naumuk(at)windstream.net Guest
Posted: Fri Oct 23, 2009 7:12 am Post subject: HDS Tire Pressure |
HDS people-
What PSI are you running in your tires?
Bill Naumuk
Townville, Pa.
HDS N601MG/Corvair 95%
Posted: Fri Oct 23, 2009 12:51 pm Post subject: HDS Tire Pressure |
Hi Bill,
I did use 21 to 23 psi, but found that when it cools, the tire pressure
drops a little below that and the plane is hard to roll.
Now the tires are 26 psi and the roll is very easy. When doing your
taxi testing, easy rolling is better for feeling what the
plane is doing.
Bill Naumuk wrote:
| Quote: | HDS people-
Bill Naumuk
Townville, Pa.
leo.gates
Posted: Fri Oct 23, 2009 1:24 pm Post subject: HDS Tire Pressure |
Bill, 20 PSI mains, 25 PSI tail, in my HDS, 674 empty weight, tail dragger.
Leo Gates
N601Z, CH601HDS TDO
Bill Naumuk
Townville, Pa.
Posted: Sat Oct 24, 2009 6:57 am Post subject: HDS Tire Pressure |
Leo and Larry-
I'm glad I asked. One part of the instructions says to "Inflate the tire
to 30 PSI" and in a later section "Wait until the wheel is mounted on the
fork before FULLY inflating". The max rated PSI on the tire is 90, and the
only other reference I had was the tire on my wheelbarrow, which runs 45
PSI. I would have never thought the final pressure would be less than 30
PSI, which, as I interpreted the instructions, was a starting point.
Thanks.
Bill
