ChangDriver
Posted: Wed Oct 21, 2009 8:33 pm Post subject: Lacing |
Bob:
You mentioned Dacron lacing as a good alternative to high temp wire ties in the engine compartment. Is there a good place to get the material and where would I find a tutorial on how to lace?
Craig
Neal.George(at)hurlburt.a Guest
Posted: Thu Oct 22, 2009 4:31 am Post subject: Lacing |
Craig -
Stein carries lacing:
http://www.steinair.com/accessories.htm
Sixth item down the page.
And here's a link to Bob's shop notes on tying bundles:
http://www.aeroelectric.com/articles/cable_lace/cable_lace.html
neal
Bob:
Craig
 Download |
| Filename: |
smime.p7s |
5.04 KB |
| Downloaded: |
468 Time(s) |
Posted: Thu Oct 22, 2009 6:03 am Post subject: Lacing |
At 11:33 PM 10/21/2009, you wrote:
<capav8r(at)gmail.com>
Bob:
I don't recommend a "running lace" for
aircraft wiring. Spot ties used on the same
frequency as you might use tie-wraps is
preferred. See:
Aircraft Spruce, Steinair, and many electronic supply
houses stock lacing tape. See:
http://www.aeroelectric.com/Mfgr_Data/Misc/Lacing_Tape/
My favorite is the Type II, Size 3, Finish B but
they're all suited to your task.
( -Thomas Paine 1776- )
ChangDriver
Posted: Thu Oct 22, 2009 3:29 pm Post subject: Re: Lacing |
Intersting as the avionics shop on my field said using wax covered lacing cord was not appropriate under the cowling. Comments?
Craig
Posted: Thu Oct 22, 2009 4:40 pm Post subject: Lacing |
At 06:29 PM 10/22/2009, you wrote:
The clove hitch methodology (I) leaves the knot
in tension and would probably be more secure
if not waxed. I've not had any knots come loose
when you tie 'em up like (II) . . .
http://aeroelectric.com/articles/cable_lace/cable_lace.html
The knot serves only to provide a "lump" that
stops the free ends from slipping though the noose-
loop, there's little or no tension on the final
knot.
Actually, I think the waxed cord gets you a tighter
knot because the string slides over itself easier
during the tightening process. But all the
listed tapes are better than nylon-tie wraps.
