Amsafe seat belts
dlm46007(at)cox.net
PostPosted: Sun Nov 01, 2009 4:20 pm    Post subject: Amsafe seat belts Reply with quote
IIRC I sent a set of belts to a 10 builder in AU . You might check the builders there; i know that one of the early sets went to Vans for inclusion in a finish kit to AU. Perhaps that builder can respond to you.
From: John Dunne [mailto:acs(at)acspropeller.com.au]
Sent: Sunday, November 01, 2009 4:50 PM
To: 'David McNeill'
Subject: RE: Amsafe seat belts
Thanks David, I don’t want to cost you a huge international phone bill so I’ll peruse the info you’ve sent me and contact you if I’m going to proceed down this track.
I had similar belts in my 182 and primarily like the freedom the inertia reels give you but also the added safety factor is attractive.
Thanks again for the info.
[b] [/b][b]ACS[/b] Propeller
John Dunne
Managing Director
www.acspropeller.com.au
Aviation Component Services (Qld) Pty Ltd.
trading as "ACS Propeller"
Building 612 Lores Bonney Drive,
Archerfield Airport Queensland Australia.
PH:61 7 3274 4500 FAX:61 7 3274 4010
"Everything Propeller"
Sent: Monday, 2 November 2009 9:03 AM
To: acs(at)acspropeller.com.au
Send me a pone number to discuss. I searched my files and found PDFS of the engineering drawings but it will take more research to find it all. we can talk about the process to install. You can get a better feel as to whether you want to do this.
Sent: Sunday, November 01, 2009 3:30 PM
To: dlm46007(at)cox.net
Subject: Amsafe seat belts
Hi David,
I’d be interested in any literature you might have or details on the inertia reel belts for the RV-10.
If you could shoot me some info I’d appreciate it.
Best regards,
Builder 40315
dlm46007(at)cox.net
PostPosted: Tue Nov 03, 2009 10:09 am    Post subject: AMSAFE seat belts Reply with quote
www.inertialbelts.com is on line again. The belts are shown in my Glastar as the belts were not installed in my 10 at that time. Rene has good pictures of the final finish. I will enclose one of his here.
 Filesize:  115.99 KB
 Viewed:  6392 Time(s)
jeff(at)westcottpress.com
PostPosted: Thu Nov 05, 2009 2:57 pm    Post subject: AMSAFE seat belts Reply with quote
I've got a couple of questions David:
How much weight are we adding with the inertia reel belts as opposed to the standard?
The hard points you show in you installation pictures are much more elaborate than what Vans provides for the stock belts. Is there a reason the inertia belts require more support, or do you feel the Vans hard points aren't enough for either approach?
Jeff Carpenter
40304
Finishing the inside of the cabin top... and making provisions for the belts
<P0002841.gif>
msausen
PostPosted: Thu Nov 05, 2009 6:55 pm    Post subject: AMSAFE seat belts Reply with quote
I think the overall concern is that the factory hardpoints are just not enough. I believe, as David said, AMSafe was concerned that additional reinforcement would up the safety margin. I know I feel a lot better after putting a couple of intersecting layers of S glass over the hardpoints.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jeff Carpenter
Sent: Thursday, November 05, 2009 4:20 PM
Subject: Re: AMSAFE seat belts
Jeff Carpenter
40304
<P0002841.gif>
[b]www.aeroelectric.comwww.buildersbooks.com
dlm46007(at)cox.net
PostPosted: Thu Nov 05, 2009 8:59 pm    Post subject: AMSAFE seat belts Reply with quote
Below is my reply to Jeff. I do believe that if you use the standard hardpoints and regular belts that you should at least use a CS stainless washer under the screw. This will spread the load on the glass and make a pull though more difficult.
don't know for sure but the total weight of four AMSAFE belts IIRC is less than 10 pounds. Incrementally I would say an additional 2-4 pounds over the standard belts. You add 4 3'x3'x1/2'' aluminum blocks and four rollers Check with Rene as he probably weighed the alternatives.
