WurlyBird
Joined: 16 May 2008 Posts: 207 Location: North Pole, Alaska
Posted: Sun Oct 11, 2009 11:27 am Post subject: Blue Bing Fuel Tubing |
Is there any reason to not use the blue polyurethane fuel tubing from Bing on the pressure side of the fuel pump? I need to replace some tubing and that is what I have on hand and understand can be used but the tubing that is coming off is 2 layer with webbing (presumably nylon) in between. Is this heavy of tubing needed between the pump and the carb?
Sorry I always have the stupid questions, unfortunately I can spend all day at work on the net but if I bust out experimental aircraft manuals people get upset.
Thanks for the help.
James
_________________ James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl. |
Tom Jones
Posted: Sun Oct 11, 2009 4:26 pm Post subject: Re: Blue Bing Fuel Tubing |
James asked:
| Quote: | | Is there any reason to not use the blue polyurethane fuel tubing from Bing on the pressure side of the fuel pump? |
That is what I have been using.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
WurlyBird
Posted: Sun Oct 11, 2009 7:39 pm Post subject: Re: Blue Bing Fuel Tubing |
Now that there is time, here is why I am replacing the lines. A fun "luck" story. I was giving a ride to a friend and we took off in marginal winds, 10 gusting 17 straight down the runway, but it was the forecast high for the day so we went with it. At some point I decided we were done and we headed back. AWOS called 17 gusting 27 still straight down the runway, at least we were going to have a low ground speed at touchdown. I opted to not do my normal 3 touch and goes to end the flight and we landed just the once with a walking speed touchdown and a 30 foot roll out. As we got out my friend asked if the fluid draining out of the cowl was normal, it was fuel. The fuel line that was used had become quite hardened and apparently cracked at the rear carb. I later told my friend how if we had taken off on a touch and go the rear carb would have starved and we would have had partial power at best on climb out and we would have landed in a best case scenario with a 20 kt tail wind on the runway.
I figured the reinforced fuel line was excessive but I just couldn't step down straight to the blue lines with out knowing, so this morning I replaced both lines from the pump with fuel injection tubing so there was no question. Clocked 1.3 today with no issues. I will be switching to the bing lines through out when I redo the fuel system later this year.
Guy Buchanan
Posted: Sun Oct 11, 2009 8:48 pm Post subject: Blue Bing Fuel Tubing |
At 12:27 PM 10/11/2009, you wrote:
| Quote: | Is there any reason to not use the blue polyurethane fuel tubing
James,
I've been using it downstream of the pump for the last few
years and about 460 hours. No problem. I replace the stuff in the
engine compartment yearly, though. (Paranoid.)
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 400 hrs. and counting
Deceased K-IV 1200
A glider pilot too. |
WurlyBird
carlisle
Joined: 20 Jun 2009 Posts: 72 Location: Sioux Falls, SD
larry huntley
Posted: Thu Oct 15, 2009 3:25 am Post subject: Blue Bing Fuel Tubing |
You should use it to cover any fuel lines forward of the firewall. You won't
care about ugly if you have flames up there. Larry
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
Lynn Matteson
Posted: Thu Oct 15, 2009 5:07 am Post subject: Blue Bing Fuel Tubing |
If you think fire sleeve is ugly, think what this scene would have
looked like if I DIDN'T have the fire sleeve in place. The flames
which resulted from a broken off tail pipe were hot enough to blister
the motor mount paint, char the fire sleeve, sneak around the battery
box and melt a hole in the battery, and let the electrolyte out of
one cell.
Even before this happened, I thought the fire sleeve was cool-
looking. I now think it's even cooler!
p.s. There was an aluminum heat shield in place between the muffler
and the carb....it is now made from stainless steel and it's bigger.
Any future exhaust flames will find it a bit more difficult to get
near the fuel lines or my Rotec TBI fuel-metering device...the Bing
is gone.
Lynn Matteson
Jabiru 2200, #2062, 795.1 hrs
Countdown to 1000 hrs~207 to go
Sensenich 62"x46" Wood prop
Rotec TBI-40 injection
Status: flying
On Oct 14, 2009, at 11:23 PM, carlisle wrote:
Do you guys use any kind of fire shield on the fuel tubing? One of
my mechanic buddies had some extra lying around. You know, the
orange sleeve stuff with the little fibers inside (probably
asbestos that you slide onto the fuel tubing. I think it's
used on hydraulic lines on larger aircraft. I'm not sure how much
good it would do if there were a fire though and it's ugly to boot.
