm Post subject: Wing root fairing |
11/6/2009
Hello John, Where did you put the cut line? Do the cut edges stay pretty
well aligned? Any tape used?
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
Posted: Fri Nov 06, 2009 10:07 pm Post subject: Wing root fairing |
Thanks Bill,
I should have been a bit more specific, I was refering to the bottom wing root fairing that you slide into the slot you built up under the fuselage. Does this also "float" where it covers the wing and does it fit into the joggle at the inner edge of the underside of the wing? If you don't mind could you also explain how you constructed the slots on the fuselage.
Mike
Posted: Sat Nov 07, 2009 4:28 am Post subject: Wing root fairing |
Okay, that is a different story.
First, to make the 'slots': I laid a long straight edge (4' aluminum ruler if I recall) down on a flat table, laid a piece of poly over that so nothing would stick, and then laid a strip of 2 ply bid that went from the table up over the ruler to make a step. I put peel ply over the BID, and then brushed it down to make it conform over the step. After cure, it was trimmed to size, and then bonded to the bottom of the fuselage using Aeropoxy 6228 and clecoes. I then filled the bottom of the fuselage at the 'step' to smooth the transition using MICRO.
The fairing is attached to the wing with screws and nutplates, overlapping the 'joggle' and it 'floats' in the slot on the fuselage, that way there are no stresses when the wing flexes. At the front of the wing, the fairing tucks under the top fairing.
Bill Schertz
KIS Cruiser #4045
N343BS
Phase I testing
Posted: Sat Nov 07, 2009 11:42 am Post subject: Wing root fairing |
Thanks Bill,
I really like your solution and if you don't mind I'm going to copy it.
Mike
Posted: Sat Nov 07, 2009 12:14 pm Post subject: Wing root fairing |
Actually we should give credit to Bob Anderson, he did it first and I copied HIM!!
Bill Schertz
KIS Cruiser #4045
N343BS
Phase I testing
Posted: Sat Nov 07, 2009 12:35 pm Post subject: Wing root fairing |
Is this on Bob's web site. I'd like to see it.
Al
On Nov 7, 2009, at 3:12 PM, Bill Schertz wrote:
[quote]Actually we should give credit to Bob Anderson, he did it first and I copied HIM!!
Bill Schertz
KIS Cruiser #4045
N343BS
Phase I testing
[quote]---
Posted: Sat Nov 07, 2009 1:17 pm Post subject: Wing root fairing |
It is on Bob's site, look under:
Builders Construction
Bill Schertz
Fuselage Construction
It is the second last item on the list under Fuselage Construction
Mike
Posted: Wed Nov 11, 2009 10:18 pm Post subject: Wing root fairing |
Hi Bill
I presume you did a layup and used the bottom of your wing as a mold to make the panels for the bottom wing root fairing. What did you use as a release material and how thick did you make this layup.
Mike
Posted: Thu Nov 12, 2009 6:17 am Post subject: Wing root fairing |
Actually, the close out panel was supplied by KIS as a molded part (flat with curve for wing leading edge) as a single sheet. I had to cut it down the center and then make the curved cut to handle the transition at the front.
If this was not supplied, you will have to make your own by covering the wing with 2 mil poly, then making the layup over the poly, using peel ply. The factory piece looked to be more than 2-ply, I would go with 3-4 ply for that part.
Bill Schertz
KIS Cruiser #4045
N343BS
Phase I testing
bakerocb
Posted: Thu Nov 12, 2009 7:07 am Post subject: Wing root fairing |
11/12/2009
Hello Mike, When I made these fairings for my KIS TR-1 I set the fuselage
upside down, installed the wing (one piece wing for this plane), and molded
the fairings to fit exactly. I used primarily package sealing tape for
release material and to bridge the gap between fuselage and wing.