The existing hardpoints were deemed inadequate (for the AMSAFE application) by both AMSAFE and consultant (PhD, ME Caltech) who lives nearby. The vans hardpoints are setup for a single #5 counter sunk screw. This is installed without CS washer that would be required to spread the load. My ME consultant friend tells me that the normal use of the regular belts will cause micro fractures and may fail (pull through) if and when a crash occurs. AMSAFE commented that they would sell me the belts if I "beefed up" the existing hardpoints. Since the roller have screws for attaching the brackets I needed a means to attach the bracket Since I did not want 16 protruding though the lid I used the aluminum blocks (2024T3 or 7075) . These were tapped for 4 external screws to hold the pad that holds the roller. Each external screw has a .75" CS stainless washer and thereby spreading the load on the lid. In addition since the shoulder straps are on inertial reels there is no constant shear load on the single screw in the lid. The hardpoints areas were strengthened by additional E-glass and S-glass tapes. The calculations of the ME ,while informal, indicated that relative strengths could compared by comparing the surface areas of the fasteners. Hope this helps.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Thursday, November 05, 2009 7:01 PM
Subject: RE: RV10-List: AMSAFE seat belts
Michael
Jeff Carpenter
40304
<P0002841.gif>
8[/b] [quote][b]
rene(at)felker.com
PostPosted: Fri Nov 06, 2009 7:14 am    Post subject: AMSAFE seat belts Reply with quote
Sorry guys, I did not weight the belts. But……my CG is pretty far aft and if I was building another RV-10 I would reconsider a couple of things in order to move the CG forward. But I WOULD NOT give up the belts. Examples:
ELT
O2 System (Currently behind the bulkhead)
Battery(1 925 in tray)
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of David McNeill
Sent: Thursday, November 05, 2009 9:30 PM
Subject: RE: AMSAFE seat belts
Michael
Jeff Carpenter
40304
<P0002841.gif>
www.aeroelectric.comwww.buildersbooks.comwww.homebuilthelp.comhttp://www.matronics.com/contributionhttp://www.matronics.com/Navigator?RV10-Listhttp://forums.matronics.com
5
6
7
8
9
5
6
7
8
9
5
dlm46007(at)cox.net
PostPosted: Fri Nov 06, 2009 7:35 am    Post subject: AMSAFE seat belts Reply with quote
One thing that will help the CG is a 680 on the firewall on the lower right side and tied to a toggle breaker on the essential bus. You will get automatic trickle charge and additional backup or avionics, but you will need some isolation from the extra battery to avoid including it in the start. I put an automotive fuse on the positive lead at the battery terminal just in case the positive lead might come loose and flail around and ground. don't want to weld anything in flight.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rene Felker
Sent: Friday, November 06, 2009 7:27 AM
ELT
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Michael
Jeff Carpenter
40304
<P0002841.gif>
5
6
7
8
9
5
6
7
8
9
5
6 [quote][b]
Tim Olson
PostPosted: Fri Nov 06, 2009 7:38 am    Post subject: AMSAFE seat belts Reply with quote
Kinda helps blow away that myth that the CG in the -10 is too far
forward and it's "nose heavy", doesn't it. Smile
My opinion personally is that the RV-10's nose-heavyness should
not be something people should intentionally try to change,
because in the end they're likely going to find that they
WISHED they had the CG more forward. It used to be that
some people thought they wanted everything up front to be
lighter (i.e. props, and all the accessories) to help "fix"
the nose-heaviness. I think that in reality, the more you
take off the nose, the more CG worry you're going to
end up with, so best to just build the plane not considering
the plane to have any "nose heaviness" to "fix".
If you build it in a normal way, you will naturally be less
nose heavy than the Van's prototypes...because you'll already
have more interior features.
Tim Olson - RV-10 N104CD
belts. Examples:
ELT
Rene' Felker
RV-10 N423CF Flying
801-721-6080
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *David McNeill
*Sent:* Thursday, November 05, 2009 9:30 PM
*To:* rv10-list(at)matronics.com
*Subject:* RE: AMSAFE seat belts
the standard?
