Thruster87
Posted: Sat Oct 24, 2009 12:39 pm Post subject: Nose wheel fork failure |
During high speed taxi runs at around 50knots lifted the nose wheel off and the mains maybe yes or no [ spectators not sure either] on lowering via elevator input [in hind site should have just pulled more elevator nose up for a smoother transition] the nose wheel come down and bumped back up[the runway has a couple of bumps as well] and on going down again the fork bent side ways as it hit the runway [due to a small right rudder input the wheel would have been pointing to the right].Basically the fork just collapsed/folded to the right jammed the nose wheel thus causing a prop strike,bent axle,firewall,and nose wheel strut. So it's back to the hangar for repairs and I'll look at strengthening the fork so it will resist the side loads better. Sitting here with a gnawing feeling in the pit of my stomach and trying to asses what went wrong. Cheers T87
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Sat Oct 24, 2009 1:06 pm Post subject: Re: Nose wheel fork failure |
Allan
If you need to borrow some parts till yours are ready / fixed give me a call. Sorry for your troubles..
Chris
Terry Phillips
Joined: 11 Jan 2006 Posts: 346 Location: Corvallis, MT
Posted: Sat Oct 24, 2009 1:59 pm Post subject: Nose wheel fork failure |
Bummer, T87
That is everyone's worst fear. I hope that your crankshaft is OK. The
linkage between the rudder and the nose wheel has long been one of my
concerns about the basic design. I wish there was an option for a castering
nose wheel. I'd love to just cover over those slots in the fire wall with
solid steel. Keep us informed about the repair process.
Terry
At 01:39 PM 10/24/2009 -0700, you wrote:
| Quote: | During high speed taxi runs at around 50knots lifted the nose wheel
Terry Phillips ZBAGer
ttp44~at~rkymtn.net
Corvallis MT
601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail, flaps, & ailerons
are done; waiting on the wings
http://www.mykitlog.com/N47TP/
_________________ Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings. |
ter_turn(at)yahoo.com Guest
First, sorry for your mishap..but it could have been worse! I'm sure there are other 601 XL drivers thinking about their up coming test flights..and I'm wondering (1) did you get any time in a 601XL prior and (2) are you going to reconsider high speed taxi runs based on your experience? I hope the damage is not too costly in time or money! Thanks.
Terry
--- On Sat, 10/24/09, Thruster87 <alania(at)optusnet.com.au> wrote:
Subject: Zenith601-List: Nose wheel fork failure
Date: Saturday, October 24, 2009, 3:39 PM
--> Zenith601-List message posted by: "Thruster87" <[url=/mc/compose?to=alania(at)optusnet.com.au]alania(at)optusnet.com.au[/url]>
http://forums.matronics.com/viewtopic.php?p=269254#269========================http://www.matronics.c --> http========================
Gig Giacona
Posted: Sat Oct 24, 2009 2:08 pm Post subject: Re: Nose wheel fork failure |
First off did you have the fork doubler in place?
Second 50 kt taxi runs are way too fast.
601XL Under Construction
bryanmmartin
Posted: Sat Oct 24, 2009 2:46 pm Post subject: Nose wheel fork failure |
Does your nosewheel fork have the doubler? My early plans did not show
a nosewheel doubler, and it didn't come with the kit. I bent my fork
on my first landing. The nosewheel fork doubler was added to later
plans.
I would suggest that anyone who attempts to lift the nosewheel off
during taxi tests should be prepared to cut the throttle immediately
and continue to hold the nose up and let it settle instead of trying
to push forward to set it back down. The elevator is surprisingly
responsive until you get used to it. I had a prop strike on mine
during my taxi tests by making the same mistake. The fact that I had a
70 inch prop instead of the current 68 inch prop didn't help either.
On Oct 24, 2009, at 4:39 PM, Thruster87 wrote:
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
_________________ --
Bryan Martin
do not archive. |
Thruster87
Posted: Sat Oct 24, 2009 4:38 pm Post subject: Re: Nose wheel fork failure |
I have the latest fork with the doubler installed, but it still folded side ways.I'd done about 3hrs of taxi runs prior two days at around the 40 knot mark and wanted to get near the lift-off envelope to see it would behave.We also did a couple of runs with two up at 45-50 knots and we lifted/lightened [not of the ground] the nose with no problems again to see how it would perform with the extra weight.It was just fine.On the day with two on board there was a 10knot cross wind and it weather cocked in a very predicable way and easy to handle.Just prior to the incident it had just passed the final inspection as well. Got the plane now back home and will start the repairs.In Hind site I'd just keep the stick back and use engine power to settle it down just like in a landing. ASAP Cheers Alan
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Sat Oct 24, 2009 7:08 pm Post subject: Re: Nose wheel fork failure |
Sorry to hear about that.
I have been considering spring loading the front wheel so it can track separately from the rudder. The front wheel really does need a good caster angle for this to work, but I have been thinking about it.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
jeyoung65(at)aol.com Guest
Posted: Sat Oct 24, 2009 7:10 pm Post subject: Nose wheel fork failure |
I just did some high speed taxi runs. Because my rudder and nose wheel were not inline I had a hard time keeping the aircraft on the runway untill I corrected it. I did not see the misalignment until the son pointed it out.I also was able to check the airspeed indicator during this taxi runs using the GPS, within 5 MPH up to 50 MPH. Would suggest all make hight speed taxi to see if the rudder and nose wheel are align Jerry of GA
Thruster87
Posted: Sat Oct 24, 2009 7:25 pm Post subject: Re: Nose wheel fork failure |
Don't have any pics of the collapsed fork as we straightened so we could move the aircraft
182.11 KB |
26291 Time(s) |
296.68 KB |
26291 Time(s) |
Thruster87
Posted: Sat Oct 24, 2009 7:28 pm Post subject: Re: Nose wheel fork failure |
And this
288.5 KB |
26287 Time(s) |
Posted: Sat Oct 24, 2009 8:03 pm Post subject: Nose wheel fork failure |
Does your fork have the doubler (6G1-5 on an XL)? Any photos?
