alsmith
Posted: Mon Oct 12, 2009 6:08 am Post subject: Propeller Selection |
We are building a CH 650 and will be installing a O-200A
Engine.
What are others installing by brand and Size?
sabrina
Posted: Mon Oct 12, 2009 7:46 am Post subject: Re: Propeller Selection |
alsmith
Posted: Mon Oct 12, 2009 8:10 am Post subject: Re: Propeller Selection |
Thanks for the input
Al
CH-650
KEOS
vk3eka(at)bigpond.net.au Guest
Posted: Mon Oct 12, 2009 12:41 pm Post subject: Propeller Selection |
Al,
I'm using a three blade 68 inch warp drive. Not flying yet but the engines
running and feels good. I used Lightspeed plugs/adapter on the top cylinders
(ala AMD) so as to use the standard cowl with no "blisters"/prop extns etc.
Cheers
Peter
Wonthaggi Australia
http://zodiac.cpc-world.com
slandwcmitch(at)yahoo.com Guest
Posted: Wed Oct 14, 2009 10:24 am Post subject: Propeller Selection |
Question relating to propeller and O-200 engine, where is the placement of the battery in your projects? Can anybody help me out ?
z601a(at)anemicaardvark.c Guest
Posted: Wed Oct 14, 2009 12:08 pm Post subject: Propeller Selection |
On Wednesday 14 October 2009 12:59, Bill Shirley Mitchell wrote:
| Quote: | Question relating to propeller and O-200 engine, where is the placement of
The O200 is said to be one of the heavier engine choices. I'm waiting to
select the battery location until I've hung the engine, and done a
preliminary weight and balance.
I'd like to place it forward of the firewall, because longer cables add to
weight, and there will be some voltage drop due to the longer cable. However,
if the aircraft comes out too nose heavy, there may be no choice.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
Mathematics and alcohol do not mix.
Do not drink and derive.
floyd wilkes
Joined: 11 Jun 2007 Posts: 39 Location: spring branch, tx
Posted: Wed Oct 14, 2009 4:50 pm Post subject: Propeller Selection |
Bill,
Mine are just behind the right seat. Actually, I have two batteries there, the usual RG680 and a 8AH SLA as emergency backup for my electrically dependent engine.
On final approach with flaps down, I must hold back stick to maintain glide slope. This is not a problem, but would be much worse if the batteries were forward.
Floyd Wilkes
601XL O-200
_________________ Floyd Wilkes |
ter_turn(at)yahoo.com Guest
Posted: Wed Oct 14, 2009 5:21 pm Post subject: Propeller Selection |
Bill, can you give us your firewall forward weight? Thanks.
Terry
--- On Wed, 10/14/09, Floyd <fwilkes(at)gvtc.com> wrote:
Subject: Re: Propeller Selection
Date: Wednesday, October 14, 2009, 7:46 PM
#yiv1840145840 DIV { MARGIN:0px;} Bill,
Floyd Wilkes
601XL O-200
floyd wilkes
Posted: Wed Oct 14, 2009 6:14 pm Post subject: Propeller Selection |
Terry,
Floyd here not Bill. My weights were nose wheel 258 lbs at -500 mm
right wheel 274 lbs at 648 mm
left wheel 280 lbs at 648 mm
601XL O-200 with two batteries aft of right seat. Standard O-200A with light weight starter and standard 70 amp altenator, no fuel pump, no vaccuum pump.
Senenich W68-ZK-57G prop
Floyd Wilkes