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *RV Builder
(Michael Sausen)
*Sent:* Thursday, November 05, 2009 7:01 PM
the hardpoints.
Michael
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Jeff Carpenter
*Sent:* Thursday, November 05, 2009 4:20 PM
*Subject:* Re: AMSAFE seat belts
the standard?
Jeff Carpenter
40304
www.inertialbelts.com <http://www.inertialbelts.com> is on line again.
<P0002841.gif>
*www.aeroelectric.com*
*www.buildersbooks.com*
*www.homebuilthelp.com*
*http://www.matronics.com/contribution*
*http://www.matronics.com/Navigator?RV10-List*
*http://forums.matronics.com*
*href="http://www.aeroelectric.com">www.aeroelectric.com*
*href="http://www.buildersbooks.com">www.buildersbooks.com*
*href="http://www.homebuilthelp.com">www.homebuilthelp.com*
*href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List*
*href="http://forums.matronics.com">http://forums.matronics.com*
*www.buildersbooks.com <http://www.buildersbooks.com>*
gengrumpy(at)aol.com
PostPosted: Fri Nov 06, 2009 7:51 am    Post subject: AMSAFE seat belts Reply with quote
FWIW, a forward CG is safer than an AFT CG.....
Grumpy
N184JM
> ELT
> Rene' Felker
> RV-10 N423CF Flying
> 801-721-6080
> *From:* owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com
> areas of the fasteners. Hope this helps. I've got a couple of
> questions David:
> ] *On Behalf Of *RV Builder (Michael Sausen)
> Michael
> Jeff Carpenter
> 40304
> the belts
> <P0002841.gif>
Tim Olson
PostPosted: Fri Nov 06, 2009 8:02 am    Post subject: AMSAFE seat belts Reply with quote
Exactly!
Grumpy
N184JM
>> belts. Examples:
>> ELT
>> Rene' Felker
>> RV-10 N423CF Flying
>> 801-721-6080
>> McNeill
>> alternatives.
>> comparing the surface areas of the fasteners. Hope this helps. I've
>> to the standard?
>> Michael
>> Carpenter
>> to the standard?
>> Jeff Carpenter
>> 40304
>> the belts
>> <P0002841.gif>
MauleDriver(at)nc.rr.com
PostPosted: Fri Nov 06, 2009 8:13 am    Post subject: AMSAFE seat belts Reply with quote
Agreed, if you are going to nudge the edges of the envelope. Heavier on
the controls versus lighter, less efficient versus more efficient, etc.
I like to think, "in the envelope is good, out of the envelope grounds
the aircraft". Understanding where you are in the acceptable range
allow you to adjust your technique, e.g. carrying trim or power in the
flare.
Bill "who knows nothing about the '10..... yet" Watson
Grumpy
N184JM
>> ELT
>> Rene' Felker
>> RV-10 N423CF Flying
>> 801-721-6080
>> McNeill
>> alternatives.
>> fasteners. Hope this helps. I've got a couple of questions David:
>> to the standard?
>> Michael
>> Carpenter
>> to the standard?
>> Jeff Carpenter
>> 40304
>> the belts
>> <P0002841.gif>
dmaib(at)mac.com
PostPosted: Fri Nov 06, 2009 6:41 pm    Post subject: AMSAFE seat belts Reply with quote
Agreed. I do think the "stock" RV-10 is a bit nose heavy. I ended up
with a CG a bit further aft than optimum because I put in the
Flightline AC air conditioning system and installed an MT propeller.
I think that having the extra weight of the Hartzell up front would
probably help a bit. As it is, I can put four normal size adults in
the airplane but will have to restrict my luggage to around 35 lbs.
About 98% or our flying is just Mary and I, so doesn't really slow us
down, but I am pretty careful about it.
David Maib
40559
Flying
ELT
Rene' Felker
RV-10 N423CF Flying
801-721-6080
questions David:
list-server(at)matronics.com] *On Behalf Of *RV Builder (Michael Sausen)
Michael
Jeff Carpenter
40304
the belts
<P0002841.gif>
