MauleDriver(at)nc.rr.com Guest
Posted: Fri Oct 09, 2009 7:23 pm Post subject: What to use for a cabin speaker and where to mount it? |
Not much in the archives... what have people installed?
Bill "fooling around with a PMA9000EX install" Watson
AirMike
Posted: Sat Oct 10, 2009 1:57 am Post subject: What to use for a cabin speaker and where to mount it? |
I got an inexpensive one at Fry's Electronics in Calif. - There, you can also get a nice durable and inexpensive grill to cover the speaker.
There is a specific OHM requirement which is probably in the manual for the audio panel. I cut a hole in the side panel at hip level in the right side of the back seat. Seems to work fine, but with all the excellent headsets out there - not sure it is really needed.
120.03 KB |
2725 Time(s) |
_________________ See you OSH '18
Q/B - sold. |
dlm46007(at)cox.net Guest
Posted: Sat Oct 10, 2009 2:45 am Post subject: What to use for a cabin speaker and where to mount it? |
Not required. Just another thing to break. Put jacks at all four seats and
an aux jack on the panel.
Posted: Sat Oct 10, 2009 7:14 am Post subject: What to use for a cabin speaker and where to mount it? |
I mounted a 11-01569 from ACS in the upper section of the rear bulkhead. Works great.
We put a doubler to beef up the cut in the corrugation, then the interior cloth went right over the speaker so it's invisible.
It's about 2 feet fwd of the AFS magnetometer, but it doesn't seem to affect it.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA 95076
831-722-9141 Shop
831-750-0284 Cell
On Fri, Oct 9, 2009 at 8:22 PM, Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)> wrote:
[quote] --> RV10-List message posted by: Bill Mauledriver Watson <MauleDriver(at)nc.rr.com (MauleDriver(at)nc.rr.com)>
http://forums.matronics.com
le, List Admin.
