680 FL
wjrhamilton(at)optusnet.c
PostPosted: Tue Oct 13, 2009 4:43 am    Post subject: 680 FL Reply with quote
Folks,
I am soliciting opinions on the 400hp direct drive conversion to the 680F/FL/FLP.
My only experience of (roughly) the same engine was on the 400 Comanche and the Excalibur conversion to the Queenair A80, neither were particularly happy experiences, with quite a few problems with a big spread of CHT.
Bill Hamilton
 Filesize:  530 Bytes
 Viewed:  4276 Time(s)
kamala(at)MSN.COM
PostPosted: Tue Oct 13, 2009 5:16 am    Post subject: 680 FL Reply with quote
bh C please call me C i will visit w/ you about the io-720. gmc   817-877-4977
Subject: 680 FL
Date: Tue C 13 Oct 2009 23:41:18 +1100
.ExternalClass p.ecxMsoNormal C .ExternalClass li.ecxMsoNormal C .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Calibri' C'sans-serif';color:black;} .ExternalClass h1 {margin-right:0cm;margin-bottom:0cm;margin-left:0cm;margin-bottom:.0001pt;page-break-after:avoid;font-size:16.0pt;font-family:'Calibri' C'sans-serif';color:black;} .ExternalClass h2 {margin-right:0cm;margin-bottom:0cm;margin-left:0cm;margin-bottom:.0001pt;page-break-after:avoid;font-size:14.0pt;font-family:'Calibri' C'sans-serif';color:black;font-weight:normal;} .ExternalClass h3 {margin-right:0cm;margin-bottom:0cm;margin-left:0cm;margin-bottom:.0001pt;page-break-after:avoid;font-size:13.0pt;font-family:'Calibri' C'sans-serif';color:black;font-weight:normal;} .ExternalClass h4 {margin-right:0cm;margin-bottom:0cm;margin-left:0cm;margin-bottom:.0001pt;page-break-after:avoid;font-size:14.0pt;font-family:'Calibri' C'sans-serif';color:black;font-weight:normal;} .ExternalClass h5 {margin-right:0cm;margin-bottom:0cm;margin-left:0cm;margin-bottom:.0001pt;page-break-after:avoid;font-size:13.0pt;font-family:'Calibri' C'sans-serif';color:black;font-weight:normal;} .ExternalClass h6 {margin-right:0cm;margin-bottom:0cm;margin-left:0cm;margin-bottom:.0001pt;page-break-after:avoid;font-size:11.0pt;font-family:'Calibri' C'sans-serif';color:black;font-weight:normal;} .ExternalClass a:link C .ExternalClass span.ecxMsoHyperlink {color:#993300;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.ecxMsoHyperlinkFollowed {color:blue;text-decoration:underline;} .ExternalClass span.ecxEmailStyle17 {color:black;} .ExternalClass span.ecxHeading1Char {font-family:'Trebuchet MS' C'sans-serif';color:black;font-weight:bold;} .ExternalClass span.ecxHeading2Char {font-family:'Trebuchet MS' C'sans-serif';color:black;} .ExternalClass span.ecxHeading3Char {font-family:'Trebuchet MS' C'sans-serif';color:black;} .ExternalClass span.ecxHeading4Char {font-family:'Trebuchet MS' C'sans-serif';color:black;} .ExternalClass span.ecxHeading5Char {font-family:'Trebuchet MS' C'sans-serif';color:black;} .ExternalClass span.ecxHeading6Char {font-family:'Trebuchet MS' C'sans-serif';color:black;} .ExternalClass .ecxMsoChpDefault {;} (at)page Section1 {size:612.0pt 792.0pt;} .ExternalClass div.ecxSection1 {page:Section1;} [img]cid:image001.gif(at)01CA4C5E.837F8650[/img]
Folks C
My only experience of (roughly) the same engine was on the 400 Comanche and the Excalibur conversion to the Queenair A80 C neither were particularly happy experiences C with quite a few problems with a big spread of CHT.
