kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Fri Oct 23, 2009 11:16 am Post subject: Fuel level sender and tank removal with 7-WTA-1 cover |
What is the reason for moving the fuel sender to the side? It seems at the very least more leak proof on top.
And for those with the optional 7-WTA-1 wing tank cover two questions:
Can you remove the tank easily through the opening?
Can you use two per wing for dual tanks?
I ask because I am thinking of a second set of covers just in case I want to add a second set of tanks later.
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
mksoucy(at)yahoo.com Guest
Posted: Sat Oct 24, 2009 9:04 am Post subject: Fuel level sender and tank removal with 7-WTA-1 cover |
What is the wta tank cover. I emailed zenair last week asking about an access panel on the top of the wing because I have serious issues burying the fuel tank. I was told no panel on top but I could make the top skin in two pieces and put an access on bottom between root and no.1 rib. Curious if anyone has seen other options.
701 scratch
Sent from my iPod
On Oct 23, 2009, at 3:16 PM, "kmccune" <kmccune(at)somtel.net> wrote:
What is the reason for moving the fuel sender to the side? It seams at the very least more leak proof on top.
Kevin
History is a great teacher if you take time to study it.
Steve Bennett
http://forums.matronics.com/viewtopic.php?p 69137#269137
kmccune
Posted: Sat Oct 24, 2009 3:53 pm Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover |
In didn't even check if this is still an option. It was emailed to me. But here is what I have.
Kevin
34.56 KB |
13751 Time(s) |
Dorothy McCune |
bryanekholm
Posted: Mon Oct 26, 2009 12:52 pm Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover |
Kevin,
The wing tank access cover shown in the plans is what I am planning on doing with my wings. I see no problem with using a cover as shown. And it beats removing the whole top skin or half of a top skin to get at the tanks if necessary.
Bryan Ekholm
Scratch Builder
_________________ Bryan Ekholm |
kmccune
Posted: Mon Oct 26, 2009 1:40 pm Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover |
This is not even shown in my plans, someone emailed me the above pic. I guess my question is can it be made for dual tanks too. I did yesterday on the Zenith builder site see that Ken P has dual tanks and a big opening in the skin, so presumably a big single cover.
Kevin
Dorothy McCune |
kmccune
Posted: Tue Oct 27, 2009 11:32 am Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover |
Here is a link to Ken Podaimas' tanks
http://www.zenith.aero/photo/wing-tanks-1?context=album&albumId=2606393%3AAlbum%3A27640
Kevin
Dorothy McCune |
bryanekholm
Posted: Wed Oct 28, 2009 6:57 am Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover |
Kevin,
Since I'm at my work computer, the zenith.aero website is filtered as a "social networking" site and won't display any of the pictures. I do get the text, but not the pictures. So if you it's possible, could you please attach the photo of Ken's wing tank cover to this topic string. This site is not filtered.
Bryan
kmccune
Posted: Wed Oct 28, 2009 12:44 pm Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover |
Her it is, my apologies to Ken for posting with out permission.
Kevin
1.73 MB |
13658 Time(s) |
Dorothy McCune |
d.shrader
Posted: Mon Nov 02, 2009 1:43 am Post subject: Re: Fuel level sender and tank removal with 7-WTA-1 cover |
| kmccune wrote: | What is the reason for moving the fuel sender to the side? It seems at the very least more leak proof on top.
Kevin |
Just split the skin (lap joint) at the rib outboard of where the aux. tank goes that way you have one section of wing skin that can be removed that will expose both tanks and pluming behind the tank support and the plumbing at the main tank..... fuel leaks are a pita and there is no better insurance than easy access in my opinion
| lap joint at last row of clecos |
857.92 KB |
13605 Time(s) |
