gmcjetpilot
Posted: Tue Oct 13, 2009 11:26 am Post subject: Bi-Directional Zeners for Contactors |
The EV200 is a different animal from the ubiquitous coil/solenoid/contactor. I did lots of
research on this. Notice the activation and latched current? Very small. You don't
need diodes. The EMF part, I'm not sure about. The diode on the classic contactor is
to suppress the voltage spike from the collapsing field, thus protecting the switch from arching and reduced life and failure.
I don't recall the details, but the EV200 uses different mechanical geometry and electro-
magnetism activation and scheme that is more efficient, while maintaining ridiculous power
specs.
I also looked at the cost v benefit. On a Lancair, cost no object, EV200 why not. For the
average home built, even my RV7 the standard contactors are fine. Still the price of the
EV200 has come way down; it's an attractive option now, especially for saving weight. It
does not weigh a lot less it self versus a standard contactor, but it uses about +0.50 amps
less to stay latched. For guys trying to fly day/night deluxe VFR with a lighter wight 30 or
40 amp alternator, every 0.50 amp counts.
These are my opinions. If you don't like them, request a refund for what you paid for it.
Cheers.
>From: mikeeasley <mikeeasley(at)aol.com (mikeeasley(at)aol.com)>
| Quote: | Subject: Diodes vs. Bi-Directional Zeners for Contactors
| Quote: | I'm building a new power grid for a customer and the research on contactors ended
up with some digging on the diodes that we use across the coils of the contactors,
and whether they're necessary. We're using a couple Tyco Kilovac EV200s
and since they have pigtail wires instead of terminals, it's tougher to install
the diodes. Tyco says we don't need "back EMF protection" with the EV200s.
But we are also using the LEV100 contactors, which do need the back EMF protection.
mikeeasley(at)aol.com Guest
Posted: Tue Oct 13, 2009 11:58 am Post subject: Bi-Directional Zeners for Contactors |
The Tyco EV200 has built-in back EMF suppression according to the engineer at Tyco Kilovac. I didn't ask him what kind of suppression, but he confirmed that it wasn't necessary to have any external suppression. The LEV series needs external suppression. The EV series has a circuit that reduces coil amperage once it closes also.
Mike Easley
Colorado Springs
In a message dated 10/13/09 13:27:27 Mountain Daylight Time, gmcjetpilot(at)yahoo.com writes:
| Quote: | .aolmailheader {font-size:8pt; color:black; font-family:Arial} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal} The EV200 is a different animal from the ubiquitous coil/solenoid/contactor. I did lots of
specs.
Cheers.
bobmeyers(at)meyersfamily Guest
Posted: Tue Oct 13, 2009 2:44 pm Post subject: Bi-Directional Zeners for Contactors |
That .50 amp savings was why I put one in my Aerovee powered Sonex with a 20 amp alternator. I had already mounted a fine cheap one from B&C but I had an opportunity to get one cheap and replace it.
"Scotty, I need more power"
Bob Meyers
Building Sonex 982SX Web Site Index http://meyersfamily.org/Sonex982.html
On Oct 13, 2009, at 2:24 PM, gmcjetpilot(at)yahoo.com (gmcjetpilot(at)yahoo.com) wrote:
[quote]The EV200 is a different animal from the ubiquitous coil/solenoid/contactor. I did lots of
specs.
Cheers.
| [b]