Chris
407.25 KB |
14723 Time(s) |
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Tom Jones
Posted: Thu Oct 15, 2009 5:24 am Post subject: Re: Blue Bing Fuel Tubing |
I installed fire sleeve on the fuel lines forward of the fire wall. It came with the kit. I like the idea of just keeping heat off the lines in general as well as the flames incase of fire.
Prices are by the foot. http://www.aircraftspruce.com/catalog/appages/aqfiresleeve.php
112.7 KB |
14711 Time(s) |
103.78 KB |
14711 Time(s) |
Classic IV
Ellensburg, WA |
Fox5flyer Guest
Posted: Thu Oct 15, 2009 5:40 am Post subject: Blue Bing Fuel Tubing |
That picture replaces a thousand words.
thanks,
Deke
Guy Buchanan
Posted: Thu Oct 15, 2009 6:31 am Post subject: Blue Bing Fuel Tubing |
At 08:23 PM 10/14/2009, you wrote:
| Quote: | Do you guys use any kind of fire shield on the fuel tubing?
I use it throughout the engine compartment. I run the fire sleeve
over the entire tube and put my hose clamp over the fire sleeve and
blue tube in one go. That way the entire hose is fire sleeved.
Haven't had a problem with this in 460 hours. I do make sure the fire
sleeve fits tight on my blue hose. No baggy lines for me.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
Pat Reilly
Posted: Thu Oct 15, 2009 6:51 am Post subject: Blue Bing Fuel Tubing |
Chris, I have the firesleeve on my fuel lines. I don't have anything protecting my plastic primer lines though. Do any of you guys put fire sleeve on the primer lines? Seems like I should protect those also.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
On Wed, Oct 14, 2009 at 10:23 PM, carlisle <carlisle_99(at)yahoo.com (carlisle_99(at)yahoo.com)> wrote:
[quote]--> Kitfox-List message posted by: "carlisle" <carlisle_99(at)yahoo.com (carlisle_99(at)yahoo.com)>
Do you guys use any kind of fire shield on the fuel tubing? One of my mechanic buddies had some extra lying around. You know, the orange sleeve stuff with the little fibers inside (probably asbestos that you slide onto the fuel tubing. I think it's used on hydraulic lines on larger aircraft. I'm not sure how much good it would do if there were a fire though and it's ugly to boot.
Chris
http://forums.matronics.com/viewtopic.php?p=268004#268004
Subscription,
www.matronics.com/Navigator?Kitfox-List" target="_blank">http://www.matronics.com/Navigator?Kitfox-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Lynn Matteson
Posted: Thu Oct 15, 2009 7:23 am Post subject: Blue Bing Fuel Tubing |
I would.....those lines would probably melt a lot quicker than the
rubber/neoprene/blue line/whatever hoses. And if I'm not mistaken,
isn't there some residual fuel left in those lines after a use of the
primer? It seems like they would not drain completely after priming,
and it they caught fire, the fire might find its way into the
cabin....and that's where you sit, isn't it Pat? : )
Lynn Matteson
Status: flying
On Oct 15, 2009, at 10:47 AM, Patrick Reilly wrote:
| Quote: | Chris, I have the firesleeve on my fuel lines. I don't have
protect those also.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
On Wed, Oct 14, 2009 at 10:23 PM, carlisle <carlisle_99(at)yahoo.com>
Chris
http://forums.matronics.com/viewtopic.php?p 68004#268004
Subscription,
www.matronics.com/contribution _-
N369LM |
Pat Reilly
Posted: Thu Oct 15, 2009 7:44 am Post subject: Blue Bing Fuel Tubing |
Lynn, I guess I'll have to find some small enough firesleeve to protect those primer lines. It doesn't make sense to protect the more fire resistant rubber lines and not the plastic primer lines. And, yes there is definitely gas in them.