-- Craig
Posted: Sat Oct 24, 2009 10:36 pm Post subject: Nose wheel fork failure |
On the photo of the front gear is that extra stepped rod resting in the V
block (below the main cross tube that links to the rudder pedals) your own
addition or something from the factory? I'm guessing you had to add it when
the cross tube on the factory part didn't reach the V because to the stop
plate on the top of the gear. I think I can also see an extra shim fitted
into the V of the black nylon part.
-- Craig
Thruster87
Posted: Sun Oct 25, 2009 1:18 am Post subject: Re: Nose wheel fork failure |
| craig(at)craigandjean.com wrote: | On the photo of the front gear is that extra stepped rod resting in the V
-- Craig
-- | It was a mod I did to allow the nose wheel to move more freely.It has a stainless steel rod with phosphor bronze bushes resting on a crom-moly plate bolted thru the bearing material for the V.It really made the rudder pedals free up and smooth to operate and self centering the same as the original.As you can see it stayed intact even thro the nose leg tube bent. Cheers
aussiech650
Joined: 04 Oct 2009 Posts: 25 Location: Sydney, Australia
Posted: Sun Oct 25, 2009 1:36 am Post subject: Re: Nose wheel fork failure |
Alan, I have an XL601 nose leg that I will not be using. Give me a call if you would like it.
Greg 0415610593.
Posted: Sun Oct 25, 2009 7:10 am Post subject: Nose wheel fork failure |
Ron,
That fork has a logical reason for failing and I'm sure it'll reveal
itself eventually.
The steerable linked nose gear is more asset than liability. To be able
to steer around potholes and rough fields is
a major improvement over differential braking. I've experienced both
types. For the tail dragger, it's logical, but for tri-gear
it would be detrimental to add a free-caster nose-wheel to side braking
mains. I know it's done in some aircraft, but
it's a much lesser solution to the steerable nose wheel.
Curious how the nose wheel steering got sideways far enough to fail the
fork. Or it would seem
there was not enough attention to where the nose wheel was at the time.
Ron Lendon wrote:
Ron Lendon, Clinton Township, MI
Zodiac XL, ScrapBuilder
http://home.comcast.net/~rlendon/site/
tigerrick(at)mindspring.c Guest
Posted: Sun Oct 25, 2009 7:43 am Post subject: Nose wheel fork failure |
Not to pick a fight here, Larry, but after flying close to 5000 hours in Grumman American airplanes with free castering nose gear, I have to object to your post.
Besides the obvious simplicity and ease of maintenance of the free castering design, its 180 degree pivot allows for incredibly tight turns while parking or simple maneuvering around objects. Assuming the airplane doesn't have a draggy brake on one side or the other, taxiing is a breeze with an occasional tap on the brake to maintain directional control.
The only negative I can see is replacing brake pads slightly more often, but pads are cheap and there's no linkage, springs, holes in the firewall, or any of the other hoopla associated with a steerable nosewheel. And best of all, the nose wheel alignment to the runway self corrects automatically upon landing, so any worry about side loads is moot.
Your claim that it's "a much lesser solution" needs some qualification. I'm curious, in what way?
Best,
Rick Lindstrom
ZenVair N42KP
Posted: Sun Oct 25, 2009 7:58 am Post subject: Nose wheel fork failure |
Could it be possible that the "free-caster nose wheel" is the problem? I do not understand how this was accomplish!!!!Landing in with a crosswind would indicate the nose wheel as cocked so when the nose wheel came down a side load was appllied to it. Now with a caster nose wheel, the nose wheel would be forced to turn to it's limit. Thus the fork could bend. My $0.02 Jerry of GA
Posted: Sun Oct 25, 2009 8:02 am Post subject: Nose wheel fork failure |
Rick, you are talking about a gear that is design to have a castering gear. The 601 nose gear was not designned for a castering nose wheel. On a castering nose wheel the strut is in front of the wheel center so the wheel is drag down the runway not pushed. Jerry of GA
bryanmmartin
Posted: Sun Oct 25, 2009 8:09 am Post subject: Nose wheel fork failure |
I don't think you should try to strengthen the fork any more than it
is. If you make it too strong, in a hard landing it would shift the
first point of failure to some other component. From the looks of
those photos, the nose gear must have come down very hard and it
wouldn't have helped much if the fork had stayed intact. That fork
absorbed a lot of energy before it failed. It won't do much good to
make the fork indestructible if it causes the strut to shear off and
you plant the nose on the runway at 40 mph.
At 50 mph and full throttle, that elevator has a whole lot of
authority, you have to use a light hand on it. At full throttle, once
that nosewheel comes off, that airplane wants to get airborne in a
hurry. Be ready to chop the throttle and let it settle in.
Bryan Martin
CH 601 XL
Builder No: 64003
Bryan Martin
do not archive. |