Regards C
Bill Hamilton
 Filesize:  530 Bytes
white_rhino_ps(at)yahoo.c
PostPosted: Tue Oct 13, 2009 5:52 am    Post subject: 680 FL Reply with quote
Bill,
Admitting no first hand experience, I did watch my mechanic/restoration guru Richard Cam dial in a set of Gami's on 2 different QueenAirs. The temp problems were eliminated, and the fuel flows reduced by 10%. It's still underpowered, but not the problem it once was. The fit of the cowlings, and baffle seals got a lot of attention as well. While the Gami's have not been fitted to my IGO-540's, they have indicated they will work with me to fit a set. He's in St. Augustine (Aeroquest Services) if you want the report first hard. He has a lot of first hand experience wit the Mr. RPM conversions as well.
Good Luck
C
From: Bill Hamilton <wjrhamilton(at)optusnet.com.au>
Sent: Tue, October 13, 2009 5:41:18 AM
Subject: 680 FL
[img]cid:1.1782779744(at)web82205.mail.mud.yahoo.com[/img]
Folks,
Bill Hamilton
 Filesize:  530 Bytes
 Viewed:  4275 Time(s)
PostPosted: Thu Oct 15, 2009 4:07 am    Post subject: 680 FL Reply with quote
C
Thanks for that, but my prior was BG ( not BC – before Gami)
Off topic, but in the ‘60s, TAA in Australia had a small fleet of A-80s, they did a complete certification of T/O performance at METO power, to get a bit more life of the IGSO-540-B1As. They also decided to make more baggage space by burying all the avionics inside modified leading edges of the wings, then proceeded to operate some in Australia wettest areas. You can guess the rest.
Bill Hamilton
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of craig kennedy
Sent: Wednesday, October 14, 2009 12:53 AM
Subject: Re: 680 FL
Bill,
Good Luck
C
Subject: 680 FL
Folks,
Bill Hamilton
 Filesize:  530 Bytes
 Viewed:  4268 Time(s)
PostPosted: Thu Oct 15, 2009 4:11 am    Post subject: 680 FL Reply with quote
Mason,
I am in Australia, I will see if I can give you a call, what is your present time zone re. UTC.
Bill Hamilton
From: owner-commander-list-server(at)matronics.com [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of MASON CHEVAILLIER
Sent: Wednesday, October 14, 2009 12:11 AM
To: commander-list
Subject: RE: 680 FL
bh, please call me, i will visit w/ you about the io-720. gmc 817-877-4977
Subject: 680 FL
Date: Tue, 13 Oct 2009 23:41:18 +1100
Folks,
Bill Hamilton
 Filesize:  530 Bytes
kamala(at)MSN.COM
PostPosted: Thu Oct 15, 2009 4:21 am    Post subject: 680 FL Reply with quote
bh C 7:20 am.  cell  817-517-4977. gmc
Subject: RE: 680 FL
Date: Thu C 15 Oct 2009 23:10:03 +1100
.ExternalClass .ecxshape {;} .ExternalClass p.ecxMsoNormal C .ExternalClass li.ecxMsoNormal C .ExternalClass div.ecxMsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass h1 {margin-right:0cm;margin-left:0cm;font-size:24.0pt;font-family:'Times New Roman' C'serif';font-weight:bold;} .ExternalClass h2 {margin-right:0cm;margin-left:0cm;font-size:18.0pt;font-family:'Times New Roman' C'serif';font-weight:bold;} .ExternalClass h3 {margin-right:0cm;margin-left:0cm;font-size:13.5pt;font-family:'Times New Roman' C'serif';font-weight:bold;} .ExternalClass h4 {margin-right:0cm;margin-left:0cm;font-size:12.0pt;font-family:'Times New Roman' C'serif';font-weight:bold;} .ExternalClass h5 {margin-right:0cm;margin-left:0cm;font-size:10.0pt;font-family:'Times New Roman' C'serif';font-weight:bold;} .ExternalClass h6 {margin-right:0cm;margin-left:0cm;font-size:7.5pt;font-family:'Times New Roman' C'serif';font-weight:bold;} .ExternalClass a:link C .ExternalClass span.ecxMsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.ecxMsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass p {margin-right:0cm;margin-left:0cm;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass span.ecxHeading1Char {font-family:'Cambria' C'serif';color:#365F91;font-weight:bold;} .ExternalClass span.ecxHeading2Char {font-family:'Cambria' C'serif';color:#4F81BD;font-weight:bold;} .ExternalClass span.ecxHeading3Char {font-family:'Cambria' C'serif';color:#4F81BD;font-weight:bold;} .ExternalClass span.ecxHeading4Char {font-family:'Cambria' C'serif';color:#4F81BD;font-weight:bold;font-style:italic;} .ExternalClass span.ecxHeading5Char {font-family:'Cambria' C'serif';color:#243F60;} .ExternalClass span.ecxHeading6Char {font-family:'Cambria' C'serif';color:#243F60;font-style:italic;} .ExternalClass p.ecxecxmsonormal C .ExternalClass li.ecxecxmsonormal C .ExternalClass div.ecxecxmsonormal {margin-right:0cm;margin-left:0cm;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass span.ecxecxmsohyperlink {;} .ExternalClass span.ecxecxmsohyperlinkfollowed {;} .ExternalClass span.ecxecxemailstyle17 {;} .ExternalClass span.ecxecxheading1char {;} .ExternalClass span.ecxecxheading2char {;} .ExternalClass span.ecxecxheading3char {;} .ExternalClass span.ecxecxheading4char {;} .ExternalClass span.ecxecxheading5char {;} .ExternalClass span.ecxecxheading6char {;} .ExternalClass p.ecxecxmsonormal1 C .ExternalClass li.ecxecxmsonormal1 C .ExternalClass div.ecxecxmsonormal1 {margin-right:0cm;margin-bottom:0cm;margin-left:0cm;margin-bottom:.0001pt;font-size:12.0pt;font-family:'Calibri' C'sans-serif';color:black;} .ExternalClass span.ecxecxmsohyperlink1 {color:#993300;text-decoration:underline;} .ExternalClass span.ecxecxmsohyperlinkfollowed1 {color:blue;text-decoration:underline;} .ExternalClass span.ecxecxemailstyle171 {color:black;} .ExternalClass span.ecxecxheading1char1 {font-family:'Trebuchet MS' C'sans-serif';color:black;font-weight:bold;} .ExternalClass span.ecxecxheading2char1 {font-family:'Trebuchet MS' C'sans-serif';color:black;} .ExternalClass span.ecxecxheading3char1 {font-family:'Trebuchet MS' C'sans-serif';color:black;} .ExternalClass span.ecxecxheading4char1 {font-family:'Trebuchet MS' C'sans-serif';color:black;} .ExternalClass span.ecxecxheading5char1 {font-family:'Trebuchet MS' C'sans-serif';color:black;} .ExternalClass span.ecxecxheading6char1 {font-family:'Trebuchet MS' C'sans-serif';color:black;} .ExternalClass span.ecxEmailStyle44 {font-family:'Calibri' C'sans-serif';color:#1F497D;} .ExternalClass .ecxMsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:612.0pt 792.0pt;} .ExternalClass div.ecxSection1 {page:Section1;}
Mason C
I am in Australia C I will see if I can give you a call C what is your present time zone re. UTC.
Cheers C
Bill Hamilton
Sent: Wednesday C October 14 C 2009 12:11 AM
To: commander-list
Subject: RE: 680 FL
Subject: 680 FL
Folks C
Regards C
Bill Hamilton
 Filesize:  530 Bytes
tylorhall(at)mac.com
PostPosted: Thu Oct 15, 2009 5:11 am    Post subject: 680 FL Reply with quote
Bill,Mason is in Texas which is UTC-5. Central daylight savings zone.
Sidney is UTC +11. I am not sure
It is Friday just after midnight now and in Texas it is just after 8 am on Thurday.
Tylor Hall
On Oct 15, 2009, at 6:20 AM, MASON CHEVAILLIER wrote:
bh, 7:20 am. cell 817-517-4977. gmc
From: wjrhamilton(at)optusnet.com.au (wjrhamilton(at)optusnet.com.au)
To: commander-list(at)matronics.com (commander-list(at)matronics.com)
Subject: RE: 680 FL
Date: Thu, 15 Oct 2009 23:10:03 +1100
Mason,
Bill Hamilton
From: owner-commander-list-server(at)matronics.com (owner-commander-list-server(at)matronics.com) [mailto:owner-commander-list-server(at)matronics.com] On Behalf Of MASON CHEVAILLIER
To: commander-list
Subject: RE: 680 FL
Subject: 680 FL
<image001.gif>
Folks,
Bill Hamilton