Pat Reilly
On Thu, Oct 15, 2009 at 10:21 AM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
[quote]--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
I would.....those lines would probably melt a lot quicker than the rubber/neoprene/blue line/whatever hoses. And if I'm not mistaken, isn't there some residual fuel left in those lines after a use of the primer? It seems like they would not drain completely after priming, and it they caught fire, the fire might find its way into the cabin....and that's where you sit, isn't it Pat? : )
Lynn Matteson
Status: flying
[quote] Chris, I have the firesleeve on my fuel lines. I don't have anything protecting my plastic primer lines though. Do any of you guys put fire sleeve on the primer lines? Seems like I should protect those also.
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Chris
Subscription,
ist Un/Subscription,
Fox5flyer Guest
Posted: Thu Oct 15, 2009 10:14 am Post subject: Blue Bing Fuel Tubing |
You might just eliminate the worries and go with metal lines.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
Lynn Matteson
Posted: Thu Oct 15, 2009 11:58 am Post subject: Blue Bing Fuel Tubing |
Ohmigod, yes.....I must've been in a fog, 'cause I didn't even think
about that, Deke. And I just got done running some primer lines on a
C-172...metal all the way, and stainless steel at that. Also, I was
told that everything "north" of the firewall should not be copper
either, let alone plastic. But after all, we are "experimental",
aren't we? : )
Pat, you could slice the fire sleeve down the length of it and wrap
it around the line(s) in question, then safety wire it in place. This
would discourage the flames. I did this on my main fuel line where it
runs under the seat, and was chafing on the bottom fabric. I didn't
want to disturb the connections, so I just sliced a length of fire
sleeve, wrapped it around the fuel line, and safety wired it in
place. In this case it was more for anti-chafe than fire protection,
but you get the idea.
Lynn Matteson
Jabiru 2200, #2062, 796.4 hrs
Status: flying
On Oct 15, 2009, at 1:59 PM, fox5flyer wrote:
[quote] You might just eliminate the worries and go with metal lines.
Deke Morisse
Mikado Michigan
N369LM |
Pat Reilly
Posted: Thu Oct 15, 2009 12:25 pm Post subject: Blue Bing Fuel Tubing |
Lynn, I found some firesleeve down to 1/4" I.D. in the LEAF catalog. Says it's a new product. I will order some when I get to the hanger to see how much I need. You live close to Deke?
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
On Thu, Oct 15, 2009 at 2:51 PM, Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)> wrote:
[quote] --> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
Ohmigod, yes.....I must've been in a fog, 'cause I didn't even think about that, Deke. And I just got done running some primer lines on a C-172...metal all the way, and stainless steel at that. Also, I was told that everything "north" of the firewall should not be copper either, let alone plastic. But after all, we are "experimental", aren't we? : )
Pat, you could slice the fire sleeve down the length of it and wrap it around the line(s) in question, then safety wire it in place. This would discourage the flames. I did this on my main fuel line where it runs under the seat, and was chafing on the bottom fabric. I didn't want to disturb the connections, so I just sliced a length of fire sleeve, wrapped it around the fuel line, and safety wired it in place. In this case it was more for anti-chafe than fire protection, but you get the idea.
Lynn Matteson
Status: flying
[quote]You might just eliminate the worries and go with metal lines.
Deke Morisse
Mikado Michigan
Pat Reilly
Deke, Thanks for suggestion. I found firesleve down to 1/4" I.D. in the LEAF catalog. Love Milton Friedman!
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
On Thu, Oct 15, 2009 at 12:59 PM, fox5flyer <fox5flyer(at)idealwifi.net (fox5flyer(at)idealwifi.net)> wrote:
Deke Morisse
Mikado Michigan
Lynn Matteson
Posted: Thu Oct 15, 2009 12:41 pm Post subject: Blue Bing Fuel Tubing |
About 175 statute miles....he's up north of me in snow country, the
lucky devil. : )
Lynn Matteson
Countdown to 1000 hrs~204 to go
Status: flying
On Oct 15, 2009, at 4:19 PM, Patrick Reilly wrote:
[quote] Lynn, I found some firesleeve down to 1/4" I.D. in the LEAF
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
On Thu, Oct 15, 2009 at 2:51 PM, Lynn Matteson <lynnmatt(at)jps.net>
Lynn Matteson
Status: flying
Deke Morisse
Mikado Michigan
N369LM |
pchristensen10(at)austin. Guest
Posted: Thu Oct 15, 2009 12:57 pm Post subject: Blue Bing Fuel Tubing |
Lynn<
Safety wire? Is that airplane talk for bailing wire? :>)
Pete
